Page 6 of 8 FirstFirst 12345678 LastLast
Results 51 to 60 of 79
Thread: 2006 Z06 Install: Part 1
  1. #51
    Apr 2008
    Austin, Tx
    So, when do you approximate you'll be finished?
  2. #52
    Aug 2005
    Quote Originally Posted by barnyard View Post
    Stand-offs epoxied to the floor:
    For each and every little terminal strip? Good god that is a lot of stand offs.
    Could the OP comment on where he bought them? Looking to do something similar.
  3. #53
    Raw Wave pierrotm777's Avatar
    May 2008
    Bordeaux, France
    Won der full job !!!
  4. #54
    Aug 2007
    Quote Originally Posted by sikryd View Post
    Holly Sound Deadening Batman! You better get a supercharger or turbo on that Z06 quick to make up for all that weight. Awesome build bro, congrats!
    It' got a cam, headers, tune, CAI so it's got a few more ponies now then it did when it left the showroom.
    Jay
    ---------- Post added at 06:58 PM ---------- Previous post was at 06:55 PM ----------
    Quote Originally Posted by SKiTLz View Post
    How are you securing all the individual terminal strips etc to the floor? I can't quite tell from the pics? I'm guessing you aren't drilling every single one down or you would have a hell of a lot of holes in your floor with all that equipment.
    Everything is secured to the floor using standoffs that are epoxied. In some of my previous posts, I show a picture of the epoxy I'm using. It's the same stuff they use on the YF-22 to epoxy stanoffs that contain clamps for wire bundles and hydraulic tubing and what not. I have a buddy that works for Lockheed Martin and he turned me on to this stuff.
    Jay
    ---------- Post added at 07:00 PM ---------- Previous post was at 06:58 PM ----------
    Quote Originally Posted by whats77inaname View Post
    It's pretty much already finished. My buddy is working on the other subwoofer (or might be for just a fan, we aren't sure yet) box. Once that is done and secured in place, I need to trim the floor for that side, put on edge guarding and then have the floor painted. Once that is done, I need to have a custom mat made and that will be it.
    Centrafuse came out with new version this week, so I need to upgrade that software. That's a major install so I suspect that will take up my day on Sunday.
    ---------- Post added at 07:04 PM ---------- Previous post was at 07:00 PM ----------
    There are only a couple of terminal strips I used. They have holes on each end. I think I only used two for each strip. But then I also used a bunch for the amps and other goodies in the back.
    The standoffs I got at the same place I got the Epoxy, http://www.theflightshop.com/Cataspx307.html. I used some larger standoffs for the amps I got from my buddy but you can get similar larger ones from The Flight shop as well. If you get the epoxy, it ain't cheap, get a couple of tubes because the shipping kills you because it's considered hazardous material. I made the mistake of buying one tube, 14 bucks, the shipping was $35....DAMN.
    ---------- Post added at 07:05 PM ---------- Previous post was at 07:04 PM ----------
    Quote Originally Posted by pierrotm777 View Post
    Aug 2007
    Ok, let’s take a look at the sub enclosure now. I selected a couple of DLS 10 inch reference subs for my install. These are Single Voice Coil 2 ohm impedance subs:
    http://www.dls.se/en/car/prod.html?produkt=en_505
    They need an 18 liter enclosure, this is the biggest limitation on the size of the sub I can/want to use as I want to build a fiberglass enclosure that will sit in each back corner of the car. Now, I’m a bit concerned if I will have enough volume in that space given it’s shape and clearance issues of the sub, false floor and closure of the hatch. I’ve also got to make the boxes symmetrical in appearance, take into account the height of the driver above the box to make sure not only the hatch closed but does not touch any part of the driver or box so it does not resonate. Big things to accomplish.
    So we start off by laying out what needs to go where and limitations of size and shape. We started by cutting out pieces of cardboard and laying them in the corner and cutting to shape. Once we got things cut to shape, we used a hot glue gun to “weld” the pieces together.
    So, we have the two sides made. My fiberglass buddy uses these cardboard templates to act as a skeleton to apply the fiberglass. Here he started to apply layers of glass mat and resin:
    After several layers we end up with a bottom and sides:
    Jay
    ---------- Post added at 12:26 AM ---------- Previous post was at 12:20 AM ----------
    Sub Part 2:
    Once those basic boxes are done, I make a pair of sub rings for the driver to sit on top of and for attaching. I make these out of MDF and a router with a circle cutter. I screw up the first one but the next two come out just fine.
    Next thing we did was to fine fit the sub box we’ve made so far for a better fit in the car. I was originally going to cut out the carpet where the sub was going to sit but later decided that was not a good idea and left the carpet in place and fitted it that way. What we did was cut the sub box fiberglass pieces along the edges and used those pieces for a more precise fit and look of the box. Once in place, we hot glued those pieces together. From here we drilled 4 holes through the rings and used wooden dowel rods to secure the ring to the sub box using hot glue.
    We then fit the box and ring assembly back into the car to make sure we had the clearance we needed. Once everything was set, my friend then finished up the fiber glassing job. Sorry, no picture of that. But he spent a boat load of time doing it and the box is very thick and rigid as all getout.
    He shaped the box and then gave it a quick covering of a flat satin type finish which was to be temporary but so far I kind of like it. The box was secured to the back of the car using two lag bolts that go through the back tail assembly through a pair of holes that were already there for a pair of plastic cargo hooks used for the cargo net in the back.
    Here’ what it looks like:
    The amazing thing was we hit the volume of the box right on the nose. We needed 18-20 liters and the box volumed out to 21 liters. This was checked but placing a plastic bag inside the box and then filling it with water 500 mL at a time….42 times. I didn’t think there was any way we would have hit the volume but sometimes it’s good to be lucky.
    Jay
  6. #56
    Jun 2008
    Perth, Western Australia
    I'm a little worried here, this almost looks like you are coming to the end stages of this project which means:
    A) You are going to be able to drive that Z06 again, and
    B) You are going to need a new project!!
    Damn, that is some extensive work, I cannot wait to see what this puppy looks like when she is all finished up and going. Outstanding, outstanding, outstanding work
  7. #57
    May 2008
    Bordeaux, France
    Oufs , great again job around these sub woofer HP ! I learn more when is see these pictures !
  8. #58
    Aug 2007
    Actuallly, I've been driving the car since last March. Some of those pictures are almost 2 years old. I didn't start posting my build thread until I was actually almost done with the project. I've been driving the car for a year now and everything works fine.
    I've got to finish the other sub box, paint the floor and have the custom mat made. After that I just need to do a fine tune of the audio system and that's it.
    Jay
  9. #59
    ITL
    ITL is offline
    Maximum Bitrate ITL's Avatar
    Jul 2004
    Atlanta, GA
    It's been a while since I visited the forums. The mp3car monthly newsletter brought me to your thread.
    What an incredible install. Almost as impressive is the extensive write-up you've contributed thus far. I know that by the time you get done, it's tough to go back and document everything you endured along the way. Excellent project, Jay.
    CarPC #3: 99% Complete
    Pentium M 1.7Ghz, 1GB DDR2 RAM
    DVD/CD-RW installed in dash below monitor
    OEM LCD relocated for 7" Touchscreen
    Wi-Fi, GPS, PS2 controllers...
    500+ full albums
    4,000+ video games
    music videos, movies, & more!
    old carPC
  10. #60
    Jul 2007
    Give me closure!! Finish the project updates! I know you are probably out actually enjoying the car, but I would consider it a great personal favor if you at least gave us a snapshot of the finished product. Looking forward to whatever else you have to show us on this one! Thanks!
  1. 2008 Peugeot 207 beeing upgraded just a bit
    By boelle in forum Worklogs
    Last Post: 07-02-2011, 02:58 AM
  2. Car PC Install in my 2006 Magnum SRT-8 with Mobile Monitor Mount
    By Redfox0099 in forum Show off your project
    Last Post: 02-23-2008, 03:42 PM
  3. PC install in a BMW 2006 525i possible?
    By coolguy1 in forum General MP3Car Discussion
    Last Post: 01-16-2007, 02:41 PM
  4. Replies: 10
    Last Post: 11-20-2006, 06:14 PM
  5. 2006 Nissan Frontier install
    By Meta in forum Show off your project
    Last Post: 03-27-2006, 07:02 PM
