I have been looking for the amp you have but I haven't been able to find it. What brand is it? Also is there a way to get a control like the one you but for a regular amp?
Done deal with the soldering. Time to go test the remote..probably still not working. Its all good though imma order another.
I am now wondering if I should revisit the mini amp and look for one that has a remote and physical buttons for adjusting which will come in handy if the remote or IR such as in the situation break for some reason. The thing is I still want the amp not visible. The only component I want visible is the tablet.
"Live Free!!!...It's all about Open Source"
Current Proj:'09 Altima In-Dash Android Tablet and System Upgrade
Old Proj II
Old Proj I
YouTube:Project Videos
Homepage: HexxWorld.net
Twitter:http://twitter.com/hexxamillion
I got it from ebay. There arent many that have remotes then this is the only one I found that has an extended IR. The brand is pcb. I will send you the link when I get home.
Old Proj II
Old Proj I
I just dropped my car off to get my LED ground signals and muffler chrome tips installed.
Sent from my ultimate Galaxy Tab using tapatalk.
Old Proj II
Old Proj I
I searched ebay and googled it. Nada could not even find the brand, but did see a couple of chinese amps. Were you able the find the link? Did you upgrade to gingerbread?
This is the link to the item on ebay: http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
Old Proj II
Old Proj I
Thank You very much!!! I hope you dont mind that I posted a link of your work over at xda. There are other people out that want to intergrate the tab into their car but are a bit lost again thanks for your help!
Old Proj II
Old Proj I
Ok..so just as I did with my last car I am upgrading my interior lights to LED. I decided on the blue LED color vs. the bright white which is what I had in my last car.
I am also getting an LED door handle kit which is something different for me. I was think about having them wired with the turn signal..I dunno still deciding.
Old Proj II
Old Proj I
Hey first off excellent thread and I'm also about to start down the same path you've outlined in this thread. I have a 2011 WRX Sedan, a rooted Sprint Galaxy Tab I picked up off woot.com, and my rooted HTC Incredible that I plan on integrating together in the vehicle when on the road.
My stock head unit allows both devices to connect via Bluetooth. I tested streaming music via Bluetooth and called my Incredible from my fiancee's cell... it worked fine. My issue I found was that I couldn't figure out a way to get the tablet to restart the music once I hung up. I recently bought Tasker for the sake of having that in my arsenal... just in case, but I don't think I can use that for my problem.
I'm torn if I want to actually remove the OEM head unit and replace it with other equipment to achieve this setup, or find a way to do this without removing it... either way, nice write-up.. wanted to join to give you props! Going to watch this thing come together.
-Stu
