Page 16 of 43 FirstFirst ... 67891011121314151617181920212223242526 ... LastLast
Results 151 to 160 of 429
Like Tree6Likes
Thread: 2009 Altima Dash Mount Android Tablet PC
  1. #151
    FLAC hexxamillion's Avatar
    Dec 2007
    AZ
    So I've cut my acrylic which I've decided to use as a bottom lip which will keep the tablet in place. Nevermind the color and rough edges, there's still some sanding and painting that I will do. From the looks of it you think that this is not secure enough but if you were holding this and take a good look closer you will know that is will be secure.
    I will also be sanding the upper inside edge of the double din opening at about a 45 degree angle (give or take) so that the top of the tablet will sit back a little further. I plan on lining the inside of the bottom acrylic once in place with some type of soft fabric (felt, or something) and attach it so that it adds even more snug fit and prevent some minor scratching on the side of my tab. I can't wait because this is simple enough that I should complete this before the weekend is over.
    There also will be a small notch cut on the right side just enough for my USB cable.
    Stay tuned..
    "Live Free!!!...It's all about Open Source"
    Recent Proj
    Old Proj II
    Old Proj I
    YouTube:Project Videos
    Homepage: HexxWorld.net
    Twitter:http://twitter.com/hexxamillion
  2. #152
    Dec 2007
    AZ
    Quote Originally Posted by hexxamillion View Post
    Here's a video I found about the Parrot device I am considering.
    hmm...I need to look into an accessory battery.
    second thought.... not so sure about this product.
    Recent Proj
    Old Proj II
    Old Proj I
  3. #153
    Dec 2007
    AZ
    This morning I started the modification on my dash kit. It all went well until I got to the charger connector. That part of the cable can't really bend beyond 40 degrees if that over and over. So I ended up having to cut this ridiculous notch on the right side. I wasn't happy about that but my work around to this is to mount an acrylic piece following the shape of the front of the dashkit where the notch was cut. I will essentially make a "slot" that will cover the ugly notch with an opening at the top so that the connector will slide down as I slide my tablet down in place. The slot will be mounted at a slight angle and will eventually be painted along with the rest of the kit for blending....crazy business.
    It's hard to explain all of this but you will just have to see once I'm done. Here are a few more pics so far from this morning.
    Here you can see the crazy notch I had to cut..no worries I think I have a plan to cover this. Worse case is I buy another dashkit and rework this.
    Recent Proj
    Old Proj II
    Old Proj I
  4. #154
    Dec 2007
    AZ
    Wow I got alot going on now... Well I am now at the stage for roughing up my surfaces to prep for the 3M adhesive then after that sits overnight I will paint...and then and then..
    Recent Proj
    Old Proj II
    Old Proj I
  5. #155
    Dec 2007
    AZ
    Progress Update
    Here are the latest pics. I roughed up the surfaces and attached the bottom lip and "slot". I used 3M adhesive for the bottom lip and for the slot which I rigged. I used a small hinge which is screwed to the dash kit with a piece of acrylic screwed in the middle of the hinge, sort of like a wedge. This is how I managed to rig the hinge to be stationary at just enough angle for the USB charger connector to slide down.
    I will let this sit overnight then spray paint tomorrow.
    This is the front view and you can see what I am planning for this crazy slot that I ended up cutting. This will blend though after its all finished and painted.
    This is the view from the bottom.
    This is the view on the side where I have the hinge mounted which will serve as the slot for the USB cable connector. I know this may be more dramatic than I planned or than any of you may like, but this works for me. So I'm improvising...what of it??
    Top view
    This is the view from the rear/inside
    Stay tuned for more tomorrow..
    Recent Proj
    Old Proj II
    Old Proj I
  6. #156
    Dec 2007
    AZ
    Paint time!
    Yeah so...I decided to go ahead and put my first coat of paint. As warm and dry as it is outside it should dry rather quickly.
    Recent Proj
    Old Proj II
    Old Proj I
  7. #157
    Dec 2007
    AZ
    OK. I promise this is my last post tonight.
    The paint is dry and I am able to simply drop my tab in the new mount. This was a very simple (not so elaborate) mod but its gonna provide me with a nice and quick mount/unmount of my tab plus it sits more flush with the dashkit vs. how I currently have the Galaxy OEM car swivel mount.
    Tomorrow I will install this in my car which will replace my old mount. Can't wait!
    Recent Proj
    Old Proj II
    Old Proj I
  8. #158
    Dec 2007
    AZ
    Tab Mount Version 2
    All done! for now... Here are the results of my new mount.
    Recent Proj
    Old Proj II
    Old Proj I
  9. #159
    Dec 2007
    AZ
    Here is my new YouTube video demoing the mount and comparing to my old one.
    Recent Proj
    Old Proj II
    Old Proj I
  10. #160
    licensed to kill - FKA kev000
    tripzero's Avatar
    Aug 2006
    16.40618, 120.61106
    Not bad. Do you just leave it on when you are not in the car? Or do you take it out with you? You a2dp from your phone?
    Former author of LinuxICE, nghost, nobdy.
    Current author of Automotive Message Broker (AMB).
    Works on Tizen IVI. Does not represent anyone or anything but himself.
  1. Android Tablet as carpc
    By barryassheton in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 07-10-2012, 02:47 AM
  2. Android Tablet / Phone in car
    By mchipser in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 03-19-2011, 01:21 PM
  3. Android Tablet
    By SLimp3car in forum Software & Software Development
    Last Post: 08-10-2010, 01:36 PM
  4. 2004 Nissan Altima - another Laptop/Tablet mount
    By khuongphihoang in forum Worklogs
    Last Post: 01-21-2007, 07:27 PM
  5. hp tc1100 tablet and dock dash-mount
    By bask0g in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 06-26-2004, 10:43 AM
