Page 20 of 43 FirstFirst ... 101112131415161718192021222324252627282930 ... LastLast
Results 191 to 200 of 429
Like Tree6Likes
Thread: 2009 Altima Dash Mount Android Tablet PC
  1. #191
    FLAC hexxamillion's Avatar
    Dec 2007
    AZ
    EGO Flash OLED Display Relocation
    Ok so remember when I stated earlier that I did not want to cut any factory dash stuff..well I was just joking
    Turns out that the original location where I had the EGO Flash display mounted just above my tablet was no good. The crazy Phoenix sun made me decide to move it. So now I placed it below on the front of my lower storage bin door. I don't have to worry about needing it at eye level because its just an integration point for my music and phone I don't need to relay on the display for anything on a constant basis. It's dark outside now so I will take another pic tomorrow when there is more light.
    I drilled a hole through the lower storage bin door so that I could feed the cable from the EGO Flash display straight back and feed it up towards the top of my dash where the EGO Flash module is mounted. This also allows the display to adhere flush against the door. I am also going to relocate the volume control from underneath the dash to inside the storage bin on the wall or behind the door.
    "Live Free!!!...It's all about Open Source"
    Recent Proj
    Old Proj II
    Old Proj I
    YouTube:Project Videos
    Homepage: HexxWorld.net
    Twitter:http://twitter.com/hexxamillion
  2. #192
    Dec 2007
    AZ
    I'm done modding/fabbing hardware tonite but I am going to continue working on some automation with tasker.
    Recent Proj
    Old Proj II
    Old Proj I
  3. #193
    Dec 2007
    AZ
    Quote Originally Posted by hexxamillion View Post
    Fun stuff playing with tasker. So I have tested and configured some simple automated tasks on my galaxytab. Since my mornings are pretty much routine I set my display to wake about the time I leave for week. Then I set a display timeout for roughly the time I usually arrive at work.
    I also config'd a task to turn on my display roughly around the time I leave work. So what about those times outside of the daily routine? Well I installed the tasker app on my Droid Bionic and config'd a task to send a text to my tablet thus waking it. I created a tasker widget so that all I have to do is tough the widget and the text gets sent. This prevents me from having to actually launch my text messenger then type and send the text manually.
    I installed the no lock app so I do not have to worry about unlocking after the display wakes up which also prevents the display from going back to sleep if it is not unlocked. By default i set my display to timeout in an hour and have brightness set to auto and powersave enabled.
    Sent from my DROID BIONIC using Tapatalk
    I configured another task and widget on my Bionic that sends a text to my tablet with the term "Timeout". Then in response I have a task on my tablet so then when it receives that text from my Bionic it will set the display to timeout in one minute. Since this actually changes the display timeout settings to one minute all of my other tasks to wake up the display sets the display timeout at an increased interval for 30min which is good enough in case I end up going out to the store no sooner than when I get home or something...which happens often
    Recent Proj
    Old Proj II
    Old Proj I
  4. #194
    Dec 2007
    AZ
    I have a little engine whine but I purchased a stereo in line noise filter which should help.
    Sent from my ultimate Galaxy Tab using tapatalk ...and I'm probably in my car..dont worry I'm not driving : )
    Recent Proj
    Old Proj II
    Old Proj I
  5. #195
    Mar 2011
    Marietta, Ohio
    Great build! Could you please list brand/model of the Mini 4 CH amp you used? I can't quite make it out in the pictures. Also how is it's performance?
  6. #196
    Dec 2007
    AZ
    Quote Originally Posted by sall View Post
    This is actually some brand shipped out of Taiwan (PBC AMP-168)...I got it from eBay. What attracted me to it was that it was unique from all other mini amps that I have seen. It has a remote control which in itself is not so unique but this one has an extended cable for the IR (about 4') which works great because that meant i could mount the mini amp off to the side and the IR in front of me. It works great for what it is and actually provides some great output to my factory speakers. They sound like aftermarket. The drawback is that I have only seen this supplied through ebay from overseas and while it works great and the sound quality is also crisp and great, the design of the unit may be not as well. One of the channels in mine blew and I think somehow the IR connection got shorted out somehow. So I purchased another one. So far its been working fine. Could have just been a defected unit.
    Here are two photos from one of my earlier posts:
    In any event, ironically I was just looking into a different amp, one supplied here in the states.
    http://www.audiopipe.com/products/am...apsm-4050.html
    Recent Proj
    Old Proj II
    Old Proj I
  7. #197
    Mar 2011
    Marietta, Ohio
    Great! thanks! Do you have any links to eBay auction perhaps for the PDC? I am unable to locate any! I am on my second amp now after first using a Phonics Digital Mini amp and now a TDA7850 and while both sound good the PD has turn off crackle and TDA7850 has noise even after ground loop isolator. Frustrated haha.
  8. #198
    Dec 2007
    AZ
    I understand the frustration. I had to actually go dig it up myself in my past email because it is hard to find. So here it is and Eureeka! http://cgi.ebay.com/ebaymotors/ws/eB...AQ:MOTORS:1123
    Recent Proj
    Old Proj II
    Old Proj I
  9. #199
    Mar 2011
    Marietta, Ohio
    Thanks for looking that up for me! Much appreciated!
  10. #200
    Dec 2007
    AZ
    No prob. Just thought I'd mention that if you do decide to order it don't expect it over night. It has been my experience it takes a few weeks probably due to the whole customs thing. for the price it actually pumps out some good sound.
    Recent Proj
    Old Proj II
    Old Proj I
  1. Android Tablet as carpc
    By barryassheton in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 07-10-2012, 02:47 AM
  2. Android Tablet / Phone in car
    By mchipser in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 03-19-2011, 01:21 PM
  3. Android Tablet
    By SLimp3car in forum Software & Software Development
    Last Post: 08-10-2010, 01:36 PM
  4. 2004 Nissan Altima - another Laptop/Tablet mount
    By khuongphihoang in forum Worklogs
    Last Post: 01-21-2007, 07:27 PM
  5. hp tc1100 tablet and dock dash-mount
    By bask0g in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 06-26-2004, 10:43 AM
