97 Nissan MAXIMAPC Version 2
I decided to upgrade my carpc that I had done last year. If anyone is interested in looking at the old setup, here is the link http://www.mp3car.com/show-off-your-...-maximapc.html
Some Problems with the old Setup
- Too much Power Consumption
- Bugs with home made startup/shutdown controller
- Static Noise heard
- Long USB cables causing signal problems
- Long bootup time
So I got rid of the old setup and had the following new components.
Quote:
Intel D410PT MINI ITX Motherboard w/ Fanless 1.6 GHZ Intel Atom Processor
Corsair 32GB SSD Drive
M4-ATX Startup/Shutdown Controller
TUFF N TINY 4GB Flash Drive
Nlite Windows Xp Professional SP2
Custom Plexiglas enclosure designed to fit completely behind the dashboard
OEM Nissan Heated Switch integrated for on/off purposes
Custom Integrated USB Port in the Ashtray
I still kept the same devices (like the Garmin GPS, OBDII controller) but I decided to store all my music in a flash drive. Since the software I was using was Centrafuse 3.1, it still did not support ipod capibility with iphones and itouches, I decided that there is no point in storing the music on an ipod.
Pictures
The Old Setup
https://lh3.googleusercontent.com/_f...0/IMG_0119.JPG
A close up of the old switch
https://lh6.googleusercontent.com/_f...0/IMG_0120.JPG
So, now the new stuff, the goal of this project was to:
- Keep the existing OEM look
- Fix all problems from previous setup
- Integrate everything behind the dash
- Keep the new project on a budget.
First, I decided to get a MINI ITX form board, because I realized I had just enough space to fit a MINI-ITX board if I could get my hands on. Now, I know that ventilation in that area is minimal, so I had to keep cooling in my mind. I came across this one day on ebay
http://www.mini-box.com/core/media/m...41af73e38446c3
and it was perfect for my application. It was fanless and only drew 20 - 25 watts at maximum load, which meant less power consumption, and less thermal heat, which I got for 40 bux (awesome deal). So, I ended up getting that, and while I was there I also got a M4-ATX shutdown/startup controller which worked soo much better than my old setup (got a used one for 30 bux). I also got a SSD drive, because I wanted to boot to the os fast and stop the hard drive from failing from vibrations in the car. This is the one I got, cuz I got it on ebay for just 24 dollars!! Insane steal!
http://www.scan.co.uk/Images/Products/1036515-a.jpg
Next, I had slipstream my windows xp cd, so I used nlite for that. I found an online tutorial showing how to slipstream xp cd for a netbook so I followed that and got good results. Below are a few pictures.
https://lh3.googleusercontent.com/_f...0/IMG_0122.JPG
https://lh4.googleusercontent.com/_f...0/IMG_0123.JPG
Next, I wired my OEM Nissan Heated seat warmer switch. I wired it up for use and then used a 2000 grit wet and dry sandpaper to remove the marking off the switch.
https://lh3.googleusercontent.com/_f...0/IMG_0125.JPG
Next, I made my wiring diagram which is shown below.
https://lh4.googleusercontent.com/_f...pc%20setup.jpg
Installation
Here are some install pictures. Below you will see my plexiglass enclosure. The design came out perfect, I had only a few mm in tolerance around the edges. I also fitted a small fan to blow any heat generated.
https://lh6.googleusercontent.com/_f...0/IMG_0127.JPG
https://lh5.googleusercontent.com/_f...0/IMG_0129.JPG
https://lh3.googleusercontent.com/_f...0/IMG_0130.JPG
https://lh4.googleusercontent.com/_f...0/IMG_0134.JPG
https://lh5.googleusercontent.com/_f...0/IMG_0128.JPG
https://lh4.googleusercontent.com/_f...0/IMG_0135.JPG
Now doing a test run.
https://lh6.googleusercontent.com/_f...0/IMG_0143.JPG
TADAAAAAAA
https://lh5.googleusercontent.com/_f...0/IMG_0150.JPG
https://lh4.googleusercontent.com/_f...0/IMG_0155.JPG
Finishing.......FINISHED
Here is the finished setup with everything working, as you can see the new switch at its location.
https://lh6.googleusercontent.com/_f...0/IMG_0156.JPG
My USB port integrated into the ash tray
https://lh3.googleusercontent.com/_f...0/IMG_0179.JPG
https://lh4.googleusercontent.com/_f...0/IMG_0158.JPG
https://lh4.googleusercontent.com/_f...0/IMG_0161.JPG
https://lh6.googleusercontent.com/_f...0/IMG_0162.JPG
Finished!
https://lh4.googleusercontent.com/_f...0/IMG_0167.JPG
Everything is installed and working at the moment, I might have to upgrade my usb port as it seems it sometimes losses signal. But overall, I would like to know your thoughts and opinions on this project. So, what do you all think?
