Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: 2008 toyota tacoma carputer and audio upgrade
  1. #11
    Low Bitrate chris_h's Avatar
    Apr 2010
    VT
    Some shots of my peripherals; tiny-a$$ keyboard i keep in the armrest; hardwired in
    I mounted a USB DVD-rom in the armrest too. the DVD drive in the system was too inaccessible being under the seat
    you can also see the USB port i mounted into my cupholders. (along with my USB NES controller! ROM's on the go!)
    Click for full-size
  2. #12
    Apr 2010
    VT
    system installed, along with amp and sub. it's all fairly compact right behind the drivers seat, and still gives me one passenger in the back. it came out pretty well.
    i threw together a quick little plywood box so the Audiobahn could fit in that little space between the box and seat. glued on some (reasonably similar) indoor/outdoor carpet that i had kicking around
    don't mind the fingerprints, needs a cleaning
    the PC, kicker amp, fuse block and dist block aren't mounted down yet. they don't really move much, though. I just haven't gotten around to getting some self tapping screws
    everything all tucked away
    seat slid forward. you can see how hard it is to access the DVD drive in the PC. that's why i added a USB cdrom in the armrest
  3. #13
    Apr 2010
    VT
    for my own records... (and anyone else who's interested)
    Lilliput EBY701-NP/C/T
    drivers here:
    Quote Originally Posted by LancerAM View Post
    The links on the lilliput site are broken, but if you go to the manufacturer of the touch panel you are in good shape.
    http://www.touchkit.com/Drivers.asp
    Hope this helps some folks out.
  1. 98 toyota tacoma tacoputer
    By a_zo in forum Worklogs
    Last Post: 01-08-2009, 10:01 PM
  2. 2008 Toyota Tacoma CD changer pinouts
    By dd9293 in forum Newbie
    Last Post: 03-13-2008, 05:45 PM
  3. '03 Toyota Tacoma first CarPC
    By JoeDirte in forum Worklogs
    Last Post: 05-07-2005, 08:39 AM
  4. '03 Toyota Tacoma: First CarPC
    By JoeDirte in forum Show off your project
    Last Post: 05-06-2005, 01:40 PM
  5. OBD-II For 98 Toyota Tacoma
    By Jailer in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 06-23-2004, 04:19 PM
