Results 1 to 10 of 13
Thread: 2008 toyota tacoma carputer and audio upgrade
    Low Bitrate chris_h's Avatar
    Apr 2010
    VT
    Hey All. I've had my build complete for about 10 months. I've been meaning to post up a thread but haven't gotten around to it till now. I had been piecing together the parts for over a year, finally collecting everything I wanted to do my install. Here's my parts list:
    Head Unit: Custom Carputer + Touchscreen
    Front Speakers: Polk DB6501 component
    Rear Speakers: Polk DB651 coaxial
    Sub: Kicker CVR 12"
    Amp 1: Audiobahn A4002T mono
    Amp 2: Kicker ZX350.4 four channel
    Here's a draft of my layout I did before I started shopping:
    This wasn't my first car audio build, by far, but this was my first carputer install. The build was pretty straight forward. Wiring was the toughest part. I went through very thorough planning beforehand so that helped quite a bit.
    I still don't have everything mounted down yet, but it's all pretty stable where it is. I'm happy to entertain questions if anyone has them.
    Cheers! and thanks for looking.
    ---------- Post added at 09:04 PM ---------- Previous post was at 08:49 PM ----------
    my PC specs are as follows:
    LCD: Lilliput 7", Scosche Tacoma Dash kit, Bybyte.com double-din 7" lcd adapter
    Case: Morex 3688
    Mainboard: MSI MS-7265
    Memory: Transcend 2 x 1gb DDR2 667
    PSU: M2-ATX
    WiFi: Qcom LR802UKN wireless N
    DVD: Panasonic CW-8124-B DVDrom
    DVD2: dig_71042 (mounted in armrest)
    HDD: Seagate 2.5" 80gb 7200rpm Extreme Environments drive
    CPU: Intel T2500 Core Duo 2.0GHz
    Software: Windows Embedded Standard, Road Runner front end
    Other: Custom "P8" molex power connector to make for easy installation + removal for bench testing, etc
    (Click for full-size)
    Jan 2008
    you have 4 ga going into the dist block, and out to the amps? i think you should have used 2 ga.
    and the 16 ga power wire going into the pc seems pretty small to me..
    other then that, good luck on the install!
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
    Apr 2010
    VT
    hi! yep i'm using 4ga from the battery to the dist block. 16ga is what the M2-atx power supply comes with, with 600v PVC jacket. So I just matched that.
    I was considering going to 2ga from the battery but I checked around and saw some other installs using 4ga so thought I'd be OK.
    thanks for the good luck wishes
    Jan 2008
    i always prefer to have too thick of a wire then not enough. first, it helps dissipate any heat build up, and keeps enough current flowing to my devices, and it helps when i want to upgrade something, i don't need to re-do my power runs all the time.. (though, just remember, i also want to do a led reverse lamp mod that would require almost 23A of power-- look up cree xm-l led's-- i want to use 8 of them!!)
    the reason most installs use 4 ga off the battery to the distro-block, is usually because the amps don't draw any more then what a 8ga can supply-- which, with 2 amps, makes up what a single 4 ga can supply..
    in your case, the bottle neck would be the 4ga off the battery.
    according to my nifty 'lil chart:
    assuming you used about 15' of power wire to the components, you are just above the recommended max of 4ga cabling. i don't think that the install is to the point where you need to worry about it catching fire or anything, but the wire is a little thinner then what i would prefer to use in my own installs..
    HID retro--100%
    Apr 2010
    VT
    i was actually just looking the same thing up haha
    i checked here (basically the same chart)
    http://www.the12volt.com/info/recwirsz.asp
    "4ga will do 800 watts at 12 feet long
    4ga will do 1000 watts at 8 feet long"
    My sub amp is 200 watts and the speakers amp is 240, my computer can't be pulling more than 100watts total
    this is all rough estimates of course but, I think (hope) it's ok
    does my math add up?
    Quote Originally Posted by soundman98 View Post
    makes sense.
    Jan 2008
    wait, the12volt.com loads fine for you? it worked fine for me yesterday, but now it won't go through anymore... i was trying to load that graph before i had to resort to my personal stash...
    yeah, those numbers make sense-- the amps will rarely get used to their full 40A draw, so to figure everything as a 30A draw would probably be fine-- which is why you don't need to worry about anything starting on fire-- and why the 4ga is will work...
    but if you ever start to get involved in sound level contests, then it is a different story!
    HID retro--100%
    Apr 2010
    VT
    well that's comforting. thank you!
    when i get used to (read:dissatisfied with, lol) my system, i'll be sure to kick myself and come back to let you "i told you so" ^_^
    edit; yeah the12volt.com is working ok for me.
    maybe try killing your history/cookie?
    Jan 2008
    well, i cleared everything, and it still won't go through.. i don't get it.. what browser are you using?
    HID retro--100%
    Apr 2010
    VT
    Firefox 3.6.16
    Apr 2010
    VT
    Here's some shots of the screen installed.
    Lilliput 7", bbybyte.com double-din adapter, Scosche tacoma dash kit
    Click for Full-size
  1. 98 toyota tacoma tacoputer
    By a_zo in forum Worklogs
    Last Post: 01-08-2009, 09:01 PM
  2. 2008 Toyota Tacoma CD changer pinouts
    By dd9293 in forum Newbie
    Last Post: 03-13-2008, 04:45 PM
  3. '03 Toyota Tacoma first CarPC
    By JoeDirte in forum Worklogs
    Last Post: 05-07-2005, 07:39 AM
  4. '03 Toyota Tacoma: First CarPC
    By JoeDirte in forum Show off your project
    Last Post: 05-06-2005, 12:40 PM
  5. OBD-II For 98 Toyota Tacoma
    By Jailer in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 06-23-2004, 03:19 PM
