Right, it's almost finished! Just the cigarette lighter to go back in.
After about 3 re-builds and lots of tinkering I finally managed to make the tablet fit. The amp under the seat takes care of the audio and I have built a little volume control in to centre console to take care of things on that side.
I've been using a tomtom charger that has a higher output than the original, it seems to be doing the job, and is hardwired in to the stereo loom now.
I was actually looking to do something like this, I still have a bit of alternator whine in the system, its probably just a bad earth but I need to investigate.
As for the GPS that works perfectly in this configuration, overall im pretty thrilled with how it turned out. Possibly in the near future I want to look at a motorized over/shutter or someway of removing the tab. Currently it's pretty hardwired in to the dash.
The tab is fixed in using a bit of plastic that came as a case with the tab. I ripped it apart and fixed it in using that:
The next job is to pull the centre console out and fix an alternative line in - for using ipods and other kit. I also need to think about some sort of source switch between the tab and the line in.
Thoughts and comments always appreciated.
