97 Olds Aurora 3.2 Ghz CarPc
Hello everyone I am new to this site, I just want to say thank you to everyone for the vast amounts of info this site contains. Made integration so much easier!
Here is my car, a 1997 Oldsmobile Aurora, I have had the car for around 4 years now.
http://i56.tinypic.com/30mti5j.jpg
http://img849.yfrog.com/img849/1716/mg8672.th.jpg
http://i52.tinypic.com/2gwtc15.jpg
http://i54.tinypic.com/24oq2s3.jpg
My CarPc specs are -
-Intel Core i3 550 3.2 Ghz
-Gigabyte H55N-USB3 1333 FSB Dual Channel DDR3
-OCZ 4GB DDR3 PC3-10666 Gold Low voltage dual channel (256 mb shared for video)
-OCZ Vertex 2 E Series 2.5in SATA II Solid State Drive, 60GB
-1.5 TB USB 3 Enclosure (mounted behind rear seat)
-1 TB USB InWin Ammo external hdd with rfid security tag (in glovebox)
-Sound Blaster USB X-fi THX external sound card
-Toughbox 12v Powered USB Hub
-Mini-box M4 atx 12 volt DC-DC 250 watt (300 peak) psu
-MCS USB 4 Relay and 4 input contoller (for amps, fans and power antenna)
-Mini-touch 700 touchscreen
My next add ons will be-
-to get my joycon module to properly interface with the Aurora's steering wheel buttons, works with the key off but not on accessory or power because the Aurora sends 12volts into the resistance line that goes into the stock hu. Time to go swimming under the dash to find that wire
-28mm Rear View CCD Camera with Night Vision LED's (autoswitches at monitor, CarPc can be off)
-GPS
-OBDLink Wifi Scan Tool - up to 90 real time specs at once, also works with my smartphone
-Andrea's PureAudio USB-SA mic for voice command and bluetooth speaker phone (using cellphones handheld while driving is illegal here)
- 2 watt wireless N Wifi Usb - used for sailboats for hotspots while docked in harbor, should give me some good range with my camera or anything Im connecting to
http://i56.tinypic.com/2h7m34x.jpg
http://i56.tinypic.com/dgkzf7.jpg
http://i51.tinypic.com/27zestd.jpg
http://i52.tinypic.com/5n7r7t.jpg
http://i55.tinypic.com/1415u8n.jpg
http://i54.tinypic.com/10emr6h.jpg
Here is the schematic of my wiring -
http://i54.tinypic.com/2vkhqw1.png
Let me know what you guys think! Thank you again to everyone for all the info and to Chris at Mo Co So!
