Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 43
Thread: Toyota Camry - Hi Tech CarPC
  1. #11
    FLAC hexxamillion's Avatar
    Dec 2007
    AZ
    Nice and clean install. I like the front cam.
    "Live Free!!!...It's all about Open Source"
    Recent Proj
    Old Proj II
    Old Proj I
    YouTube:Project Videos
    Homepage: HexxWorld.net
    Twitter:http://twitter.com/hexxamillion
  2. #12
    Oct 2006
    Kiev, Ukraine
    Thanks. Front cam may help to park closer to the objects but the camera should be not reversed. By some reason I had dificulty to find it in local stores.
  3. #13
    Jul 2011
    Hey, awesome CarPC! I'm wanting to make a similar install. I'm just curious whether or not you installed a CD/DVD Player? And if so, where did you decide to mount it?
  4. #14
    Oct 2006
    Kiev, Ukraine
    Hi Chanus! There is no need in CD/DVD drive, because any music,videos or programs I can write to carpc via flash-drive with using USB hub. Anyway I can bought external USB DVD drive and use it when it will be needed.
  5. #15
    Jul 2011
    Oh ok, that makes perfect sense. Thank you very much for the fast response!
  6. #16
    Low Bitrate 2009Prius's Avatar
    Sep 2010
    Very, very nice!
    Microsoft VX-2000 probably won't have enough resolution to record license plate numbers, would it?
    PriiDash(TM) open source software
    Enhanced Instrument Panel and Data Logger
  7. #17
    Aug 2009
    I really like the idea of the amp and usb controls....any idea where one might get an american version of this?
  8. #18
    Oct 2010
    869 panel size
    Hi, your carpc came out great and looks like it was meant to be there.
    I want to use this same display and would go the same route with removing the external casing but I am hesitant to buy since I don't know the panel size. I have 7.5'' x 5.25'' to work with and am worried that this will be too wide. The problem with mine is that I can't cut anything to gain more left/right room. Do you happen to know these dimensions?
    Thanks.
    Edit::
    I found this link http://www.mp3car.com/lcd-display/14...imensions.html where someone says its 7.6inch x 4.6inch but didn't confirm.
  9. #19
    Jul 2011
    That is a very clean install. Does anyone know where i can get that 2din trim piece in the States?
  10. #20
    Constant Bitrate Project07MACry's Avatar
    Aug 2009
    BK, NY
    @Erix920:
    Metra makes those kits. They are available through Amazon and eBay.
    Here's a link. The center mount that holds the 7" screen is detachable, so it should be able to accommodate an 8" screen without a whole lot of remodeling...
    All systems are a go...
    Currently in "tweaking" mode.
    The Worklog
  1. Carpc for toyota camry
    By jadon087 in forum Newbie
    Last Post: 09-29-2009, 10:52 AM
  2. 1994 toyota camry
    By hommeg in forum Worklogs
    Last Post: 10-21-2006, 12:19 AM
  3. 2002 Toyota Camry XLE
    By NekkidRidr in forum Newbie
    Last Post: 09-24-2006, 09:50 AM
  4. 2002 toyota camry
    By jurassic262 in forum Show off your project
    Last Post: 04-28-2006, 01:32 AM
Tags for this Thread
