Very nice. Subtle yet not understated
The "I void warranties" shirt is appropriate.
Screen placement is sick man. Definitely following this build.
Wilco,
Great install. Really thinking outside the box... or circle in this case. I am very interested in your screen/NAV retrofit install. I have 2 Mini speedos that may just get the same treatment.
It looks from what you wrote that you did not have the factory nav originally. And I think I see on the other forum where you were looking into what (retrofit) it would take to install it. I even found where someone mentioned that the speedo and tach would have to be replaced as a pair. I think you made the best decision.
I have a few questions if you don't mind:
1. Did the connector to the old speedo fit into the new one?
2. Was anything additional need to be done to restore the indicator lights and speedometer movement?
3. Do all of the lights function as they should?
4. Are you satisfied with the upgraded monitor that you have chosen?
5. What are the compromises or things that aren't exactly what you hoped for (or side effects) as far as the monitor/speedo setup? (if any)
6. Would you be able and/or willing to provide me a name or other contact info for the screen and/or nav speedometer that you used, either here or in a PM?
7. Since the speedo install, have you had any thoughts on how you would have mated the devices together differently? If so, what?
8. Can you clarify that you did indeed have to modify the corner of the screen (and not just the speedo) with a dremel?
It's been a while...
No problem, let me see if I can answer your questions:
Yes. I was pleasantly surprised by this.
No, as soon as I connected it, everything functioned 100% as expected.
Yes, everything was 100% functional.
Yes and no. I am totally happy with the result (and the screen itself is great), but had I the option of obtaining a 6.5" display with the same functionality, it would have saved me from a lot of headaches (and dremeling).
The cut-off corners are a pain for running Windows (start-menu isn't reachable). In my opinion, that was a fair trade for a super-clean OEM look that was really unique. Plus I ended up building a custom Centrafuse skin, designed around that unique screen shape, which basically made it a non-issue except for the occasional use of the windows desktop for maintenance/admin tasks.
I got them both on eBay. I'll be happy to give you any contact info I can dig up, but it might be a long shot since it was so long ago. A good alternative would probably be to find them at a salvage yard that will ship them on car-part.com
Short of finding a decent 6.5" touchscreen, I'm still happy with how I approached it. I really tried to find a 6.5-incher with no luck (at least not for something at a decent resolution)
Unfortunately yes, and I get the feeling I was incredibly lucky that the screen survived it. No cracked glass or funky display issues. I'm not sure there would have been any way to avoid the modification unless a different make/model (say a Xenarc, or a different Lilliput) just happened to fit perfectly.
The difference was at most 1 cm, so I suppose there might be a 7" screen out there somewhere that would fit, but short of ordering/trying multiple screens yourself, it would be a tough process.
Hope that helps! Let me know if you get started and have any questions mid-project!
My Worklog: 2008 Mini Cooper + Mac Mini
How is that mic working out for you? I'm trying to decide which one to get. Leaning towards the MT107A but $150 is a hard pill to swallow.
Nice install. I've got a mac mini in my Inifiniti. Makes for a versital carputer.
This is great, it looks fantastic. Where were you able to find just the enclosure for the nav spedo? I've been looking around but I'm having trouble finding one. Thanks!
