Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 50
Thread: All-in-one BlackBox install - Toyota Yaris 2007 sedan
  1. #21
    Dec 2007
    NY
    Sorry, wasn't thinking straight when I wrote that, the nano does not power the monitor. The monitor needs 8V. Since the USB DC-DC can output 24+V, cant' I split the out to feed both? Or will I need to go with the overkill? How much V does the nfano need? I've searched for specs and can't find it.
  2. #22
    Jun 2007
    Boston MA
    Quote Originally Posted by Champak View Post
    I'm pretty sure the monitor needs 12V. It also comes with a power filter inline with the cigarette adapter. I just cut off the power filter and connected it to the ACC line to power the monitor. DCDC-USB will give you stable 19V to power the nano.
  3. #23
    May 2010
    Australia
    Yeah what nivanov said.
    Nano needs 19V monitor needs 12V and comes with it's own 12V filter. Not sure it will survive cranking but will make sure it can handle car voltages.
    But no you can't split voltages you need a form of transformer or another method to change a voltage.
  4. #24
    Dec 2007
    NY
    Your right, I was looking at 8W thinking V. Why did you cut off the filter...couldn't you have cut after the filter…why did you find it unnecessary...isn't it supposed to filter out everything above 12V? How long have you been running it connected directly to the ACC line?
  5. #25
    May 2010
    Australia
    No he cut off before the filter to use it, just cut off the cigarette lighter plug as for a long term setup it will be unreliable.
    Using proper connections will be far better so you cut off the cigarette lighter plug rewire and then use the filter and plug on the other end to connect to the monitor.
  6. #26
    Maximum Bitrate kegobeer's Avatar
    Nov 2010
    Panama City Beach
    When I was using my DCDC-USB, I used a splitter on the molex plug that came off the motherboard and used one end to power the monitor and the other to power my sata hard drive. Other than supplying the monitor with filtered and regulated 12V, it also meant that the monitor was only powered while the computer was on.
    1999 Mercury Grand Marquis GS with: ASRock E350M1 w/4GB RAM, 80GB Intel SSD, Opus DCX3.120, Visteon HD Radio + HDR-USB, PL-18N wifi, OBDLink Scan Tool, BTA6210 BT, BU-353, Win 7 Ultimate, CF 4.0, Alpine MRP-F240 + MRP-T220, RF Punch 1572s, Kicker 8" Comp.
  7. #27
    Jun 2007
    Boston MA
    I've been running my monitor off ACC through the filter ever since I installed my car pc. If you think about it, it's not any different than running it from a cigarette adapter. It's been working fine so far.
    Unfortunately, those nettops don't have standard molex connectors coming off them - they are very self-contained (a good thing and a bad thing, when it comes to using them as car pc's).
  8. #28
    Dec 2007
    NY
    I'm almost certainly going with the DC-DC, but a couple questions.
    1/ Since the closest voltage output would either be either 18 or 24 volts, which should I set it to if the voltage required by the nano is 19V.
    2/ Back to if I can split the output between the nano and monitor. If I set the output to 18 or 24V to feed the nano, because I have the filter on the monitor, that means that I will be ok splitting the output to the monitor right?
  9. #29
    May 2010
    Australia
    18V might not be enough to power it and 24 might be enough to fry it.. Guess you just have to try probably starting with the lowest..
    As for the monitor it is designed to filter car voltages IE 10-14V again it might not like 18-24 as that is a fair bit higher than it would expect..
  10. #30
    Jun 2007
    Boston MA
    1. DCDC-USB can be tuned up to produce any voltage between 7V-34V (that might not be the exact range). While you can use jumpers to get one of the preset voltages, you can hook it up to a USB port and set any voltage you want. Same goes for timings, min. running voltages etc. I suggest you take a look at the software that comes with it. I have my nettop powered with 18V (it requires 19V) and it's running just fine.
    2. You don't need to use DCDC-USB for the monitor at all. Just hook it up to the ACC circuit. ACC provides unregulated 12V line and the filter takes care of stabilizing it. The filter is only capable of handling 11-14V or so, so you definitely don't want to power it with the 19V you are going to give to nano. DCDC-USB has an AUX port that provides unregulated input voltage, but whether the port is powered or not can be controlled from within DCDC-USB software. I had my monitor hooked up to that port. I set it to turn on the port 3 seconds after the ignition - after that, most of the fluctuations on ACC line are gone, so the monitor isn't going to be stressed too much. It's been working fine so far.
  1. Indonesian Newbie '06 Toyota Yaris... :)
    By jaesusu in forum Newbie
    Last Post: 10-07-2011, 07:32 PM
  2. 2008 Yaris 4 Door Sedan PC Install
    By rizaydog in forum Show off your project
    Last Post: 05-21-2009, 08:03 AM
  3. 2008 Yaris Sedan S VVTi
    By Urbanmindz in forum Show off your project
    Last Post: 07-20-2008, 03:43 PM
  4. Replies: 6
    Last Post: 03-18-2007, 11:51 AM
  5. My New 2007 Yaris
    By thoughtfix in forum General Hardware Discussion
    Last Post: 10-05-2006, 02:24 PM
