Page 1 of 5 12345 LastLast
Results 1 to 10 of 50
Thread: All-in-one BlackBox install - Toyota Yaris 2007 sedan
    Jun 2007
    Boston MA
    The project worklog is located here, however i've gone through too many hardware revisions so I decided to just create a new post, listing what I've done.
    Ingredients:
    Computer: MaxData QutePC-3020 (Atom 330 / ION) with 500gb hard drive, 2gb RAM and 802.11n wifi
    Power supply: DCDC-USB
    Monitor: Lilliput 669GL
    Amplifier: TDA7850 with Denoiser
    Enclosure: BlackBox v1
    Sound Card: GWC USB 5.1 Channel Audo Adapter AA1500
    USB Controlled Relay
    Array Microphone
    Bluetooth
    OBD2 Elmscan
    HD Radio with Mitch cables
    BU-353 GPS
    Screen installed, hooked up to the unit:
    Amp, prepped and ready:
    Everything wired together:
    Enclosure enclosed:
    Installed and operating:
    The reason I needed a USB Controlled Relay is to eliminated amplifier thump. I had to turn on the amp after the sound card is initialized. The way I did it was to wire the amp to the ACC circuit and also put the same ACC line to the Mute pin via USB Relay's NC connect. Basically, the amp turns on as soon as the car is on, but it starts off muted (so no pop). Once Windows boots up, I wrote a service that sends the On command to the relay, so NC connector becomes open, the Mute pin goes low and the amplifier unmutes.
    Feel free to ask questions!
    P.S. Many thanks to everyone that helped me along with this project, especially SoundMan - he's been following it from page 1 and offered a lot of valuable advice
    MySQL Error scott_fx's Avatar
    Dec 2004
    Los Angeles Ca
    great install! love how clean it is.
    what usb relay did you use?
    New System in progress:
    M10k
    Phaze TD1500 ~> Seas g18rnx/p
    Zapco Ref 500.1 ~ 12" tc-9
    Transflective Xenarc
    My Car Pc Install
    My Boat Pc worklog
    Jun 2007
    Boston MA
    Quote Originally Posted by scott_fx View Post
    This one
    Jul 2007
    Arkansas
    That is a very nice setup!
    Jun 2011
    Dublin, Ireland
    Very nice install!
    I'm embarrassed when I look at my rig (and my car) after I see all these installs!
    Feb 2011
    nice!
    Nice setup. Great looking design. Just one question. Hows that amp holding up? I have the same amp but don't k ow how it'll preform
    Jun 2007
    Boston MA
    It's been great so far.
    The only part that I'm not satisfied with is DCDC-USB. I'm really not sure why I was trying to save a few bucks on a project that cost more than a grand.
    Once in a while, when my car idles for a while and I shift to Drive, the computer shuts off. I think there's a dip in the voltage from the alternator and DCDC-USB can't handle it. If I had to do it all over again, I would have gone with Opus.
    Amplifier is working A-OK though!
    Oct 2007
    Nice & Clean Install.
    Car PC in Daihatsu Terios & Xenia, Honda Jazz & CR-V
    http://www.flickr.com/photos/tangkas_baru
    Oct 2011
    in the 4th picture, you have a cutout at the top of the black box that exposes the control pcb for the lcd screen? what is the cutout for? cooling?
    Jun 2007
    Boston MA
    Quote Originally Posted by droll View Post
    Blackbox doesn't officially suppot 669GL, because of how tall the PCB is. I had to cut away a part at the top and at the bottom for it to fit. It looks kinda ugly, but its behind the dash anyways. I think there's a version of 629 that has DVI, and that should fit without cutting the box. I went with 669GL because it has an HDMI port, and I was having troubles hooking up MiniTouch to the DVI-A port.
  1. Indonesian Newbie '06 Toyota Yaris... :)
    By jaesusu in forum Newbie
    Last Post: 10-07-2011, 06:32 PM
  2. 2008 Yaris 4 Door Sedan PC Install
    By rizaydog in forum Show off your project
    Last Post: 05-21-2009, 07:03 AM
  3. 2008 Yaris Sedan S VVTi
    By Urbanmindz in forum Show off your project
    Last Post: 07-20-2008, 02:43 PM
  4. Replies: 6
    Last Post: 03-18-2007, 10:51 AM
  5. My New 2007 Yaris
    By thoughtfix in forum General Hardware Discussion
    Last Post: 10-05-2006, 01:24 PM
