Project MotoBus 30' Bus, PC, Xbox, Stereo, Fiberglass, Ligiting and MORE!
So I've finally been able to get some progress started here on this project that has been titled the "Motobus" for a friend of mine, skipping all the vehicle technical nonsense its rough around the edges but should look great by the end of this project.
Heres the bus as I saw it first, being stared down by my beastlike chopper.
http://i102.photobucket.com/albums/m...otobus/001.jpg
Step one, deciding what all is going into this thing, when I was recruited to help on this I was basically given open creativity to do whatever I wanted, as long as it was functional and looked good, the only specifics were an overhead monitor, something in dash to control the multimedia, a 55" sony lcd tv, an xbox, and plenty of sound to pump throughout this bus.
We talked about some different ideas and concepts, myself being big into the mobile computing scene, I brought up the idea of a pc based system to control all of the audio/video/web/navigation and whatever else possible, and it was decided thats what it would be!
The interior was in for an overhaul, while the repairs to the floor were being welded I took the panels back to my laboratory, and by laboratory I mean my front porch and started planning and sketching out some different ideas and tried to figure out how to make everything work together.
http://i102.photobucket.com/albums/m...otobus/002.jpg
http://i102.photobucket.com/albums/m...otobus/003.jpg
I started first with the dash, I chose a Lilliput FA1011-NP/C/T 10" monitor with a capacitive touchscreen, the size is perfect for a dash application, it has HDMI, DVI, & VGA inputs, a resolution of # 1024 x 600, Brightness: 250cd/ and a Contrast ratio of 500:1 bought from the awesome folks over at mp3car store at
" http://store.mp3car.com/Lilliput_FA1..._p/mon-130.htm "
http://i102.photobucket.com/albums/m...otobus/004.jpg
This monitor was looking great, nice and new with that fresh smell of win still lingering prior to ripping open its carefully designed case to remove the stand and non essential parts for this particular application.
http://i102.photobucket.com/albums/m...otobus/006.jpg
http://i102.photobucket.com/albums/m...otobus/007.jpg
http://i102.photobucket.com/albums/m...otobus/008.jpg
I removed the button board and the buttons themselves, to relocate the board to the back of the monitors case and remove the button for power and the source select to tap into the circuit and relocate somewhere on the dash with a larger, more attractive push button for ease of use.
http://i102.photobucket.com/albums/m...otobus/010.jpg
http://i102.photobucket.com/albums/m...otobus/011.jpg
A handful of screws and a few pop tabs and the stand was off, and the case was open, I removed the back and the lcd assembly so I could trace the shape of the front of the monitor onto the dash panel to know exactly how much to trim out.
http://i102.photobucket.com/albums/m...otobus/009.jpg
http://i102.photobucket.com/albums/m...otobus/012.jpg
http://i102.photobucket.com/albums/m...otobus/013.jpg
http://i102.photobucket.com/albums/m...otobus/014.jpg
I used some of the scrap plastic left over from cutting out room for the monitor to serve as a backing for the large gaps to fill and to keep them as structurally sound as possible, being flexible and plastic and all.
http://i102.photobucket.com/albums/m...otobus/015.jpg
http://i102.photobucket.com/albums/m...otobus/016.jpg
http://i102.photobucket.com/albums/m...otobus/017.jpg
http://i102.photobucket.com/albums/m...otobus/018.jpg
http://i102.photobucket.com/albums/m...otobus/019.jpg
http://i102.photobucket.com/albums/m...otobus/020.jpg
http://i102.photobucket.com/albums/m...otobus/021.jpg
http://i102.photobucket.com/albums/m...otobus/022.jpg
After all the filling and sanding, and sanding.. and sanding was taken care of and I was happy with the look of the monitor, I reassembled all the pieces from the backside, I cut a hole out of the back cover of the monitor case to let me run the cable out that goes to the button board, and secured it to the back of the monitor case to keep it from flopping around, once the dash is finished, painted, back together and ready to go into the bus for good, is when I will tap into the button board and extend the connections out to new push buttons on the dash.
http://i102.photobucket.com/albums/m...otobus/023.jpg
http://i102.photobucket.com/albums/m...otobus/024.jpg
On a completely embarrassing side note, in the picture of the monitor up close the diagonal line in the corner is not a hair, or a smudge, but yes, unfortunately I did somehow manage to put a pressure crack into the corner of the touch overlay during testing/reassembly, being my first time experimenting with a glass overlay I didnt realize just how fragile these things are and serves as a reminder for everyone [mostly me lol] to take your time on these kinds of projects, pay close attention and dont rush things, LUCKILY the dudes at mp3car.com support was able to source me a replacement for just the overlay, added it to the website and I had waiting at my door in about a week, if annnyone else out there is into the carpc scene, yes you can find most things a couple of bucks cheaper on some other websites, but never have I had a company go out of there way to help me like that before, and I cant say enough good things about them.
I have a lot of pictures to organize and go through of everything I've done so far, the next update should be sometime tomorrow, and will be the progress of the fiberglass overhead panel for the 20" slave led monitor and 6.5 arc audio components.
Feedback, questions, opinions, suggestions, *coughdonationscough* is as always welcomed.
