Results 1 to 10 of 13
Thread: 350z carpc, autopc project
    Oct 2011
    Project took 5 days total and about 400 dollars worth of parts and tools.
    Finished project:
    How it began:
    I found a laptop on craigslist that had a cracked touch screen and broken outer shell for a hundred bucks. This gave me the idea to install it in my car to replace my 7 inch touch screen stereo. Here's what the laptop looked like.
    The first thing I had to do was to replace the touch screen. I found a vendor in china online and managed to pick it up for 150$. Part arrived in about a week. Install took about 20 min.
    My next task was to fabricate a bezel that I could mount the screen to in the center of the dash where the original radio had been. This is the original setup.
    As you can see the screen was very small and it was hard to navigate while driving.
    This is the factory bezel cut out with card paper cut and formed to the general shape I needed. I coated it with fiberglass resin to make it stiff.
    I then fiberglassed and applied bondo, then sanded the bezel.
    A couple more applications of bondo and some primer...
    J B welded 2 studs to the back of the bezel to hold the screen in.
    Gutted the passenger side of the dash to make room for the laptop...
    Test fit the bezel.
    I bought an Audigy 2 ZS for the laptop to run sound to the Bose amp which was very easy as I had an aftermarket adapter with 2 pair of RCA jacks and the zs 2 had 5.1 out, all I had to do was wire the Bose amp to acc. power and buy 2 adapters for headphone jack to RCA out so I would have front and back speakers. I ran the power to the laptop from the acc power for the radio and grounded it to the radio ground. I was blowing fuses so I had to buy an inverter to run the power supply through. I finish bondoed and sanded the bezel and covered it with carbon fiber print pleather I bought from a marine upholstery shop for 5 bucks. This is the finished product so far.
    This was my first time dealing with fiberglass, bondo, and upholstery, so I learned alot and had fun doing it. I used this forum for reference and am thankful you guys are here. My next project is to remove the pod gauges from the center console bezel and mold it smooth into the top of the screen for a more curvy look. I will then replace those gauges with a dash commander lcd screen hooked to the laptop, which will also replace my speedo cluster.
    Oct 2011
    Completed
    Oct 2011
    reserved 2
    Jul 2011
    Is that a Dell Latitude D6410? Where can I get the touch screen for it? Plz PM me, thx
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    41
    Very nice work. A screen that big in an 350 must light up the entire cabin at night
    Live mp3Car Facebook Chat
    Oct 2011
    Quote Originally Posted by Sonicxtacy02 View Post
    I run the screen at 100% brightness during the day and 5-10% at night. This car isn't quite as big as a Altima but that doesn't make to much of a difference because the screen is dimmed at night. I'm hoping to make a program or batch file to automatically dim the screen at a certain time of day.
    Woodbridge, VA
    Blog Entries
    41
    Are you running a front end? My Auto Dimmer Control plugin for CF will do that. You can do it with RR without a plugin at all.
    Oct 2011
    Not running a front end atm just running windows 7 and I am using winamp for playback of music. Still debating on running a front end or not. I think I can get windows to do all the things I need it to, but I have seen some really nice front ends.
    Jan 2008
    looks really good!
    My 2001 Mitsubishi Eclipse GT:
    "The Project That Never Ends"
    more projects then time!
    Led Skyline Tail Lights--100%
    High Power Led Reverse Lights--100%
    Led third brake light--100%
    Led front turn signals--0%
    HID retro--100%
    Oct 2011
    Finally finished!
    Bezel was 300 dollars from a custom fabricator. He did a great job well past my expectations.
    His info is:
    Alvin Lawrence
    5293 tower way
    Sanford Fl 32773
    340-513-1290
    autofanatik@hotmail.com
    Tell him I sent ya!
  1. auto skin and auto gamma feature idea
    By kuo in forum Road Runner
    Last Post: 09-22-2009, 11:35 AM
  2. 04 350z Convertible "small time project".
    By kermityfrog in forum Show off your project
    Last Post: 02-17-2007, 06:30 PM
  3. Replies: 20
    Last Post: 12-10-2006, 10:11 AM
  4. New carputer project started - 350z (56k beware)
    By StutterinJ in forum Fabrication
    Last Post: 05-22-2005, 07:45 AM
