Results 21 to 30 of 39
Thread: 2005 Dodge Magnum _ Galaxy Tab install
  1. #21
    Mar 2012
    Arezzo, Tuscany, Italy
    I think he can't get access to inner dash by detaching the dock from the magnet, simply because the right side (the original bottom side of the multimedia dock) has no enough space to 'swing' and open.
    Since I want to mantain access to the inside of the dash, I am searching on of those special hinges used in kitchen furniture,... sorry I am unable to explain in english (I'm italian) how it's made and how it works, but I want to use a hinge that can extend and can completely open the dash.
    what you mean with "it would pop up from being flush"? Again, my fault that can't understand well english language
    what is "flush"?
    Edit: I mean a hinge with a mechanism like this:
  2. #22
    Low Bitrate Lankin's Avatar
    Jun 2009
    hmmm what is flush?
    by flush I mean the screen is flat with the dash. One smooth plane. When the latch is pushed in and then pops out, the tablet will be out at an angle. The left side will be further away from the dash, and the right side will remain in place by the hinge.
    The latch is activated by the push. granted we "touch" a touch screen, but if you "touch" too hard it would become a "push" and make the left side of the tablet pop out.
    I'm sure when the OP gets back to this thread he can confirm or deny if this happens.
  3. #23
    Mar 2012
    understood!
    for preventing this, shiltz made a small 'lip' at the bottom left that, combined with the bottom of the dock, keep it in place.
    I think he made a simple and very smart install! Hope I am able to do the same..
  4. #24
    Feb 2012
    Quick noob question. So you're head unit reads the audio out from the dock? I'm guessing via usb, or does the dock have a 3.5mm ?
  5. #25
    Mar 2012
    the dock has 3.5mm audio out, plus mini-hdmi out and samsung connector to charge the tab.
    here you can see it better:
  6. #26
    Constant Bitrate shiltz's Avatar
    Dec 2004
    Massachusetts
    Damn, sorry, been crazy busy the last few weeks, moving etc and just got back to this thread now.
    Quote Originally Posted by papinist View Post
    how many layer of fiberglass have you used?
    I believe it was 3 layers I used before it seemed sturdy enough.
    Quote Originally Posted by Lankin View Post
    That latching mechanism is super innovative. Great job!
    One question though: Do you ever find yourself accidentally pushing the screen to hard and causing the latch to "pop out" when you remove your finger?
    Nope, it take much more force to pop the latch out than what I use to touch the screen, so you really have to intentionally be trying to make it pop out for that to happen.
    understood!
    Yup, the small tab on the bottom left plus the dock base on the right hold the tablet in place in the dock itself so it can't come out without first being slid to the left. And also she, not he
    2005 Dodge Magnum RT, Samsung Galaxy Tab install
  7. #27
    Mar 2012
    oops... she!
    However, I am in the final hardqare step and starting to play with software. I got PowerAMP and Tasker, and I'm trying to make some profiles/tasks.
    How have you set this up?
  8. #28
    Dec 2004
    Massachusetts
    The way I have it setup for profiles in Tasker is that I have 2 different profiles.
    Profile 1:
    State: Power Any (the state for docked didn't work sadly)
    Actions:
    1.) Widgetlocker unlock (that's the custom lock screen app I use)
    2.) Load App: PowerAMP
    3.) Media Control: Cmd Toggle Pause
    So that unlocks the tablet, launches into PowerAMP and unpauses.
    Profile 2:
    State: Not Power Any
    Actions:
    1.) Media control: Cmd pause
    2.) Go home (this is because I have Poweramp set to never turn off the screen if it's running and one time I accidentaly threw the tablet without hitting the power button so it killed the battery, when it goes to home it turns off after whatever time frame for that you have set in Android)
    I also have a speedometer program I've tried to add to that, but it never seems to kill the app properly and it slowly runs down the battery when it's still running :/
  9. #29
    Mar 2012
    Thanks, I'm trying to understand the full potetinal of tasker with its user guide but it took me a lot of time.
    I tried yesterday with a 'docked' state ad it seems to work, but I want to make it more specific: docked and powered (I only have power with key turned on), but I must care of power goes off during engine start.
    Something like:
    - tab docked and car off: nothing happens
    - turn key: power reach tab (and it is docked) but it waits to start
    - ignition: power goes temporarily off - tab waiting
    - car on: tab docked and power on - tab start
    Since we used a home dock, I'll say tasker: "if docked (any) -> go to car mode"
    car mode should set several parameters for our use.
    I'll investigate
  10. #30
    Dec 2004
    Massachusetts
    Yeah, it really does have a lot of potential, I just kind of poked around the app and figured it out myself though instead of actually reading the user guide
    Weird, I wonder why yours works with the docked state while mine didn't, when I set the dock state and docked it nothing at all happened, that's the only reason why I used the Power any state, but that has one drawback, if I plug in the tablet at home to charge it performs the same actions, but since I don't actually do that that often since it's mainly being charged in the car I just have dealt wit it.
  1. 2005 Dodge Ram 3500 Truckputer Install w/ 15" Touchscreen
    By IssaquahWA1979 in forum Worklogs
    Last Post: 03-31-2010, 03:14 PM
  2. HP Slimline in a Dodge Magnum
    By jeeves720 in forum Newbie
    Last Post: 02-23-2009, 04:03 PM
  3. 2005 Dodge Magnum RT Carputer
    By shiltz in forum Worklogs
    Last Post: 11-12-2007, 12:45 PM
  4. 2005 Dodge Magnum Mac Mini CarPC [LINK]
    By bEE2643 in forum Show off your project
    Last Post: 05-16-2006, 02:59 PM
  5. 2005 Dodge Magnum SXT PC *appearing at MML '05*
    By bellerophon in forum Show off your project
    Last Post: 06-26-2005, 11:30 AM
