Results 21 to 30 of 39
Thread: 2010 Toyota Corolla S - Custom CarPC Build (Lots of photos)
  1. #21
    May 2010
    Nice work! I've got a 9th Gen Corolla that I'll put up here soon. I did things a little differently though, it'll be fun to compare.
  2. #22
    Jan 2012
    Quote Originally Posted by bambam View Post
    Very nice setup!
    I have been looking at the Directed AM/FM/HD tuner because I need my am/fm channels. How do you like the unit? Did it integrate well with Centrafuse and do you think it sounds as good as a headunit does?
    Appreciate it...your opinion will probably sway me one way or the other!
    Honestly, quite disappointed in the Directed HD Tuner... It integrates just fine with CF, but the reception is terrible (and yes the power antenna wire is connected). The way it goes in/out of HD to normal FM drives me nuts - I now have the Pandora plugin for CF and with my Verizon 4G MiFi that's pretty much all I use now. Kinda regret buying it... If you can live without FM/AM I kinda don't see the point in it. I tried searching for FM boosters but they all seem to be junk. That's just my 2 cents though... If you really want FM I'd look elsewhere.
  3. #23
    Jan 2012
    Quote Originally Posted by Emeka View Post
    Cool, I'd be interested to see it. I'm probably going to be changing some things around with my setup in the near future. Since I've had it for a few months already there are a few things I'd like to improve upon.
  4. #24
    Variable Bitrate bambam's Avatar
    Dec 2004
    Upstate New York
    Quote Originally Posted by XAndyJX View Post
    Really appreciate the reply! I won't even consider this now....thanks again!
    "Imagination is more important than knowledge." -AE
  5. #25
    Jan 2012
    GPS Receiver
    The USB GPS receiver I originally had wasn't quite living up to expectations (satellite acquisition took an eternity). I replaced that one with a Columbus V-800 (5Hz update is what sold me) - actually worse than my other one was After tinkering with the firmware on it and reflashing this, and changing that - let's just say it's decoration at the moment... I broke down and decided to buy the new GlobalSat BU-353-S4 with the SiRF Star IV chipset (got it from MP3Car's Amazon store). I read some good things about that chipset, hopefully it works well with iGuidance 2011. I'll comment on that when it arrives - as long as it takes less than 5min to find 1 satellite I'll be happy
  6. #26
    Dec 2005
    Raleigh, NC
    Where are you placing the GPS module? I have horrible GPS reception inside (locality to windows made no difference) of my car but when the module is placed outside it works perfectly fine.It worked fine in my previous car, Saturn Ion, but not in my current car, Honda Accord.
    "You're just about as useless as JPEGs to Helen Keller" - Wierd Al
  7. #27
    Jan 2012
    I am placing it inside my car on top of the dash... I know it's not the optimal location but I've had a few GPS receivers in the past that worked just fine inside the car. Also, I don't believe that these other GPS units were waterproof. I will try this new one out any hopefully it works well - if not, I know that this one is waterproof and I'll find a good spot on the outside of the car if I have to.
  8. #28
    Apr 2012
    what on/off configuration did you use on your M4-ATX?
  9. #29
    Mar 2012
    This is great, I was looking for a cheap alternative to boost the Volume.
    The Clarion seems the way to go.
  10. #30
    Jan 2012
    Quote Originally Posted by Thomas Fleming View Post
    Do you mean for the dip switch settings? If so, I just used the factory recommended P1 setting (5sec on delay/1min AutoLatch/60sec 5VSB Hard-off). Works out well for me...
  1. TFCommanderBob's 2010 Corolla S CarPC
    By TFCommanderBob in forum Worklogs
    Last Post: 07-17-2010, 09:00 AM
  2. White Toyota corolla 2002 carpc
    By ravid in forum Show off your project
    Last Post: 12-02-2009, 05:10 AM
  3. Toyota Corolla 2004 CarPc (European Edition)
    By NyO in forum Show off your project
    Last Post: 05-13-2007, 04:48 PM
Tags for this Thread
