Page 1 of 4 1234 LastLast
Results 1 to 10 of 39
Thread: 2010 Toyota Corolla S - Custom CarPC Build (Lots of photos)
    Jan 2012
    Cool 2010 Toyota Corolla S - Custom CarPC Build (Lots of photos)
    06/01/12 - Dual Screen upgrade on pg.4
    This is my CarPC project - I will be installing it in my 2010 Toyota Corolla S. I have quite a few pictures of the build and I finally received the last of the parts that I needed to complete it. I will be installing it this weekend hopefully. I have just about 2 weeks into this project, I lost count of the hours and $$$ that it took to design and build it. Lots of custom fabrication work on my end. Have a look at my progress so far
    The barebones of the build consists of a ASUS F1A75-1 Deluxe Motherboard, AMD A8 3870 APU, and 8GB of DDR3 1600 RAM.
    Bundled with the motherboard was this rather convenient wireless remote/keyboard that seems to be perfect for the CarPC
    This is the back of it
    The in-dash monitor is a modified Lilliput 669GL-70NP/C/T with the Resistive touch replaced with a Multi-Touch Capacitive panel - it's VERY nice!
    Monitor assembled in the Double-DIN mounting bracket
    I have a 4-ch JBL amp and a Monoblock Kenwood amp to power my speakers - I will be using this Clarion EQ/Line Driver to up the sound cards output to 7Vrms to reduce any noise and lower the gain on the amps
    I didn't want to use any pre-made cases, and most mini-itx cases wouldn't work with what I wanted anyhow. I decided to install everything in my Glovebox (my car has 2 compartments so I didn't mind sacrificing the lower one). I needed to level out the base of it and make a durable platform to start with. I used 22ga steel as the mounting plate for the components - contoured to the inside of the Glovebox.
    I needed to make my own motherboard tray, so I used 22ga aluminum for that.
    Pattern is stenciled out, stand-offs are in place, and it's ready to be cut out.
    This was just a test fit to make sure everything was in check
    I will be using a 250W (300W Peak) Intelligent Automotive ATX PSU, a Sony Blu-Ray Slim Slot-Load Optical drive, and a Samsung 128GB SATA3 SSD (over 500MB/s R/W)
    Standard Metra mounting bracket I modified to fit the Blu-ray drive under the monitor - just a test fit
    I will be using 2 60mm High RPM fans (1-in/1-out) to keep everything happy and cool - stencils I used for the cutouts
    The APU is an AMD 3870 3GHz Quad-Core (I OC'd it to 3.3GHz)
    Random install picture
    I cleaned off the factory Thermal Paste and used Arctic Silver Thermal Paste
    It's a light coating even though it doesn't look like it
    8GB of DDR3 1600 Corsair RAM
    Motherboard assembled
    The ASUS F1A75-I Deluxe motherboard is VERY feature rich - SATA3, USB 3.0, UEFI BIOS, WiFi, Bluetooth, HDMI, list goes on. *On a side note, even though the onboard bluetooth supports everything for a mobile phone it is not recognized by Centrafuse unfortunately
    This is the Metra kit before my Carbon Fiber overlay
    This is it after, but pre-clearcoat
    Another test fit before I cleared it to make sure the added thickness didn't affect anything
    Clear coated and fully assembled!
    This was the first power-up - Installing UEFI Windows 7 x64
    Overview picture of the system
    Windows WEI Scores - The Samsung SSD is maxed out at 7.9 - From cold boot to fully ready in less than 10sec - no joke!
    Final Product - WiFi antennas down
    Final Product - WiFi antennas up. I know it's not the most pleasing eye-candy to look at, but it's fast, it works, and hardly anyone is going to see it in the Glovebox anyhow.
    Rest of the parts came today. Sirf III GPS antenna with modified Baud Rate, Directed AM/FM/HD tuner with USB interface kit, Joycon EXR Steering Wheel Interface, Phoenix Audio MT107A Echo-Canceling Microphone, and Centrafuse 4.0 with Navigation.
    I will add more pictures of the actual installation this weekend!
    UPDATE!! - Install Completed
    Ok, after about 7-8hrs of installation time it's finally installed. I ran into quite a few issues with fitment (mainly the Glovebox due to the external fans) - but it wasn't terrible. I ran 8ga wire to the Power Supply since it can draw upwards of 25A at peak power (I know 8ga is tad overkill for 25A but I had it laying around). It's fast, runs great, and one of a kind
    8ga power wire (this is on top of the 4ga I have running to my amps - tight fit)
    Glovebox installed
    I noticed this space here was easily accessible and I was able to fit the mics perfectly
    The monitor and blu-ray bracket installed
    Re-installing Windows after I accidently crashed the damn thing
    Everything buttoned up and me checking my e-mail
    Constant Bitrate 4ofakind's Avatar
    Jul 2009
    Looks great!
    A couple of things: I have an ASUS board as well, albeit an older model. I ordered a BT dongle from ebay, took it apart and the receiver on my board apart, then unsoldered the one from the board and replaced it with the one from ebay. RR sees it fine; CF should as well especially if you order one from their approved HW list.
    Second, could you report back with how well the Phoenix Audio unit works? That is next on my purchase list.
    Mal
    Vehicle: [100%] 1995 C 1500 ECLB
    Gear: [90%]
    Build: [80%] PC & Chassis, Worklog
    Jan 2012
    Thanks, I ordered an approved BT Dongle and should hopefully be here today. That's an interesting suggestion to replace the onboard BT board! I'll look into that... As soon as I get everything buttoned up I'll be sure to post with feedback on how it turns out. For the cost of that Phoenix Audio microphone it better be worth it :\
    Dec 2006
    India
    Good Install log!
    Which multi-touch panel did you use?
    Jan 2012
    Hard to say as I ordered it that way with the capacitive swap already done. From what little information I was able to gather possibly off of some Lenovo device - can't say for sure though. Works really well and no drivers needed for Windows 7.
    Jul 2009
    Quote Originally Posted by XAndyJX View Post
    Patiently waiting your thoughts on the PA mic. In the meantime, here is the link to another member who had an ASUS board and how we replaced the BT receiver. BT Swap Scroll down to post #25 for my crappy pics and details.
    Mal
    Gear: [90%]
    Variable Bitrate chris350's Avatar
    Aug 2007
    Queens, NYC
    nice... i have a 2011 corolla... got everything from my other car..just got the do the swap... good work
    CarPc
    Project "Driver"
    Planning [99.9%]
    Parts Collected [98.5%]
    Installation & Fabrication [98%]
    Total Completion Level [96.9 %]
    http://www.mp3car.com/vbulletin/work...ct-driver.html
    Jan 2012
    Ok, I updated the first post with the final install pictures... Everything is working great! As for the P.A. Mic set - it works really well no one can hear anything else other than me talking no matter how loud I crank up the volume. I really don't have any other echo-canceling mics to compare it to, but for the money it does it's job.
    Jul 2009
    Looks great; like it came that way from the factory! Also its good to know the PA Mic works so well, especially at such a long low distance. Thanks for your review. I will get one ASAP.
    What did you figure out for your BT?
    Mal
    Gear: [90%]
    May 2010
    Moncton, New Brunswick, Canada
    Mt107a
    How is the MT107A working where the microphones are installed below the steering wheel?
    I have a 2009 Corolla S, have the MT107A, but will not be installing until spring when warmer, was going to run the cable behind a A pillar trim on passanger side, between the front windsheild and passanger door, under the headlineer to the map lamp and install where there are two vents on each side.
  1. TFCommanderBob's 2010 Corolla S CarPC
    By TFCommanderBob in forum Worklogs
    Last Post: 07-17-2010, 10:00 AM
  2. White Toyota corolla 2002 carpc
    By ravid in forum Show off your project
    Last Post: 12-02-2009, 06:10 AM
  3. Toyota Corolla 2004 CarPc (European Edition)
    By NyO in forum Show off your project
    Last Post: 05-13-2007, 05:48 PM
Tags for this Thread
