Page 2 of 10 FirstFirst 12345678910 LastLast
Results 11 to 20 of 92
Like Tree2Likes
Thread: 2006 Alfa Romeo GT - Removable In-Dash Android Tablet install (Samsung Galaxy Tab 7")
  1. #11
    Mar 2012
    Arezzo, Tuscany, Italy
    today I've received two other items:
    car charger with cigarette lighter plug
    Name:  Autoradio Galaxy Tab 035 (Custom).jpg
    it has an extra usb power port I does not need of, but who cares
    male ISO connector
    Name:  Autoradio Galaxy Tab 034 (Custom).jpg
    added to shopping list
  2. #12
    Mar 2012
    ok second attempt with fiberglass:
    Name:  Autoradio Galaxy Tab 036 (Custom).jpg
    this time was almost perfect!
    Name:  Autoradio Galaxy Tab 038 (Custom).jpg
    Name:  Autoradio Galaxy Tab 043 (Custom).jpg
    BUT...
    since I used too many layer of plastic to protect the tab, it can't fit perfectly in the dock and the extension was not straight
    Name:  Autoradio Galaxy Tab 046 (Custom).jpg
    so I removed it and will try again
    Name:  Autoradio Galaxy Tab 047 (Custom).jpg
    I'm sure version 3 will be the good one
  3. #13
    Mar 2012
    version 3: perfect! (at last...)
    this time I wrapped the tab in only two layer of plastic
    Name:  Autoradio Galaxy Tab 048 (Custom).jpg
    Name:  Autoradio Galaxy Tab 049 (Custom).jpg
    and then, with a perfect mix of resin and hardener I fiberglassed it
    The wood piece keeps the front lip in place)
    Name:  Autoradio Galaxy Tab 050 (Custom).jpg
    It's a very tight fit, but it's ok
    Name:  Autoradio Galaxy Tab 051 (Custom).jpg
    I bought a small can of "stucco metallico" (don't know the exact translation, maybe "filler"?) and covered the fiberglass
    Name:  Autoradio Galaxy Tab 055 (Custom).jpg
    Name:  Autoradio Galaxy Tab 056 (Custom).jpg
    Name:  Autoradio Galaxy Tab 057 (Custom).jpg
    Now, I have to sandpaper it to smooth and make it clean.
    And since I think I use too much filler, I have a lot of sanding to do....
  4. #14
    May 2009
    Ladispoli, ROMA
    I'm sure you'll make a good work.. we're waiting for new pictures...
    Forza che ce la fai...
  5. #15
    Constant Bitrate shiltz's Avatar
    Dec 2004
    Massachusetts
    Very nice, you're a lot better at documenting the work in progress than I am, I just kind of made mine then though shoot, I didn't take any pic while I was making it.
    2005 Dodge Magnum RT, Samsung Galaxy Tab install
  6. #16
    Mar 2012
    Thanks, I'm doing so many photos because it could be of help if someone wants to try (and maybe made better work!). I have done other steps, later I'll post progress!
  7. #17
    Mar 2012
    Quote Originally Posted by Larry49 View Post
    Grazie Larry
    I've just done a little rework in the shopping list post with a list of steps I'll try to follow in this project.
    Finally, after a lot of work I have completed the extended dock.
    Pics following!
    after lots of sanding..
    Name:  Autoradio Galaxy Tab 058 (Custom).jpg
    Name:  Autoradio Galaxy Tab 059 (Custom).jpg
    and painting, here is the result!
    Name:  Autoradio Galaxy Tab 061 (Custom).jpg
    It has some small pits and scratches, but not so much.. the digital camera flash makes it seems ugly but it is not
    Name:  Autoradio Galaxy Tab 062 (Custom).jpg
    Name:  Autoradio Galaxy Tab 063 (Custom).jpg
    Name:  Autoradio Galaxy Tab 066 (Custom).jpg
    most important of all, I saved the samsung logo
    Name:  Autoradio Galaxy Tab 068 (Custom).jpg
    Name:  Autoradio Galaxy Tab 069 (Custom).jpg
    Name:  Autoradio Galaxy Tab 070 (Custom).jpg
    Name:  Autoradio Galaxy Tab 073 (Custom).jpg
    this time the tab fits correctly
    Name:  Autoradio Galaxy Tab 074 (Custom).jpg
    this is the hole for mic to capture voice
    Name:  Autoradio Galaxy Tab 078 (Custom).jpg
    this is not for digital camera, but is needed for grab the tab and extract from the dock
    Name:  Autoradio Galaxy Tab 079 (Custom).jpg
    Name:  Autoradio Galaxy Tab 080 (Custom).jpg
    Name:  Autoradio Galaxy Tab 081 (Custom).jpg
    Name:  Autoradio Galaxy Tab 083 (Custom).jpg
    Name:  Autoradio Galaxy Tab 086 (Custom).jpg
    Now Step 1 is officially over!
  8. #18
    Mar 2012
    Little update, I have started STEP 2: MAKING AUDIO/POWER CONNECTIONS and I'm having problems with the usual audio noise coming out from the amplifier. It is generated by the dock when inserting both audio and power cable. I used very cheap audio cables I have laying around, but I have purchased some quality cables from ebay and waiting for that to arrive. I also bought one car audio noise filter to try all possible things.
    Today I will post some pics of the amplifier and initial audio setup.
  9. #19
    Low Bitrate aziodale's Avatar
    Jun 2009
    Italy Sicily Palermo
    check the ground ;-)
  10. #20
    Mar 2012
    Yes I've checked it, now I use ground from the pre-existing radio system but even connecting to a big screw under the dash nothing changes. I hope that quality wires and noise filter will solve that.
  1. Alfa Romeo Specific PID
    By fanl in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 12-18-2011, 08:15 AM
  2. Android tablet hovering over the Dash install.
    By RipplingHurst in forum Android Tablet
    Last Post: 10-31-2011, 05:49 PM
  3. Samsung Galaxy Tab 7.4 x 4.7in tablet
    By RipplingHurst in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 12-26-2010, 10:54 PM
  4. Alfa Romeo 145 Boxer CPC
    By weirdmeister in forum Show off your project
    Last Post: 04-09-2008, 10:24 PM
  5. 5.6" Screen in Alfa Romeo 156 Dash (BIG IMAGES)
    By iansalfaproject in forum Fabrication
    Last Post: 03-16-2005, 11:52 AM
