Results 1 to 3 of 3
Thread: CarPC and Head unit intigration on my 2011 Toyota Prius
    Jan 2012
    New York
    Hi folks.
    thanks to all the amazing projects i saw here i atempted to install a carPC in my 2011 Prius.
    I put the monitor in the top glove box and the computer in the lower glove box.
    I considered buying a carputer but the price range was coming to about 400-to 500 (for a good one). So then I looked into making my own which is a better option but would take up extra time and still cost like 300 or so.
    So I decided to go with a nettop ( for about $150). Not the best choice for a carputer because it does not have a regular ATX motherboard and not very rugged but I only need it for internet access.
    Since the nettop does not have a motherboard power switch header that would normally connect to the push-button on the front of a personal computer case. I solder couple of wires to the on/off button which I used to place a small push button under the center consol.
Size:  62.9 KBName:  IMAG0339.jpg
    My car does not have a conventional starter, there is no high amp spikes, so i dont need a DC to DC regulator.
    I taped +12 from the lighter socket and ground near the bottom of the glove box. and installed a small push button to turn on the computer.
Size:  68.6 KBName:  IMG_2388.jpg
Size:  86.1 KBName:  IMG_2389.jpg
Size:  85.4 KBName:  IMG_2397.jpg
    I Installed the nettop holder in the lower glove box and made some vent holes.
Size:  58.4 KBName:  IMG_2390.jpg
    Found some space behind the lower glove box where i stuffed the computer power brick and the wires for the LCD touchscreen
Size:  97.5 KBName:  IMG_2399.jpg
    I removed the stock CD player because it did not have and aux input and bought a cheap genaric chinese Headunit off of ebay. I output the audio and video from the CarPC to the new head unit.
Size:  69.1 KBName:  IMAG0417.jpg
Size:  67.7 KBName:  IMG_2401.jpg
    Routed the wires and hooked up the CarPC.
    Problem!! the 7" touchscreen was too big to fit in the upper glove box so I ended up cutting the bottom off, squished the electronics together and repositioned the buttons.
Size:  91.0 KBName:  IMG_2362.jpg
Size:  107.1 KBName:  IMG_2365.jpg
Size:  121.6 KBName:  IMG_2368.jpg
Size:  88.2 KBName:  IMG_2370.jpg
    After hacking up the monitor it still did not fit the glove box so i had to cut up the glove box to make it fit.
Size:  72.1 KBName:  IMG_2372.jpg
Size:  53.0 KBName:  IMG_2384.jpg
Size:  61.4 KBName:  IMG_2380.jpg
Size:  78.1 KBName:  IMG_2385.jpg
    put everything to gether .
Size:  82.1 KBName:  IMG_2403.jpg
    Finally testing if it works and yes everything is up and running. and when the glove box is closed no one knows there is a computer there .
    Aug 2004
    You just ruined your Prius.
    Mar 2008
    monitor in the glove box?
  1. Replies: 5
    Last Post: 08-16-2011, 11:03 AM
  2. Parrot's New Android Head Unit - CES 2011
    By Jensen2000 in forum Mp3Car Blog Talk
    Last Post: 04-06-2011, 12:05 PM
  3. Pionner head unit, xm and soon to me carpc help
    By supergelf in forum Car Audio
    Last Post: 01-21-2005, 09:24 AM
  4. toyota prius help
    By studmonk3y in forum Newbie
    Last Post: 02-09-2004, 11:21 PM
Tags for this Thread
