Looks really good. Could you describe the front end/app you're using? I recognize Google Music as the music player, but nothing else.
after 3 years i upgrade carpc system with a Huawei Mediapad 7"
of the previous configuration has remained only the carnetix p2140 appropriately reconfigured;
i only changed the center console to add tablet
this is the preliminary test
tablet specs:
Operating System
Android ICS
CPU
1.2GHz Dual Core
Display
7'' LCD WXGA (1280x800 IPS)
Camera resolution
5 Mega-pixels AF camera & 1.3 Mega-pixels camera
Capacity
8GB
Extended
up to 32GB micro SD
Connectivity
Wi-Fi 802.11b / 802.11g / 802.11n
Bluetooth 2.1
Headphone
3.5mm stereo audio jack, Stereo speaker
GPS/A-GPS
Accelerometer sensor
Ambient light sensor
Compass
Battery Type
Li-Polymer Capacity 4100mAh
positive side
global cost
velocity
simplified installation
monitor resolution and quality
boot velocity
integration without particular frontend
no crash or operative system error
no drivers to install
minimal configuration
negative side
rear cam; temporarily lost functionality (I have an idea :-))
The tablet is powered by a Carnetix P2140 dual channel
5v for Tablet and usb hub
12v for silent 92cm fan behind tablet inside enclosure
and programmed for send and cut dc with no delay
for OBDII i use a modified Bluetooth adapter
Software:
widget auto pro as launcher
WeFi Pro - automatic and seamless Wi-Fi connectivity whenever you are!
Torque for OBDII data
Tasker for automations
- on (Enable the system, wireless connections etc)
- off (Go in Stand by mode, Aereomode, pause music etc)
- Say if wifi connection is on or lost
- Say every 15 minutes what time is it
Central consolle command interface fabbrication
Powered +5v HUB USB with velcro fix
OBDII bluetooth adapter with 12v under key permanently connected
no danger of battery drain ;-)
microphone location
i use widget auto pro as launcher that is the only solution similar to centrafuse;
is a widget inserted in th home of ICS very simply to use
need moar pics!! looks good dude
Huawei Mediapad 7" (1280x800 IPS) | Carnetix P2140
My last update http://www.mp3car.com/show-off-your-...t-version.html
Central consolle command interface fabbrication photo added ;-)
nice, I'm curious but how will you integrate the buttons you added with the tablet?
natively mapped keys perform the same functions as a multimedia keyboard with Microsoft Windows;
unfortunately in Android is not possible to map keys as in Centrafuse (or at least I do not know), so I chose the media keys that had direct effect;
The LED is powered from the 5v USB port and serves as a warning to learn the status of the power supply;
the adapter is connected via USB HUB
Where did you buy that tablet from, looking at doing a similar install for my brother.
it's not difficult to find
http://www.huaweidevice.com/worldwid...yId=5011&tab=0
