Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: 1990 Celica GT - New Install
  1. #11
    Low Bitrate stkdidy ntshidy's Avatar
    Jul 2003
    california
    im thinkin it will be 400ish for a screen, 300ish for a basic computer setup, 100ish for a power inverter, 100ish for a good smoke machine, and less than 100 for supplies/wiring/brackets/etc ...i hope i hope i hope
    at first i thought, "gee, wouldn't it be a cool safety device to hook a smoke machine into my alarm, that way if someone pulled a gun on me and made me give up my keys i could press a lil button that would start the smoke machine 5 min later, and fill the car with smoke so that it couldn't be driven, even with the windows down." but then i got a better idea, "wow it would look cool to have smoke pouring from under my car along with the underbody neon lights that are already down there...that would be a cool thingy to show off"
    there are more ideas of course, and i like em all cuz ive never seen a smoke machine in a daily driven car, or any car for that matter.
    2005 Mustang GT:
    12w7...arc audio kar1000.2t...jl 300/4 pushng focal 165k2p...pioneer premier deh-880prs...tm-701l...audiocontrol eqs
    want: my stereo actually IN the car
  2. #12
    Jun 2003
    Chicago
    HereFishyFishy
    nice job on the zenarc install. I have a 93 celica and the same screen...you've given me some ideas for mounting the screen. Do you have any issues with the viewing angle of the screen? Did you modify the radio bezel (I don't what it's called..the black plastic piece the goes around the radio from the shifter to the bottom of the vents).
  3. #13
    May 2003
    Charleston, SC
    Nah...the viewing angle is great at night & most times during the day. The only time I have a problem is when the sun is right on it or when there's a bad glare...then you have to lean over and down a bit to be able to read stuff, you can still see where the icons (bigger stuff) are from a driving position though. And when watching video's it's better to be centered or reclined so you don't get that bleed out stuff because of the angle.
    The Bezel is still how it was stock...I didn't want to modify anything until I got a new one from the junkyard to play around with. Those clips basically just hug the back of the bezel above the clips that hold the bezel in...you'll see what I'm talking about if you look at the pics up there! The screen is almost the perfect height for this! I just had to chop some of my clips down partially so they wouldn't hit the bezel's clips when I folded them over.
    I wish you luck on your installation. It was a lot easier then I thought to mount the screen, but I'm also not going to keep it like that forever I don't think. I want to go for a flush install, but that's coming much later as school is about to start up again. A word of advice: I have an 800w RMS AMP & the 150w opus installed in my car & it ran great for a few weeks, but yesterday I did a lot of idling while playing around & when I started my car up last night to show the system to my friend's dad the PC wouldn't come on. The Opus volt. reg. kicked in because my battery was down under 12v so it looks like an alternator upgrade might be needed. Or maybe I need a new battery since mine is a little old.
    Phil
    Car: 1990 White Toyota Celica GT Hatchback, Custom CAI w/ K&N filter, AutoVation Celica Racing Pedals
    PC: Athlon TB 1000, Opus DC-DC Power Supply, 40GB, 8x DVD, 256MB RAM, FM/TV Tuner, 5.1 Audio, 7" Xenarc Touchscreen, GPS w/ CoPilot 2003, 802.11g wireless NIC
    System: Hifonics ZX8000 5ch amp, Sony XS-L101P5 10" Sub, Q-Logic .6 cu ft sealed enclosure
    Coming Soon: Clean install in custom hatch enclosure, USB 2.0 or Firewire hub in front console, Slot DVD in front console, VHF/UHF antenna
  4. #14
    Aug 2003
    how do you use such a small touchscreen? No probs touching such small controls to get mp3s etc playing??
  5. #15
    May 2003
    Charleston, SC
    Not really...at first it was hard to use because I wasn't sure where everything was (tiny stuff), but now that I'm accustomed with it it's not that much of a problem. Little things like minimizing or closing windows can be tough at times. I use Media Engine right now & the controls are plenty big enough to touch with your finger. I also use 4am music console & that works good for full albums I have in mp3 since I touch the album cover & get to select from the songs. It too is easy to use with your fingers. Anything really tiny I use a small plastic touch pen & lately I've just thrown winamp on random with all of my songs loaded and sit the USB keyboard in my lap...it has volume controls at the top & 'z' & 'b' for previous & next selections respectively. This way I can change songs w/o using the touchscreen at all.
  6. #16
    Jun 2003
    Chicago
    Quote Originally Posted by HereFishyFishy
    Phil
    Well, I finally got my install completed (for the most part). I installed the computer in the glovebox for my first install attemp. It didn't work half bad until a stray wire shorted my 120gb hard drive....doh! I decided to take the more conventional approach and installed the computer in the trunk (in a casetronix 2699r case). This works much better...I can remove the computer from the car in 60 seconds and use it inside without modification. I'm using a standard 5.25" DVD rom drive in a USB 2.0 external enclosure. I removed the AC power supply from the enclosure and made a custom dc-dc supply, 8V to 20VDC input and constant 12V (1.5A max) &5V (2A max) output. I made a similar power supply for the computer, I connected four Texas Instruments PT5071's in parallel with a schottkey diode on each of the outputs, this gives me a constant 12VDC output with an input voltage anywhere between 8V and 20VDC. I'm using the PW60 that came with the casetronics 2699r case to generate the atx voltage rails. I installed a couple push buttons for power and reset switches. The screen still needs to be mounted better...I'm using the cheapo stand that that came with the 700ts. I need to take some pics.
  7. #17
    Sep 2003
    nice setup...
    I've got some yellow liquid for your popcorn and it's non-dairy too...
