Results 1 to 10 of 18
Thread: X-Mp3 Stage 1
    Raw Wave hijinks21's Avatar
    May 2002
    Albany, NY
    X-Mp3 Stage 1
    Project Name: X-Mp3
    Car: 1998 Ford Explorer Sport
    Engine: V6 4.0 liter
    no basic pics yet.. lemme get a car wash
    Stock everything but the deck.
    Carputer: Athlon 800 Mhz 192 meg RAM
    Case: Generic Cheap case (free)
    Power: INverter
    Storage: ~20 gig
    Sound: Sound Blaster Live
    Information Sources:
    http://www.mp3car.com
    Pictures:
    Here is the layout of my lcd. Its a 9 inch wide screen vga
    Here is the place I'm making a console for. It was a little self I took out to make some room.
    Stage 1 of console. Everything done out of wood
    Stage 2 of the console. Here the frame is completed
    my helper
    console in the car with the LCD attached.
    Here is the console and lcd in my apartment hooked up to the computer. It is taken with a bad camera so the screen looks blurry.
    For more pics and better res pics goto
    www.zcentric.com/~mike/mp3
    I just have to vinyl the console and do some touchup work so hopefully it will look a lot better. Looks very ghetto now.
    My task was to make a console that I could just pop right out and make my truck look stock again. SO hopefully it'll be a success.
    '98 Explorer Sport
    80% done
    Constant Bitrate reggiek945's Avatar
    Apr 2003
    Oklahoma
    Looks great dude, looks like your headed in the right direction. I like the way you have it so tha you can use it in car or home, very nice touch. Keep up the good work,
    Reggie
    Oh by the way, cool little helper.
    Jan 2003
    New Orleans
    Man, that's a friggin sweet lcd...Nice set up.
    Maximum Bitrate allenruble's Avatar
    Jun 2001
    somewhere
    looking good . nice lcd
    www.sounddomain.com/id/2000mp3ranger
    Mp3 player - 10.4 Allbrite Gigabyte GA-71XEH , 700 mgz t-bird , coolmaster fan , 2x 128 ram + 1 512ram , ATI-RAEON RV100 ,on bd sound , Linksys Wireless-B usb network adapter , 20G IBM TRAVELSTAR
    Registered User
    May 2003
    wut lcd is that? HOw come you made the wood frame so wide, which in effect increased the "ghettoness". Great start though, hopefully the vinyl'd finished product will blend in a bit more with your center console in your car
    HI!
    May 2002
    Albany, NY
    HeyMan, I wanted something I could just pop right out and make it look stock again. Also I needed it bigger to place the controller in the back and still be able to hook up the lcd. I'm hoping the vinyl makes it look a lot better.
    '98 Explorer Sport
    80% done
    May 2003
    Montreal, Canada
    I was at that stage a few months ago, I had a wooden frame with a 7" widescreen LCD and tried a few ways of covering the wood to make it look stock.
    I tried some thin vinyl... that didn't work out, I was able to see every single bump.
    I then tried putting the vinyl on top of some cardboard, and then cutting it to fit the LCD, but that didn't work either.
    The best solution I came up with was to go buy a 50cents tile from HOME DEPOT and paint it using special KRYLON plastic paint. Looks great in the car.
    FLAC MP3DUB's Avatar
    Jan 2002
    Chicagoland, IL
    You need some foam padding/headliner material between the vinyl and the wood if you dont want to be able to see all the imperfections. If you sand down/fill the plywood, you would probably just be able to cover it. Someone had a similarly rough frame in a 325i? and covered it in headliner material and then vinyl, and it looked quite good.
    -Nick
    _____________________________
    www.mp3vw.com
    May 2002
    Albany, NY
    ya i'm gonna use some 3M foam between the wood and the vinyl.. i'm also gonna get the really high grade stuff.
    '98 Explorer Sport
    80% done
    Mar 2001
    Benton Arkansas
    haha, talk about ghetto.... you should see my setup. Its almost just like yours!!! i'll post up pics this week
    MP3 GT
