Here are some more recent updates:
looks a lot better with the toner on it
oh ya this notch in the top left is for the wire, less of a hump for the wire, will make for a cleaner install
will be interesting to see it illuminate once in car
Another one of climate control with stickers on:
have attached to the mold bolts to connect to dash securely. bolts are held in place with JB weld front/back and lock washers
Since doing this I've filled over holes/scruffs on front, painted, applied toner:
pc power switch (not mounted yet), monitor switches, usb ports visible but they need work, might see about painting around edges or getting some sort of trim for that
as well as 3 bolts on right side that have been stealthily hidden, I had to drill 2 bolt holes on the left.
u can't see these bolts, basically out of view and sort of behind the steering wheel...but just to make it cleaner i'll paint em to match dash and see if i can clip on a plastic covering
going to see if i can find a stencil or sticker for the hazard light emblem
more to come soon!
LinkBack URL
About LinkBacks
