Page 2 of 7 FirstFirst 1234567 LastLast
Results 11 to 20 of 61
Like Tree4Likes
Thread: BMW E46 Android install (INCLUDES BUILD LOG / DIY)
  1. #11
    Jul 2012
    Quote Originally Posted by ohjamus View Post
    Where did you place the radio? Is it behind the Droid tablet? Does the new bezel allow you just put the tablet if front of the stock radio?
    Stereo needs to be modified a little bit in order to go deeper into the dash.
    Watch this space for a link to a DIY - should be available in the next couple of weeks.
    Cheers.
  2. #12
    Nov 2007
    Hello,
    I was wondering if there are any DNLA router tips you could give me? More specifically, I'm wondering how long it takes for something like that to boot up? Is there is any way to find out which models boot up the fastest? I would be using it mainly for multi media hard drive streaming. Also, is there anything I need to watch out for to make sure I can still tether the phone to the tablet while using the WIFI for the hard drive storage for multimedia? (Is pass through an issue with some DLNA routers?)
    I still have a power supply I purchased here a few years ago and I'm thinking of just buying a JVC head unit for the phone BT, amp, Speaker control, and CD's etc..
    I really like your set up and it is almost exactly what I am trying to do, only with the galaxy 10.1 first generation tablet. It would simply slide into a dock integrated into my dashboard from the top so I could take it on the go or put it in a lock box under the seat.
    I built a car pc using Road Runner into a super charged intercooled E36 M3 a few years ago, but I had to let it go after buying a house. My M3 Car pc blew peoples minds. They would get into the car and be at a complete loss for words. Now, I have a 2004 Scion XB econobox *30MPG*... It's awesome how this community has grown!
  3. #13
    Aug 2012
    BMDroid,
    Just saw this and very interested in doing something similar... Looks like a brilliant setup! Just curious about your power supply and aux audio in?! I have a BMW Nav so don't know if it would be possible to keep the OEM radio?!?
  4. #14
    Aug 2012
    San Rafael, Ca
    Question Stereo location and Step by Step install
    Quote Originally Posted by bmdroid View Post
    - Kept original BMW stereo system in place
    Can you please tell us where you hid the stereo system?
    I would also like to know if you have a Step by Step guide, or else a more detailed list of components you used and where you got them would be greatly appreciated. I just don't want to re-invent the wheel if it already has been well thought out and done, thanks!
    If you already have a Step by Step guide, can you please post it for everyone else here who might also be interested?
    One last question, how do you change from AM to FM or back to AM when the main stereo controls are not insight? Did you have to preset all your favorite channels so that you can run through the presets on your steering wheel?
  5. #15
    Oct 2009
    Wow, that's very clean.
  6. #16
    Jul 2012
    Hi guys,
    I've put together a sort of a DIY, hope you'll enjoy this and get something useful out of it.
    http://www.bmdroid.co.nz
    Cheers
  7. #17
    Jul 2008
    Very nice setup for a e46. Have you finished the canbus interface?
  8. #18
    Nov 2012
    RIKO STORE LIKES MY SKIN
    IM not really sure if anyone is still viewing this thread, but I have a few suggestions.
    Firstly, the need for a DLNA based router and HDD, might really be unnecessary. It depends on your situation though. If you life in an area with shotty cell coverage, or if you are stuck on a data plan that doesn't offer you very much bandwidth, then you might not be able to use the following recomendation.
    Look into a server/client app named Plex. This program started life as a branch of XBMC. The major difference between the two is that Plex has a dedicated program for Library management and file serving. What the hell does that mean you ask, or why is it relevent here. Well you set the server up on a home PC, Mac, Win, and Linux are all available. Point the server at your media locations, Music/TV/Movies, it will then go to work downloading meta-data on all of the files, with surprising accuracy so long as the file names are in clean order. For an example, the structure I use which has yet to fail me is as follows. "2001.A.Space.Odyssey[1968][720p].mp4"
    Once you set the library up all you need to do is add media to the folders and Plex will automatically add them to the library, downloading cover art, media info such as date, directors, cast, ect.
    Now the really cool part. Sign up for a MyPlex account which is free at my.plexapp.com. Sign into your myplex account in your Plex Media Server and also sign into your myplex account in the Client app available in the Google Playstore http://goo.gl/FVqFC .
    Once its done all of your media will be available to you on the go. Even better Plex uses HLS (http live streaming), this is the same streaming model apple uses for AirPlay. The advantage to it over something like Flash is that some of the codecs/containers do not need to transcoded, such as MP4. If it does need to be transcoded for playback or if the available bandwidth is too low for a live stream, Plex auto detects this and does it for you. Better still the transcode bitrate of HLS is completely adjustable on the fly, this means if you enter into an area of weaker cell coverage, your video does not buffer and stall, instead it dynamically lowers the quality (audio first, then video). When the signal strength picks back up HLS dynamically raises the quality.
    Want to share your movie collection with others, thats cool just have them sign up for a myplex account and quickly give their account access to your server right from the myplex website. This also means that you might not acutally need to worry about hosting the server yourself as mentioned above, if you have a friend with a better collection willing to run it on their system.
    I use this all the time in my car and it is always impressive in terms of video quality and responsiveness.
    If you dont want to have a dedicated server running all the time back home and dont have a friend willing to either there is another alternative also available in the Playstore. Go check out Navi-X. This thing is FILLED with free Movies and TV, it is a scraper program for things such as IceVideo and the like. Its not quite as stable as Plex, but its free so you cant complain too much. http://goo.gl/fQpiM
    If Music is more important to you, I HIGHLY suggest Subsonic. This again is a server/client setup that works much the same as Plex, but is better suited for music. Again you can share you music with other friends as well. YOu can even deligate which of them has access to creating playlists that are viewable to all the users, plus a crazy amount of other cool sharing features.
    Subsonic server - http://goo.gl/k8nz
    Subsonic app - http://goo.gl/GLoFq
    Dsub app (a slightly nicer looking/performing app) - http://goo.gl/xxnB6
    Now the last suggestion. The Jellybean interface is nice, but its still not really suited for a car infotainment system. You really need to try and create something along the lines of a 10foot interface. Big buttons and the like.
    Here is one I build for my Galaxy Nexus. Ill attach the PSD file so you can edit it according to the size of your screen, though using an app like image2wallpaper or multipicture livewallpaper if you want to have a slightly different image on each screen, would likely allow you to use it as is. After the wallpaper is applied use Desktop Visualizer to create transparent widgets over the buttons baked into the wallpaper itself and set each one to launch the appropriate app.
    You will need to download a 3rd party launcher to set this up correctly. I personally run this setup in ADW-Ex http://goo.gl/Z4W9x , though Apex Launcher or Nova Launcher will likely serve you just as well.
    The important part is that you need to be able to set a custom number of rows and columns. For this setup you need to set the rows to 5 and the columns to what ever you like. I think I am using 10.
    I also have the notification bar hidden, along with the icon dock. I setup gestures to access these features.
    Swipe up - opens the app drawer
    Swipe down - opens the notification pulldown.
    You can use UCCW to create the widgets I have to the left of the BMW logo.
    One I made for my buddy with a VW
    Here is the PSD should you want to alter it.
    BMW - https://www.dropbox.com/s/1ts1gv7uqgr9gp1/BMW.psd
    PS - For anyone that does not have access to Photoshop, you can always use GIMP or an even easier alternative is to visit http://pixlr.com/editor/. This browser based photo editor is surprisingly powerful and robust. It will open PSD files without many issues.
    HERE IS THE LINK TO THE DROPBOX FOLDER CONTAINING ALL NEEDED FILES!
    https://www.dropbox.com/sh/bge7jqtzacpawot/vgQbzz6hHu
  9. #19
    FLAC hexxamillion's Avatar
    Dec 2007
    AZ
    Awesome write up on the apps. You actually gave me a few ideas to add to my setup.
    Sent from my DROID BIONIC using Tapatalk 2
    "Live Free!!!...It's all about Open Source"
    Recent Proj
    Old Proj II
    Old Proj I
    YouTube:Project Videos
    Homepage: HexxWorld.net
    Twitter:http://twitter.com/hexxamillion
  10. #20
    Sep 2012
    rxritalin your picture is for 7" tablet ?
    Do you have one for renault ? (i'm not good with gimp / photoshop )
  1. Replies: 91
    Last Post: 07-21-2013, 06:48 AM
  2. Replies: 14
    Last Post: 07-28-2012, 02:20 PM
  3. Android dual tab install
    By Chrysrhodes in forum Android Tablet
    Last Post: 04-15-2012, 06:56 AM
  4. Android tablet hovering over the Dash install.
    By RipplingHurst in forum Android Tablet
    Last Post: 10-31-2011, 05:49 PM
  5. Android help?
    By Derek Shain in forum Android Tablet
    Last Post: 03-29-2011, 09:26 PM
Tags for this Thread
