Page 4 of 11 FirstFirst 1234567891011 LastLast
Results 31 to 40 of 106
Thread: 2008 Chevrolet Corvette 7" Android Tablet Install
  1. #31
    Oct 2012
    El Paso, TX
    Quote Originally Posted by YelloEye View Post
    Agreed there, battery pack maybe. Gotten should be a negative switch so that won't work. Your clock spring might be the same across all trims though, worth taking a look.
    Yeah I'll definitely take a look and ponder my options. I also considered a battery pack, but then I remembered that the ps3 controller dies often. This is because the bluetooth connection must remain constant, which drains the battery. I don't anticipate that the battery pack would last very long. I really don't want to take my airbag off once a week to charge it...
  2. #32
    Mar 2011
    Quote Originally Posted by SDB_FTW View Post
    Xbox battery pack mounted on the back of the wheel, it's a lithium ion pack and you can buy a couple to keep charged.
  3. #33
    Oct 2012
    El Paso, TX
    hmmm... I assume you mean mount the battery pack externally behind the wheel for easy swapping? Your suggestion is an intriguing one, my friend...
  4. #34
    Sep 2012
    What is that bezel you have attached with velcro and where did you get it
    Sent from my HTC One X using Tapatalk 2
  5. #35
    Mar 2011
    Yes exactly. Would have to look at the aesthetics of it though. I'm also not sure what voltage those packs kick out.
  6. #36
    Constant Bitrate firstorbit84's Avatar
    Mar 2009
    FL
    what are you running the audio to? do you have the stock head unit relocated or an amp somewhere?
  7. #37
    Oct 2012
    El Paso, TX
    Quote Originally Posted by krisperry View Post
    The bezel was cut from a metra double din stereo adapter, available at most stereo shops. I grabbed mine on Crutchfield for $9.99.
  8. #38
    Oct 2012
    El Paso, TX
    I would assume that the packs would kick out 3V since you can also run the controller off of 2 AA batteries which would be 3V.
  9. #39
    Oct 2012
    El Paso, TX
    Quote Originally Posted by firstorbit84 View Post
    I'm running the audio to an AudioControl Epicenter to boost the signal, then out to my crossover/amplifier network. You can see the complete install HERE.
  10. #40
    Jun 2007
    you know the samsungs tab have audio available via the USB out
    that way you can maintain a digital out instead of running through the headphone jack
    see
  1. Replies: 90
    Last Post: 01-27-2013, 04:58 PM
  2. **2008 VW GTI Nexus 7 Tablet install**
    By maresgti12 in forum Show off your project
    Last Post: 10-04-2012, 11:01 PM
  3. Porsche Cayenne Android Tablet Install
    By reedickyaluss in forum Android Tablet
    Last Post: 09-25-2012, 02:53 PM
  4. Android Tablet Install
    By rgscomputers in forum Android Tablet
    Last Post: 09-07-2012, 08:09 AM
  5. Android tablet hovering over the Dash install.
    By RipplingHurst in forum Android Tablet
    Last Post: 10-31-2011, 04:49 PM
Tags for this Thread
