Results 1 to 10 of 14
Thread: 98 Civic Ex Car Computer Custom CAD Install
    Apr 2013
    So my car is a 98 civic ex 2-door, i wanted to install a car pc but due to the small interior and no room for a normal DIN display I had to get a bit creative. I decided on installing it in the dash on the passenger side.
    Started out in cad, designed a frame that could be built into the dash to hold the touchscreen in place.
    Name:  2012-09-17 19.56.35.jpg
    Once i finished the design i sent it to a company i found online and had it printed for about 35$ + shipping.
    results: not bad
    Name:  2012-09-25 17.49.31.jpg
    Next i mounted the screen in the frame, a perfect fit.
    Name:  2012-09-25 17.49.58.jpg
    Name:  2012-09-25 17.50.08.jpg
    Adding the components and securing it in place, about as sloppy as it gets but hey, it holds great and no one will ever see it.
    Name:  2012-09-28 15.38.45.jpg
    outlined the are for cutting, made sure it was level and in the correct place on the dash.
    Name:  2012-09-28 15.52.18.jpg
    Sloppy cutting but i made sure to get it nice and smooth before finishing
    Name:  2012-09-28 23.11.59.jpg
    Installed the frame with touch screen, all the edges fit smoothly
    Name:  2012-09-29 01.06.53.jpg
    Name:  2012-09-29 01.07.04.jpg
    Heres the actuall computer, it fits in a nice little package under the passenger seat and has some pretty decent specs: Corsair 64GB SSD, 4gb ddr3 ram, Intel Atom Dual core D525 motherboard, m3-atx powersupply. It is also hooked into the obd2 port and i use dashcommand to display the data
    Name:  2012-10-02 18.32.20.jpg
    Heres a shot of it at night. The china screen actually works surprisingly well, resolution is great and the touch screen is very accurate and responsive
    Name:  2012-10-02 23.48.32.jpg
    Name:  2012-10-13 00.31.32.jpg
    I installed 2 usb ports in the front plate of where the casette player used to be as well as a headphone jack
    Name:  2013-04-24 11.41.35.jpg
    Here are the power buttons, green is for the computer which turns on both the screen and the pc, it also shuts it down. blue is for the blue leds in the footwells.
    Name:  2013-04-24 11.42.46.jpg
    Name:  2012-10-10 20.50.50.jpg
    Well its not the most beautiful setup in the world and i may have hacked up the car a little in the making, but its not exactly a beamer and i learned alot along the way. lemme know what you think!
    Mar 2006
    Colorado, but Canadian!
    Very nice install! Your in the top percentile of clean CarPC installs. Great job.
    1.9in x 2.9in -- 47mm x 73mm
    Jan 2007
    Looks great!
    What kind of screen are you using and what resolution do you have it set at to run Windows 8? What company did you use to have your screen bezel printed?
    Mar 2012
    New Jersey
    What are you using for OBD? That software looks nice if it functions well
    "It's not worth having if you can't customize it"
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    Very clean install. Looks like he is using dashcommand SNO http://www.palmerperformance.com/pro...dows/index.php
    Mar 2012
    New Jersey
    Ahh I have used Palmer before and it did work well enough. But the touch screen interface was pretty lacking. Is there some sort of skin being used there?
    Nov 2009
    Keswick,On Canada
    yeah it's been skinned here is the link to the skins and you need the skin editor if you want changes http://www.dashxl.net/
    Variable Bitrate AutoWiz's Avatar
    Jun 2013
    Pompano Beach, FL
    wow, that is clean install. very nice. now if you swap center bezel and a/c head unit with ex model, you could have dual screens on your civic.
    Sep 2013
    Very nice install!Is there some sort of skin being used there?
    Feb 2012
    rujoesmith that is NICE! I am using the same lcd and could really use that cad file as I have a 3d printer. Could you please upload or send them to me?
  1. Car Computer Install: Building the Computer Cable Management
    By Jensen2000 in forum Mp3Car Blog Talk
    Last Post: 09-27-2011, 09:48 AM
  2. Replies: 1
    Last Post: 02-05-2011, 09:20 PM
  3. CIVIC MOLDED CARPUTER screen/dash (civic 01-05)
    By sl33pyriceboi in forum Classifieds
    Last Post: 09-11-2009, 06:10 PM
  4. 94 Civic EX
    By djXternal in forum Car Audio
    Last Post: 12-30-2005, 04:52 PM
  5. To all Civic mp3-r's
    By gizmomkr in forum Off Topic
    Last Post: 05-27-2001, 12:22 AM
Tags for this Thread
