Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 36
Thread: My 95 Accord V6 with Win 8 CARPC
  1. #11
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    OK, I see you have the tower mounted in the armrest space. Pretty clever spot too, doubles as vibration dampening.
  2. #12
    Feb 2012
    Central Florida
    Thought about water cooling , but I came across a DIY circuit you can build to control fans , tested it out on my home PC and it worked great . What it does is it varies the voltage going to the fans depending on the temp, my front fan pulls in and the rear fan pushes out the rear. Using that circuit and speed fan I tweaked the settings on the circuit where as on the hottest August Florida day my proc and graph and sata ssd don't get get close to being hot. 95 degree day and the fans are running maybe 3/4 speed at start , which I can tell by the brightness of the LED on the fans, takes about 5 mins and my A/C has the temp down and fans running at minimum speed
  3. #13
    Feb 2012
    Central Florida
Size:  146.8 KBName:  HD Radio on RR 1.jpg
Size:  145.9 KBName:  carpic.jpg
  4. #14
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Very nice clean install. I like it!
  5. #15
    Feb 2012
    Central Florida
    thanks , the PC was about a 6 month long project , most of the stereo equipment is 20 years old and still crankin .
  6. #16
    FLAC rray's Avatar
    Apr 2012
    SF Bay Area
    +1 Very Clean!
  7. #17
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    There is definitely a cool factor to old skool mobile audio, some of it is drawing pretty good bucks now too because it is in style right now.
  8. #18
    Feb 2012
    Central Florida
    well I do know that the distortion ratio was rated at .008 on my 20 year old Soundstream amps, and the last 10 years have been geared toward volume which results in ratings of .08 or .8 distortion. unfortunately there no ADHOC for car stereo so companies can put any spec they want. But your higher end companies usually have accurate specs." point in case"
    I would have customers bring me a 300 watt amps to install that would have 1# 20 amp fuse for protection. TALK ABOUT BREAKING THE LAWS OF PHYSICS. That amp might reach 300 watts but it would be at a high distortion ratio that your speakers would eventually fry
  9. #19
    FLAC PhilG's Avatar
    Mar 2009
    Ontario, Canada
    Yup, nothing like a Pyramid 1200w amp that can almost run off a cigarette lighter.
  10. #20
    Variable Bitrate bambam's Avatar
    Dec 2004
    Upstate New York
    Quote Originally Posted by rray View Post
    +1 Very Clean!
    Agree, very nice install. I like how you went headless; what did you route your sound from the PC to? I want to go headless also but I'm somewhat hesitant because I'm not sure how to get the sound from my motherboard to the speakers/sub effectively.
    Also, how do you like the Directed HD Radio tuner?
    "Imagination is more important than knowledge." -AE
  1. 2004 Accord navigation with carPC
    By blazer563 in forum Newbie
    Last Post: 02-04-2011, 11:49 AM
  2. 06 Accord CarPC - LOTS of pictures!
    By jpinkerton in forum Worklogs
    Last Post: 12-06-2010, 02:22 PM
  3. CarPC for '06 Accord LX
    By Ceriand in forum Worklogs
    Last Post: 09-15-2010, 02:03 AM
  4. 8th gen honda accord carpc
    By jayknight in forum Show off your project
    Last Post: 03-29-2010, 06:52 AM
