Results 21 to 30 of 36
Thread: My 95 Accord V6 with Win 8 CARPC
  1. #21
    Feb 2012
    Central Florida
    I have a Creative Sound Blaster Z SBX PCIE audio card that has a great preamp output, then I built a audio switcher that has 5 volt relays so when the pc is off the hd radio controller under the monitor will provide audio to the amps . when pc is turned on the usb provides 5 volt to the relays and switches to pc audio from the card. MAKE SURE AND GROUND YOUR COMPUTER CHASIS GROUND TO CAR GROUND OR YOU MIGHT GET SOME NOISE.
  2. #22
    Feb 2012
    Central Florida
    love my directed hd tuner built a switch for the controller that uses the directed controller to control tuner when pc is off and when pc is on it uses the riderunner front-end with DFX5.1 skin to control the tuner. MP3.car sells adapters to make this possible
  3. #23
    Variable Bitrate bambam's Avatar
    Dec 2004
    Upstate New York
    I would love to see/hear more about your audio switcher with relays and, I looked in the MP3.car store and didn't know exactly what product you meant about the directed controller to control the tuner when the PC is off (Mitch JS USB audio selector?)
    Thanks....love your setup!
    "Imagination is more important than knowledge." -AE
  4. #24
    Raw Wave SNOtwistR's Avatar
    Nov 2009
    Keswick,On Canada
    Not sure what route they used but I am going this route for having the directed screen and still be able to use with a pc. http://store.hawkesintl.com/midin8swbo.html I got 2 so I can see if it can be controlled by relays. But this seemed the simplest. SNO
  5. #25
    Feb 2012
    Central Florida
    the usb cable product Code: COM-138 at the mp3car store Price: $37.95 can be used with Visteon HDZ300 and Directed Electronics hd tuners I have the Directed version . My audio switcher is comprised of 2# DPDT (double pole double throw) 5volt relays, you want to use relays that are rated for the LIGHTEST duty you can find , heavy duty relays can add a spike noise when they are powered. Got mine at radio shack , you can find them cheaper online. One relay for the left channel and one for the right channel . there is an easier but a little more expensive way you can buy a (PIE MPSS-2 2-Channel Multi-Purpose RCA Audio Source Switcher ) and on SPST 5 volt relay to trigger the 12v audio switcher, you also need a simple car audio (PREAMP thru RCAs) volume control usually $ 15.00 I only had an audio switcher because I was using both Sirius-xm and hd radio together. the switcher I built for the hd radio controller is needed if you want sound when the pc is off. Later today when I get off work I will post a diagram on how to make that switcher
  6. #26
    Feb 2012
    Central Florida
    AUTOMATIC HD RADIO SWITCHER
    parts list
    2# 6Ft Apple Mac Serial Device Cable ( 8 pin mini din ) 4.99 each EBAY
    4# H02151-01C Relay DPDT 5v " $3.99 each at "HOBBY ENGINEERING"
    1# radio shack project box $5.99
    1# usb charger cable "not sync cable" charger cable will only have power and ground in them.
    NOTE : cut both 8 pin mini din in half, you only need 2 # female ends and 1# male end , each of the 8 wires usually have different
    colors makes it easy to match up to relays.
    The 3# 8 pin mini din cables will all have an unsheilded wire no need to go to the relay with them just connect all 3 together.
    NOTE : If you get relays elsewhere the N/o (normally open) and N/C (normally closed) and C (common) , might be in diferent locations
    but all relays should have a schematic telling you where the N/C and N/o and C are located
  7. #27
    Feb 2012
    Central Florida
    it would not let me paste my notepad diagram on the forum without it getting jumbled so I will take a pic
  8. #28
    Feb 2012
    Central Florida
  9. #29
    Aug 2010
    Bahrain
    Quote Originally Posted by zeerific View Post
    Attachment 70133
    almost GAVE UP ON FINDING A MICRO TOWER THAT WOULD FIT IN THAT LOCATION, STARTIED DRAWING UP PLANS TO BUILD A TRANSPARENT BLUE PLEXIGLASS TOWER , THEN I FINALLY FOUND THE TOWER ONLINE. I CONNECTED WIRES TO THE START BUTTON OF THE PC AND RAN THE WIRES TO A SWITCH ON THE RIGHT SIDE OF THE STEERING WHEEL. BOTH SWITCHES ARE FUNCTIONAL
    Impressive.
  10. #30
    Feb 2013
    I can't believe you found something that fitted inside there... good job!! Hope it absorbs shocks very well.
  1. 2004 Accord navigation with carPC
    By blazer563 in forum Newbie
    Last Post: 02-04-2011, 11:49 AM
  2. 06 Accord CarPC - LOTS of pictures!
    By jpinkerton in forum Worklogs
    Last Post: 12-06-2010, 02:22 PM
  3. CarPC for '06 Accord LX
    By Ceriand in forum Worklogs
    Last Post: 09-15-2010, 02:03 AM
  4. 8th gen honda accord carpc
    By jayknight in forum Show off your project
    Last Post: 03-29-2010, 06:52 AM
