Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Lexus IS250 Android integration using iVIC and ODROID U3
  1. #11
    Newbie focused's Avatar
    May 2014
    Canada
    Quote Originally Posted by kevinkga View Post
    You were right Focussed, delivery is rather quick! However, our customs had a surprise for me too. Seems like customs charged me an additional GBP28 for it. Bummer! Hopefully I'll have it by tonight when I get home
    Sounds about right. I had to pay some brokerage as well from Hardkernel. For my project the brokerage and shipping accounted for $149.60CAD, 24.6% of the project. Probably a useful thing to know for people who are pricing things out. Very exciting though, the Odroid is a lot of fun!
  2. #12
    Sep 2009
    London
    So I finally received the ODROID and here are some unboxing pics:
  3. #13
    Sep 2009
    London
    I was very curious about the hardware and chipsets available on this device, so I installed the dual booting image for linux and android. Here's what I did (on linux):
    #download the zipped image file
    wget http://www.odroid.in/mirror/dn.odroi...140315.img.zip
    #unzip the file to reveal the image
    unzip xubuntu-13.10-desktop-armhf_android_odroidu_20140315.img.zip
    #do a raw write to the chip using the linux dd command and specifying 4M block size
    sudo dd if=xubuntu-13.10-desktop-armhf_android_odroidu_20140315.img of=/dev/sdb bs=4M
    sudo sync
    NOTE: that /dev/sdb is the Usb Card Reader to which I attached my eMMC module to. This might vary on different systems and should be used with extreme care otherwise you risk overwriting data such as your OS!
    Hardkernel provided an eMMC to MicroSD adaptor with the purchase of the eMMC module. You basically take off the eMMC module from the ODROID, press it onto the MicroSD adaptor, put the MicroSD adaptor into a (USB) MicroSD reader/writer and stick that MicroSD reader/writer into your PC's USB port. It turned out to be very handy for updating images. Once the image was written, I just took the eMMC chip and placed it under the ODROID U3 in its socket. Voila! New OS!
    Power on the device and it boots into an ncurses a config mode, where you can set the HDMI output modes, SSH-on-boot etc. Very easy and convenient stuff. Once done, it boots straight into Xubuntu.
    This video shows how to perform the actual dual boot afterwards: https://www.youtube.com/watch?v=4FTQgpalAqY
    In short (btw the root password is 'odroid'):
    odroid@odroid:/media/boot$ sudo su
    [sudo] password for odroid:
    root@odroid:/media/boot# cd /media/boot/
    root@odroid:/media/boot# mv boot.ini.android boot.ini
    root@odroid:/media/boot# mv boot.scr boot.scr.ubuntu
    root@odroid:/media/boot# sync
    root@odroid:/media/boot# reboot
  4. #14
    Sep 2009
    London
    So here are some commands that I ran to get more info about the unit
    odroid@odroid:~$ uname -a
    Linux odroid 3.8.13.16 #1 SMP PREEMPT Tue Feb 11 10:47:21 BRST 2014 armv7l armv7l armv7l GNU/Linux
    odroid@odroid:~$ lspci
    pcilib: Cannot open /proc/bus/pci
    lspci: Cannot find any working access method.
    odroid@odroid:~$ lsusb
    Bus 001 Device 006: ID 0bda:8176 Realtek Semiconductor Corp. RTL8188CUS 802.11n WLAN Adapter
    Bus 001 Device 005: ID 0a12:0001 Cambridge Silicon Radio, Ltd Bluetooth Dongle (HCI mode)
    Bus 001 Device 004: ID 046d:c52b Logitech, Inc. Unifying Receiver
    Bus 001 Device 003: ID 0424:3503 Standard Microsystems Corp.
    Bus 001 Device 002: ID 0424:9730 Standard Microsystems Corp.
    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
    odroid@odroid:~$ lsmod
    Module Size Used by
    fuse 65473 2
    ipt_MASQUERADE 1693 1
    iptable_nat 2485 1
    nf_conntrack_ipv4 13029 1
    nf_defrag_ipv4 1231 1 nf_conntrack_ipv4
    nf_nat_ipv4 3444 1 iptable_nat
    nf_nat 14753 3 ipt_MASQUERADE,nf_nat_ipv4,iptable_nat
    nf_conntrack 65240 5 ipt_MASQUERADE,nf_nat,nf_nat_ipv4,iptable_nat,nf_c onntrack_ipv4
    ip_tables 11486 1 iptable_nat
    x_tables 15172 2 ip_tables,ipt_MASQUERADE
    bridge 81191 0
    stp 1882 1 bridge
    llc 4842 2 stp,bridge
    rfcomm 31784 16
    btusb 12824 0
    bnep 10808 2
    bluetooth 197870 22 bnep,btusb,rfcomm
    mousedev 10060 0
    ipv6 269175 55 bridge
    joydev 8724 0
    smsc95xx 19090 0
    usbnet 19464 1 smsc95xx
    hid_logitech_dj 10725 0
    rtl8192cu 522755 0
    gpio_keys 7062 0
    vfat 9124 1
    fat 49103 1 vfat
    Note that the USB logitech receiver is just my keyboard/mouse receiver.
    The wifi adaptor uses the RTL8188CUS chip and rtl8192cu kernel module:
    Device Descriptor:
    bLength 18
    bDescriptorType 1
    bcdUSB 2.00
    bDeviceClass 0 (Defined at Interface level)
    bDeviceSubClass 0
    bDeviceProtocol 0
    bMaxPacketSize0 64
    idVendor 0x0bda Realtek Semiconductor Corp.
    idProduct 0x8176 RTL8188CUS 802.11n WLAN Adapter
    bcdDevice 2.00
    iManufacturer 1
    iProduct 2
    iSerial 3
    bNumConfigurations 1
    Configuration Descriptor:
    bLength 9
    bDescriptorType 2
    wTotalLength 46
    bNumInterfaces 1
    bConfigurationValue 1
    iConfiguration 0
    bmAttributes 0x80
    (Bus Powered)
    MaxPower 500mA
    Interface Descriptor:
    bLength 9
    bDescriptorType 4
    bInterfaceNumber 0
    bAlternateSetting 0
    bNumEndpoints 4
    bInterfaceClass 255 Vendor Specific Class
    bInterfaceSubClass 255 Vendor Specific Subclass
    bInterfaceProtocol 255 Vendor Specific Protocol
    iInterface 0
    Endpoint Descriptor:
    bLength 7
    bDescriptorType 5
    bEndpointAddress 0x81 EP 1 IN
    bmAttributes 2
    Transfer Type Bulk
    Synch Type None
    Usage Type Data
    wMaxPacketSize 0x0200 1x 512 bytes
    bInterval 0
    bLength 7
    bDescriptorType 5
    bEndpointAddress 0x02 EP 2 OUT
    bmAttributes 2
    Transfer Type Bulk
    Synch Type None
    Usage Type Data
    bInterval 0
    bLength 7
    bDescriptorType 5
    bEndpointAddress 0x03 EP 3 OUT
    bmAttributes 2
    Transfer Type Bulk
    Synch Type None
    Usage Type Data
    bInterval 0
    bLength 7
    bDescriptorType 5
    bEndpointAddress 0x84 EP 4 IN
    bmAttributes 3
    Transfer Type Interrupt
    Synch Type None
    Usage Type Data
    wMaxPacketSize 0x0040 1x 64 bytes
    bInterval 1
    Here is some more info about the USB Bluetooth adapter:
    Device Descriptor:
    bLength 18
    bDescriptorType 1
    bcdUSB 2.00
    bDeviceClass 224 Wireless
    bDeviceSubClass 1 Radio Frequency
    bDeviceProtocol 1 Bluetooth
    bMaxPacketSize0 64
    idVendor 0x0a12 Cambridge Silicon Radio, Ltd
    idProduct 0x0001 Bluetooth Dongle (HCI mode)
    bcdDevice 19.58
    iManufacturer 0
    iProduct 0
    iSerial 0
    bLength 9
    bDescriptorType 2
    wTotalLength 177
    bNumInterfaces 2
    iConfiguration 0
    bmAttributes 0xc0
    Self Powered
    MaxPower 0mA
    bLength 9
    bDescriptorType 4
    bInterfaceNumber 0
    bAlternateSetting 0
    bNumEndpoints 3
    bInterfaceClass 224 Wireless
    bInterfaceSubClass 1 Radio Frequency
    bInterfaceProtocol 1 Bluetooth
    iInterface 0
    bLength 7
    bDescriptorType 5
    bmAttributes 3
    Synch Type None
    Usage Type Data
    wMaxPacketSize 0x0010 1x 16 bytes
    bInterval 1
    bLength 7
    bDescriptorType 5
    bmAttributes 2
    Transfer Type Bulk
    Synch Type None
    Usage Type Data
    bInterval 1
    bLength 7
    bDescriptorType 5
    bEndpointAddress 0x82 EP 2 IN
    bmAttributes 2
    Transfer Type Bulk
    Synch Type None
    Usage Type Data
    bInterval 1
    bLength 9
    bDescriptorType 4
    bInterfaceNumber 1
    bAlternateSetting 0
    bNumEndpoints 2
    iInterface 0
    bLength 7
    bDescriptorType 5
    bmAttributes 1
    Transfer Type Isochronous
    Synch Type None
    Usage Type Data
    wMaxPacketSize 0x0000 1x 0 bytes
    bInterval 1
    bLength 7
    bDescriptorType 5
    bEndpointAddress 0x83 EP 3 IN
    bmAttributes 1
    Synch Type None
    Usage Type Data
    bInterval 1
    bLength 9
    bDescriptorType 4
    bInterfaceNumber 1
    bAlternateSetting 1
    bNumEndpoints 2
    iInterface 0
    bLength 7
    bDescriptorType 5
    bmAttributes 1
    Synch Type None
    Usage Type Data
    wMaxPacketSize 0x0009 1x 9 bytes
    bInterval 1
    bLength 7
    bDescriptorType 5
    bmAttributes 1
    Synch Type None
    Usage Type Data
    bInterval 1
    bLength 9
    bDescriptorType 4
    bInterfaceNumber 1
    bAlternateSetting 2
    bNumEndpoints 2
    iInterface 0
    bLength 7
    bDescriptorType 5
    bmAttributes 1
    Synch Type None
    Usage Type Data
    wMaxPacketSize 0x0011 1x 17 bytes
    bInterval 1
    bLength 7
    bDescriptorType 5
    bmAttributes 1
    Synch Type None
    Usage Type Data
    bInterval 1
    bLength 9
    bDescriptorType 4
    bInterfaceNumber 1
    bAlternateSetting 3
    bNumEndpoints 2
    iInterface 0
    bLength 7
    bDescriptorType 5
    bmAttributes 1
    Synch Type None
    Usage Type Data
    wMaxPacketSize 0x0019 1x 25 bytes
    bInterval 1
    bLength 7
    bDescriptorType 5
    bmAttributes 1
    Synch Type None
    Usage Type Data
    bInterval 1
    bLength 9
    bDescriptorType 4
    bInterfaceNumber 1
    bAlternateSetting 4
    bNumEndpoints 2
    iInterface 0
    bLength 7
    bDescriptorType 5
    bmAttributes 1
    Synch Type None
    Usage Type Data
    wMaxPacketSize 0x0021 1x 33 bytes
    bInterval 1
    bLength 7
    bDescriptorType 5
    bmAttributes 1
    Synch Type None
    Usage Type Data
    bInterval 1
    bLength 9
    bDescriptorType 4
    bInterfaceNumber 1
    bAlternateSetting 5
    bNumEndpoints 2
    iInterface 0
    bLength 7
    bDescriptorType 5
    bmAttributes 1
    Synch Type None
    Usage Type Data
    wMaxPacketSize 0x0031 1x 49 bytes
    bInterval 1
    bLength 7
    bDescriptorType 5
    bmAttributes 1
    Synch Type None
    Usage Type Data
    bInterval 1
  5. #15
    Sep 2009
    London
    I also received the GPS board today.
    Happy to find out that it's actually recognized as a COM port as I had originally suspected.
    Opening /dev/ttyUSB0 showed me some GPS data, which is great news!
    odroid@odroid:~$ cat /dev/ttyUSB0
    It seems to be handled by these modules:
    Module Size Used by
    cp210x 8163 0
    usbserial 23409 1 cp210x
    Bus 001 Device 007: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP210x UART Bridge / myAVR mySmartUSB light
    Device Descriptor:
    bLength 18
    bDescriptorType 1
    bcdUSB 1.10
    bDeviceSubClass 0
    bDeviceProtocol 0
    bMaxPacketSize0 64
    idVendor 0x10c4 Cygnal Integrated Products, Inc.
    idProduct 0xea60 CP210x UART Bridge / myAVR mySmartUSB light
    bcdDevice 1.00
    iManufacturer 1
    iProduct 2
    iSerial 3
    bLength 9
    bDescriptorType 2
    wTotalLength 32
    bNumInterfaces 1
    iConfiguration 0
    bmAttributes 0x80
    (Bus Powered)
    MaxPower 100mA
    bLength 9
    bDescriptorType 4
    bInterfaceNumber 0
    bAlternateSetting 0
    bNumEndpoints 2
    bInterfaceSubClass 0
    bInterfaceProtocol 0
    iInterface 2
    bLength 7
    bDescriptorType 5
    bmAttributes 2
    Transfer Type Bulk
    Synch Type None
    Usage Type Data
    bInterval 0
    bLength 7
    bDescriptorType 5
    bEndpointAddress 0x01 EP 1 OUT
    bmAttributes 2
    Transfer Type Bulk
    Synch Type None
    Usage Type Data
    bInterval 0
  6. #16
    Sep 2009
    London
    So after the reporting on the hardware and drivers in linux, I was happy to reboot the system into Android mode.
    The next step was to install GAPPS (Google Apps e.g. Google play etc). To do this I opened this APK from the android browser: http://dn.odroid.com/GAPPS/GAppsInstaller_jellybean.apk
  1. ACUI: Android Integration into your car!!
    By ACUI in forum Software & Software Development
    Last Post: Yesterday, 10:25 AM
  2. 2004 Ford Focus ZTS and Odroid U3
    By focused in forum Worklogs
    Last Post: 07-02-2014, 07:37 AM
  3. What are my options for running raspberrypi/odroid 24/7?
    By Vadim Osovski in forum Power Supplies
    Last Post: 12-14-2013, 11:06 PM
  4. Replies: 14
    Last Post: 07-28-2012, 01:20 PM
  5. Lenovo S10-3t in my IS250
    By n3w813 in forum Show off your project
    Last Post: 12-15-2010, 03:09 PM
Tags for this Thread
