Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
Thread: 1996 Camaro
  1. #21
    Newbie mjackson's Avatar
    Jun 2004
    Currently in Germany
    _maelstorm - I know you said small, but I have been using the ATI Remote Wonder for my application and it works like a charm...
    It is a USB RF remote...
  2. #22
    Newbie Digitaltigre's Avatar
    Jun 2004
    Hello. You should forget about the rf part of it. Go IR and use the program called Girder. I have a remote that has a qwerty layout keyboard inside it (flips open to reveal). Here are two pictures of it
    And with Girder you can program each button to do whatever you want. And I do mean WHATEVER! It is so flexible and powerful that you honestly wont need anything else. You will need any remote and an IR usb receiver along with the program.
    The main reason I am reponding here is that I have the same static problem as you. Only when I turn the volume up and only with the bass hits. I get some lines and that flicker or roll in the screen. I just put in an XAV-7W. I used to have an Audiovox 5.6" in the dash and I was running it off the computers PSU because the static from the cars power was insane. The car battery powered the screen fine until I started the engine and the line went from 12 volts to like 14+ which made the screen go nuts and become unviewable. So I just decided to power it from the computer. But now I can't do that because it's a whole head unit and not just a little screen. Plus I like having the HU's remote line start up and shutdown the computer. So - did you ever find a fix to your static problem? I was thinking that the CAP might do the trick, but before I try I wanted to get some feedback from you. Your last post was ages ago and I wonder if you'll even see this...
  3. #23
    Constant Bitrate _maelstrom's Avatar
    Aug 2003
    I've tried a few suggestions other than spending cash on a cap, but none of them have worked. One of the installers at a local car audio shop suggested running power to the HU directly from the battery instead of the factory wiring harness....didn't help. It wasn't too long ago I had to replace my battery and alternator....didn't help. I must have checked the A/V and power cables at least 4 or 5 times to make sure they weren't picking up interference....didn't help. Tried grounding the PC....didn't help. The only suggestion I haven't tried is purchasing a cap. I'm putting that off cuz I've been looking at getting a new car for awhile so I stopped working on this one.
    The thing that really baffles me is the fact that the static only appears when the volume is up and the bass hits when the HU is playing an AUX source. I've never seen the static when just using the AM/FM tuner. I'm wondering if there is an issue with the external A/V box. I guess I could try grounding that somehow....I don't know. Have you had any luck with fixing the problem?
    Sorry it took so long to post. I haven't had much free time the last couple days.
    - Sony XAV-7W In-Dash 7" LCD
    - Via EPIA 800MHz
    - 256MB SDRAM
    - 40GB HDD
    - Targus Wireless Remote
    - Win 98SE
    See it Here
    or Here (
  4. #24
    Oct 2003
