Results 1 to 10 of 14
Thread: mp3850
    Sep 2002
    Worcester, MA
    mp3850
    Project Name: mp3850
    Car: 1996 Volvo 850
    Engine: 2.4L L5 PFI DOHC 20V
    Basic Stereo Information:
    Front: Infinity Kappa 5.25 Componant Set
    Rear: Infinity Kappa 5x7's
    Amp: Rockford Fosgate Punch 700x
    Carputer: Epia M9000
    Case: Glovebox
    Power: OPUS 90watt DC-DC with remote output
    Storage: 25 Gig
    Sound: Onboard Sound
    Display: GAIN 7inch Touchscreen LCD
    Information Sources:
    mp3car
    Volvospeed
    Pictures:
    Final Install Pictures
    Everything Else
    SMKFree liquid_smoke's Avatar
    Aug 2003
    Chicago
    Hey how did you mount your screen? Thats exactly how i want mine to be mounted, got any pics of it showing how its mounted?
    Cool install
    Sep 2002
    Worcester, MA
    Quote Originally Posted by liquid_smoke
    Cool install
    I bought a 2nd radio for my car off of ebay. I then gutted it, removed the front and used the frame. It worked rather nicely. If you click on the everything else pictues, and then click on LCD Mount you can see some shots of it.
    Aug 2003
    Chicago
    thats pretty nice.
    I wish i had a double din so i could do the same.
    FLAC chut's Avatar
    Jul 2003
    San Antonio, TX. USA
    I've got the same single din problem. I bet if you got the single din mounting box, you could do something with that. I got this for .99 on eBay. I am going to use this, an underdash mounting kit and the indash mounting kit for the LCD on top of my dash. I'll post pictures when I am mostly done. It will be double ugly at first, but I'll work on that. The pictures attached are of the parts I'm going to use to make my "above the dash" mounting kit.
    Peter
    thats pretty nice.
    Aug 2003
    Chicago
    Chut
    I look forward to seeing how you set it up, not sure what the second pic is or where it fits in on your setup.
    The last pic-
    Are you buying a new screen or just the part that the screen folds into?
    I have a single din, but it is possible for me to do a double DIN conversion for my car (VW Passat) but i wasnt going to do it because the screen i had wasnt a fold out din type like the las pic you posted. Its the DS700YVV from DSCustoms. Can you buy the part that the screen folds into seperately? And can my screen fit into one of these. If so then ill do the double din conversion and it will solve all my mounting problems.
    TIA
    FLAC chut's Avatar
    Jul 2003
    Hi,
    Actually, at this point, I have already bought all that I need, I'm just waiting to take delivery on all of it. I'm buying just the part that the screen mounts into. I got it from www.DigitalWW.com PM from here seems to work best for purchases. I already have the 700TS USB from Xenarc. I plan on mounting the touchscreen into the box with sliders. Mounting the box with sliders into the single din chassis upside down and then mounting the two parts into the underdash kit which I then flip over and mount on top of the center dash in my roadster. Either that or buy an EQ and get rid of my head unit. Then install it in place of the headunit. But then I loose my XM radio. I am bidding on an EQ on eBay right now...so we'll see how that goes.
    Chut
    The last pic-
    TIA
    Sep 2003
    Helsinki Finland
    Quote Originally Posted by chut
    I plan on mounting the touchscreen into the box with sliders. Mounting the box with sliders into the single din chassis upside down ...
    Where can I find that kind of housing or box with sliders. I would also do that kind of install if I only could find the box. I'm harvesting equipment for my carputer and looking about everything I could use.
    FLAC chut's Avatar
    Jul 2003
    I got it from www.DigitalWW.com by sending a PM to digitalww from here, which seems to work best for purchases. I got the Pioneer EQ 6500 on eBay last nite for 61.00. It's has nine bands, low pass, high pass a ten decibel gain on the sub, two input to five output and even has amber illumination to match my interior. Once I rip out the DEH-P8400 I'll install the monitor into my dash instead of on my dash, run the soundcard from my laptop to the EQ mounted somewhere, I haven't decided yet. That will run into the front, rear and sub inputs on the kenwood amplifier. the amp is connected to two 5.25 inch kenwoods in the kick panels, two 4 inch round in the rear and a 6' sub in the center console. 700 Watts RMS. It should make quite a show. The motorized mount would be cooler, but I didn't want it. Anyway, I won't be cutting up my car so that makes me even happier. Next I need to think about beefier drivers for the sound system. But that will have to wait.
    Peter
    Quote Originally Posted by Doggyboy
    Maximum Bitrate SiGmA_X's Avatar
    Jul 2003
    Portland, OR, USA
    naevity - Site is down, all of them
    1993 BMW 325is - 15.2sec
