Results 11 to 20 of 24
Thread: DSCustoms flush indash, VIA m10000 DONE! tons of pics and info
  1. #11
    Raw Wave Defiler's Avatar
    Jan 2002
    Temple Terrace, Fl.
    Quote Originally Posted by Callahan
    My 2001 Grand Am has a Double DIN.. they already have
    Well, they should've done it in '98!!!
    Aura MR62 (F and R)
    My Current MP3s
    IamDefiler.com
  2. #12
    Jun 2003
    Chicago
    gizmomkr
    What material did you use to make the lcd look so flush (plexiglass I assume?). Did you line up the material to the outside of the screen or did you cover the screen with the plexiglass?
  3. #13
    Mar 2002
    does the touchscreen still work?
  4. #14
    Sep 2003
    Baltimore, MD
    Did you have to move around any of the climate control buttons to fit the screen in? If so, how hard was it to do and how long did it take?
    Im thinking about putting a screen in my accord but i would have to move all of the climate control down a good 6 inches.
    ~Mike
  5. #15
    Apr 2003
    can you show me how to take off the radio cover? I have a 2000 civic too and I been lookin in the manual with no luck.
  6. #16
    Raw Wave kickercivic1's Avatar
    May 2003
    Florida
    hahaha
  7. #17
    Maximum Bitrate gizmomkr's Avatar
    Dec 2000
    Smyrna, Ga, USA
    Well lets see - No I didnt have to touch the AC controls at all.
    The Radio "cover" you mean the black shroud with the ac vents and all ?
    Ok, start off with the two screws under the panel, facing the floor board (near the cig. lighter) then remove the paneling under the steering wheel, (this has screws all over , just gota look for em..) (1 is in the glove box corner) then you will have access to 1 remaining screw in the far upper left side of the plastic that contains the cig lighter. The screw is normally covered by the far corner of the other plastic shroud. remove this screw, and the cig lighter shroud shoud be free.
    under this shroud are 4 bolts with philips heads / socket
    remove these 4 bolts and the entire black plastic shroud can nuw be pulled off (it has clips, so pull firmly)
    Gizmo-
    Techonlogy on Wheels
    http://www.hjnetworks.com/car
  8. #18
    Dec 2000
    Smyrna, Ga, USA
    Wow - I never thought updating my website would take so much f$#@! time !
    Anyway - Everything is done . Install is complete, and I have ooodles of pics in the LCD section
    Gizmo-
  9. #19
    Dec 2000
    Smyrna, Ga, USA
    Before I get yelled at - its kind of a double post from my other one- but not really because the old post was just the LCD .
    Everything is in and my new system is hapily chugging along with all the fix'n's of a carputer.
    LCD in dash (the most work)
    WiFi, DvD (under drivers seat) GPS,
    Opus PSU, tank circuit, wireless internet via Bluetooth GSM (t-mobile)
    I updated my website to reflect all the new toys.
    Enjoy - Questions, coments - http://www.hjnetworks.com/car
    - See you guys at NOPI - Gizmo...
    Gizmo-
  10. #20
    Jan 2002
    Philadelphia
    Looks great. Did you keep the touch screen? Do you find the extra controls you added are needed with the touch screen? (assuming you kept it in)
    Great Job.
