Do you have any plans for the custom relay switch that you made?
Printable View
use the fiberglass cutting wheels (the blue ones). 5 for $5.
I love it!!
Could you send me all those pics in a .zip format possibly?
zhartwel@flemingc.on.ca
What type of screen is it? One of the ebay ones you see on there all the time?
Hey man looks good. I just got myself an 86 lincoln cont givenchy(fun cars). It was finny cause I was just looking at it yesterday thinking how nice it wold look to mold a touch screen in place if the stereo. Did you completly remove the factory computer in the upper dash
Yup, I completely removed the computer and status panel that was below it. although the computer was required to make the Electronic dash work, so I just gutted it to the bare boards, and moved it further inside the dash. I then had to cut quite a bit of bracing and plastic supports out in order for it to all fit. My only worry is putting it back together when I go to sell the car :confused:Quote:
Originally Posted by aleromaster
hey man...did you have any problems drilling into the plexi? THan
How did you build the power switch to start the computer when the car starts? Do you get any trouble from those 12W3's (thats what they looked like) vibrating the comp? Nice setup.
actually they are 12w4's and I haven't had a lick of trouble, even when they are hitting at their hardest.Quote:
Originally Posted by jusatry
About the relay, all it really does it short the connections on the power toggle switch of the power inverter when it receives +12v from my ignition switch. And a second relay then keeps those contacts shorted, via +12v from the computer's power supply so that way the inverter stays on until the computer shuts off, even if the ignition is turned off.
No problems drilling the plexi, just need a sharp drill bit, and you have to take it slow to keep it from melting..Quote:
Originally Posted by outofmyway6
hey MeanGT,Quote:
Originally Posted by MeanGT
really good job!! :)
but i don't understand how you solved the problem with the fluctuation of the voltage during starting process? then the voltage is going down to arround 7V and your power inverter can't hold the 12V...? and if you get the power direct from battery it would be the same problem with the fluctuation??
how does it work with this power switch? sorry.. for my stupid question!
don't sell this car!!!
