Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 32
Thread: 1982 Lincoln Continental Carputer install
  1. #11
    Oct 2003
    Michigan
    Do you have any plans for the custom relay switch that you made?
  2. #12
    Jul 2000
    Jackson, MS, USA
    use the fiberglass cutting wheels (the blue ones). 5 for $5.
    24 y/o w/ Silver/Red
    2000 Honda S2000
    http://www.squeezer.net
  3. #13
    Oct 2003
    Canada
    I love it!!
    Could you send me all those pics in a .zip format possibly?
    zhartwel@flemingc.on.ca
    What type of screen is it? One of the ebay ones you see on there all the time?
  4. #14
    Constant Bitrate aleromaster's Avatar
    Nov 2003
    Valrico, FL
    Hey man looks good. I just got myself an 86 lincoln cont givenchy(fun cars). It was finny cause I was just looking at it yesterday thinking how nice it wold look to mold a touch screen in place if the stereo. Did you completly remove the factory computer in the upper dash
  5. #15
    Variable Bitrate MeanGT's Avatar
    Jul 2003
    Melbourne, Florida
    Quote Originally Posted by aleromaster
    Yup, I completely removed the computer and status panel that was below it. although the computer was required to make the Electronic dash work, so I just gutted it to the bare boards, and moved it further inside the dash. I then had to cut quite a bit of bracing and plastic supports out in order for it to all fit. My only worry is putting it back together when I go to sell the car
    My OLD Carputer: http://www.mp3car.com/vbulletin/showthread.php?t=17412
    Currently, Don't have a carputer :( I sold my lincoln and bought a '93 Acura Vigor, plan on putting a carputer in it one of these days. You can see my vigor at: This Site
  6. #16
    Apr 2003
    hey man...did you have any problems drilling into the plexi? THan
    slow carputer project...real slow due to college
  7. #17
    Maximum Bitrate jusatry's Avatar
    Nov 2003
    Power switch
    How did you build the power switch to start the computer when the car starts? Do you get any trouble from those 12W3's (thats what they looked like) vibrating the comp? Nice setup.
  8. #18
    Jul 2003
    Melbourne, Florida
    Quote Originally Posted by jusatry
    actually they are 12w4's and I haven't had a lick of trouble, even when they are hitting at their hardest.
    About the relay, all it really does it short the connections on the power toggle switch of the power inverter when it receives +12v from my ignition switch. And a second relay then keeps those contacts shorted, via +12v from the computer's power supply so that way the inverter stays on until the computer shuts off, even if the ignition is turned off.
  9. #19
    Jul 2003
    Melbourne, Florida
    Quote Originally Posted by outofmyway6
    No problems drilling the plexi, just need a sharp drill bit, and you have to take it slow to keep it from melting..
  10. #20
    Low Bitrate cotwild's Avatar
    Dec 2003
    Switzerland
    Question what about fluctuation of current?
    Quote Originally Posted by MeanGT
    hey MeanGT,
    really good job!!
    but i don't understand how you solved the problem with the fluctuation of the voltage during starting process? then the voltage is going down to arround 7V and your power inverter can't hold the 12V...? and if you get the power direct from battery it would be the same problem with the fluctuation??
    how does it work with this power switch? sorry.. for my stupid question!
    don't sell this car!!!
    STATUS: planing / building
    Car: 85' Audi Urquattro
    System: VIA EPIA M10000?, GPS, WLAN, DLink Radio
    Display: 7" Lilliput Touchscreen
    Power: 300W DC/AC Inverter, OPUS?
    Sound: 7.1 Dolby Digital with Audigy2 NX
