Take the LCD apart, and take your console out. To remove: 2 screws in front on right, 1 on left in front. 2 screws (1 on each side) on the back section, down from the little storage thing. There are covers on these, feel down the sides and pop them from the back side. Then, under your shifter boot there are 2 nuts you need to remove. Use a socket or something like that. To get boot out, well you should know this, but you just lift on each side until it comes up. Then once you take the back section out, there is another nut holding the first section in, you can see it looking from the back. use a socket to get it out and you can lift the front section out.
To build the LCD into the console, take the front part of the case for it, and place it on the console cupholder. Then cut a section out, and set it into the console like you want it to be. Then fiberglass/bondo it in
I used both, fiberglass for the first layer and Bondo for the rest. I am going to re-Bondo it this xmas break, when I have time. Make sure to make it nice and smooth
