Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: MP3 Pump house (MERCEDES)
  1. #11
    FLAC Mastero's Avatar
    Aug 2001
    India
    Quote Originally Posted by guitar333
    hey mastero, you should post more info your relay controlled a/c and how you did it. that'd be awesome
    Am going to do that in a while. shall be updating the web site.
    till then feel free to ask me anything
    Mastero
  2. #12
    Nov 2003
    Los Angeles
    Can't wait for the info on the A/C relay! How does it work? Does it retain the state it was previously in? Can it still work independantly of the carputer? Does it just control the buttons? Did you program it yourself?
    I have a 1990 Mercedes SEC i am trying to install a carputer in, so i am REALLY curious!
    Thanks!
    Edward
  3. #13
    Aug 2001
    India
    Edward the a/c is controled by the parallel port relay board.
    The software is custom made ME V1 which controlles the Relay board for a/c on & off and fan control 1 , 2 , 3, 4 wheni press 4 the fan goes to speed four and when i press 1 the fan 4 relay cutoff and fan 1 relay goes on ..
    it all in the software ... check what your car has vacum or wire on the fan knob.
    Cheers
    Mastero
  4. #14
    Nov 2003
    Los Angeles
    Thanks for the reply mastero,
    My A/c is automatic (but i can probably get a manual controller for it) so all the controls are electronic either way. Plus the temp selector is potentiometer (spelling?) controlled.
    Also, i was wondering, how much of the software did you script yourself? Or is it pretty much what you found was there?
    Edward
  5. #15
    Aug 2001
    India
    Quote Originally Posted by cyberdrakon
    Edward
    Edward the temp control can be done with a servo which will be opreted with the relay..
    Oh as for the software i had to modify it in major as the ME does not have relay control in built so had to play with it and also code it to work with XP .. plus remove known bugs and add features i wanted (eg when i click FM the fm radio starts and the power ant goes up. and whn i am done then it comes down..
    What do you want to do.. depends on that.... and how you want it ...
    Sit down in your car in the back seat look at the front panel and think what you want were and how should it look, what features will help you and what wont ...
    Cheers
    Mastero
