Page 5 of 6 FirstFirst 123456 LastLast
Results 41 to 50 of 58
Thread: 2003 G35 Sedan Custom Dash And Computer
  1. #41
    Feb 2004
    For the 12v did you use those add-a-fuse fuses to connect? For the switched did you just splice the wire to the cigeretter lighter and connected it with the 12v switched.
    Quote Originally Posted by Izik
    I connected the fixed 12v to the fuse panel. I connected the switched 12v to the cigarette lighter.
  2. #42
    Feb 2004
    also what amp fuses did you use?
    Quote Originally Posted by mikeyg35
  3. #43
    Fairfax, VA
    The links to your site didn't work so I don't know if you have two screens, but I am confused. The top picture of just the dash piece looks like the screen is mounted below the AC controls, in the pics of it actually in the car it is mounted above.
    Did you add two? Or did you move it? Or am I going crazy?
  4. #44
    Nov 2003
    I used the add-a-circuit for the fixed 12v with a 10A fuse. I spliced the switched 12v.
  5. #45
    Nov 2003
    The pics with the screen above the A/C are from the old setup. I just finished the new dash, I will remove the radio and have the screen mounted below the A/C. The new dash in not yet mounted in the car.
    Quote Originally Posted by MSUC5Vette
  6. #46
    Nov 2003
    Original dash:
  7. #47
    Nov 2003
    First mod:
  8. #48
    Nov 2003
    IZIK,
    What made you move your screen down to where the radio was? Where are you going to move your radio to?
  9. #49
    Nov 2003
    I moved it because for the past 6 months I didn't use the radio once. I am moving the radio to storage and connect the computer (that has FM receiver btw) to the AMP.
    Quote Originally Posted by wumagic
    IZIK,
  10. #50
    Aug 2004
    Cape Coral. FL
    There is a lot of G35s on here....
    That is awsome.
    I have a 04 6MT Coupe, I am going to do this project as well.
    Izik, where did you order your 2nd console from?, I want to make it and get it painted then, do the install.
    ~Gary
