Ron
That's the standard battery in the boot, makes the installation a little easier.
Craig
Nice Craig,Originally Posted by craigyb
The battery in the boot is that an extra one, or do Merc put it there instead? is it being charged by the alternator?
Cheers
Ron
www.fsplanes.net NEW site
AMD XP 1800+ / 256mb ram ddr / 2 x 60gig hdd / Asus mobo micro ATX / GF-FX5200 / BU 303 GPS reciever / dlink usb radio
Software:
Window's XP SP1 / USB Radio / Destinator v2 / Mediacar / 3000 mp3's / 30 movies
Ron
Craig
Audi S8 supercar
Modded Xbox 400GB HD
Rear 7" screen & navplus
Toyota Hiace Van
Shuttle PIII 866 256Mb 10GB OPUS powered
MediaCar & Mappoint 2004
Custom fit 7" TFT VGA TSK
You bugger's, not fair
To be honest it makes some sense, I was thinking of having a seperate battery in the boot, and find some charging device,
Be carefull Craig running that invertor, I have shagged 2 x 100amp batterys already in my Audi, they dont like invertors normal batterys.
I got a 3 yr warranty on my last one, and get a new one every year
Looks nice the install of yours
Software:
Ron, I've got an OPUS, but it wont fire my system :-(
So I'm basically stuck with the inverter until I can find a solution.
I'm smoothing the power through a 20A filter between the inverter and battery, hopefully this will isolate the battery from the inverter a bit, plus smooth the volts going into the inverter.
I've got an old style shutdown controller and I'm gonna fit that this weekend weather permitting.
Craig
Audi S8 supercar
Toyota Hiace Van
Yeah the opus doesnt provide the watts neededOriginally Posted by craigyb
untill they make a DC DC 350watt PSU were stuck with inverters, at the moment im shutting mine down by hand, which sucks, but when I wire the invertor to the AMP which is controlled via the remote wire there isnt enough power to crank the car without losing power to the PC.
I also tried wiring in a switch, but the thickness of cable needed to run was not practicle
Good luck
Software:
Ron
I use an automotive relay (12v coil 40A switching) to switch the power to my inverter, I only need thin cables for that.
They cost about a fiver, you can just see it in my inverter picture (attched to the side of it with DS sticky tape). This also means that the shutdown controller doesn't have to handle a lot of power as that can switch the relay too.
In series with my relay I will have a master power cut off switch and the shutdown controller.
Currently looks like this.....
+12V battery --> relay coil --> switch --> GND
Will look like this....
+12V battery --> SDC --> relay coil --> switch --> GND
Craig
Audi S8 supercar
Toyota Hiace Van
yea i seen this car close up, its real tidy. and thanks to craig, i now finished my project (all but the subwoofers).
nice install
and expect pics of the minis install up soon![]()
Hi craigyb,
Nice install. I am about to purchase a CLK and am going to go for pretty much the same set up as you.
What screen are you using? Is it touch-screen? Is it fully motorised?
Any feedback you could give me would be appreciated.
Cheers mate,
Sigol.
BTW, I work in Carrington Business Park, which is just down the road from you. How about a meet?
Hey Sigol
I'm using a VGA touch screen from www.digitalww.com
It's not motorized, you simply push it in and it pops out enough for you to pull it out of the dash. It's got a USB touch screen interface.
If you check digitalww's website out you will see that he is advertising a VGA motorized touch screen, but people have been waiting on these for about a year or more. Still not turned up.
I have one on back order, but I don't expect to see it any day soon.
Craig
Audi S8 supercar
Toyota Hiace Van
craigyb,
I like that wifi atenna where can I get it, who makes it?
