nicely done felton..cant wait to start mines
Just wanted to take some time to post some pics of my current setup and what I am currently working on. Here are the specs on my stereo system and computer.
Stereo System
Pioneer Deck custom mounted (See pics)
OEM Speakers (6x9 rear, 5 1/4 in the doors, tweeters in dash)
Rockford Fosgate Amp
Rockford Fosgate 10" DVC Sub in speaker box
Computer
Shuttle PC w/PIII 900mhz
384 PC-133 ram
Maxtor 7200 rpm 80 gig
5" raw lcd display in custom housing
Lilliput 7" touchscreen (Working on right now!)
Shout out goes to my man Otis because he truly is MacGuyver when it comes to making it happen with custom ideas!
These are the current gauges I have installed in my car.
Sitting @ home waiting for me to come finish it.![]()
did you relocate your HU faceplate to your visor? if so, that's hardcore. that opens up a whole new horizon for my future install.
it seems that he has relocated the Face of his HU, which is damn aesome ill be looking into this... for my setup
It aint no family car.
SEE MK2 At : -
http://www.mp3car.com/vbulletin/showthread.php?t=22810
I did that for my friends car also, I just posted pictures and you can get some ideas from it.
Relocating headunit and extending faceplate somewhere else.
SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
GPSing - Digital Speedo
Button app to Alt-Tab between two programs
Did you have to shave the DDin hole to get the Lilliput to fit?
I have to use fiberglass and bondo to build out the sides but I did have to shave the top and bottom. I also had to remove the clock because it interfered too much. I just finished fiberglassing that whole about 3 hrs ago....I hope to have it ready for paint prep tomorrow afternoon.![]()
WELL.....I was almost done but one of the parts I chose to fiberglass decided to crack on me. Upper right corner of the clock..err where it used to be. I'm thinking I need to do some resanding, fiberglassing then repainting. But this should give people a good idea of what the final product will look like.
Looks like bondo, not fiberglass. Thats why it cracked. Where I used bondo on my install, it wasnt to hold the screen or fill any major holes. If I were you I would have used fiberglass on that top hole and some resin on the sides over that bondo.
For installs like this, I would use 40/40. It is used to adhere two plastics together and then it is easily filled with 40/56 and sanding and painted. Fiberglass does work well with this type of install and bondo is good but will crack. Figure I would try to help![]()
