Results 1 to 10 of 14
Thread: 1997 Honda CR-V
    Low Bitrate divinity's Avatar
    Jan 2004
    Chicagoland
    1997 Honda CR-V
    Finally got around to getting some pics of my install.
    I wanted a setup I can easily remove when need be, hence the not-so-professional look. hehe in the end I'm all about function anyways. Although I would like ideas on where I should eventually permanently mount the LCD.
    Hardware:
    Epia M10000 Motherboard w/ 256MB DDR
    20gig harddrive I had laying around
    CDROM I had laying around
    iRock FM Transmitter
    Delorme Earthmate GPS (painted black for "stealth mode"
    USB Handheld trackball mouse
    USB Foldable keyboard
    Lilliput 7" screen with a cranky touchscreen I have since given up on.
    LED's ripped off of my first "PC" an old Packard Bell p60 that dad bought.
    Software:
    Mediacar (most often used)
    Mediaengine
    Delorme Street Atlas 2004+
    Mappoint 2004 (most often used because it embeds nicely)
    WinDVD
    Some customization of the windows theme
    If anyone is interested, I'll grab some pics of the inside of the shoebox sometime..
    1997 Honda CR-V
    Audio::Custom Speaker Box:/:2x10" Rockford Fosgates:/:Sony Xplod amp
    Computer::Epia M10000:/:Deluo GPS:/:Lilliput 7":/:802.11g:/:In a shoebox
    Software::FrodoPlayer + Destinator3
    Variable Bitrate streetknight's Avatar
    Dec 2003
    that looks good but u have to hide that every time u park, so no one can steal it.
    FLAC samc's Avatar
    Feb 2003
    Brooklyn, NY
    you should make yourself an mdf carpted center console... you ever watch "Pimp my Ride?" But good start.
    Mine needs to be updated.
    about the lilliput
    i was thinking about getting the lilliput, but would you say its really not worth it for the extra 100$ for touchscreen, cuz i will just go with the regular one then? please give me your advice. Also, how is the 7". I was thinking of going with a 10". I plan to run myhtpc, which is a great frontend software for everything multimedia, you can see it at myhtpc.net. Im worried 1024 x 768 of windows XP, would be too difficult to see/use on a 7" screen, whats your opinion.
    thanks you can email me too
    how you like you lilliput touchscreen
    Jan 2004
    Chicagoland
    I don't use my touchscreen at all (i.e. the note about it being cranky). In my opininon the touchscreen isn't worth it (note "my opinion")
    -greasy fingerprints == more cleaning
    -calibration and not being able to hit the corners (in my case I was having trouble closing applications with the X)
    -pain in the *** to do right-clicks
    -doesn't always keep the "button held down" when you drag your finger across.
    -reaching for the screen while driving
    I've found that the cheapo handheld mouse I got works well, I generally use it for just switching through songs on random and then I just have to mouse it over the button and I can watch the road while I click through to a song I like..
    As for the size, the 7" is perfect for my car, 10" would require a lot more work, and I think it would become more obnoxious with that size. However with a larger vehicle I bet it would be great.
    1997 Honda CR-V
    valid points
    you made some good valid points i did not think of. THANKYOU! i was wondering though, as far as the closing X, and cranky, did you try to use a stylus pen? and did it work well? I have a ATI remote wonder ($25) GREAT device, and uses radio freq. you might want to look into that.
    im still curious, did you run XP? i know you stated 7" was perfect, but were you just regarding size. my main concern is, if im running windows XP at a resolution of 1024 x 768, am i gonna be able to read the text and images, or will i be squinting?
    thanx
    Jan 2004
    Chicagoland
    I didn't try the stylus pen that came with the lilliput, knowing that unless I tied it down in the car it would get lost. That might have helped some. I've thought about getting a remote control, but all funding is on hold as a vacation is coming up.. Hehe
    I am running XP on there, considering moving to gentoo if some of the linux solutions become more viable (nudge nudge to those developing I run in 800x600, and I can read things well, although I get a headache because my viewing angle is all messed up.. I can't remember if the lilliput will take 1024x768, but I would be willing to bet it would be hard to read. It was real weird for me at first, as I usually run 1600x1200 on my desktop at work and at least 1024x768 at home. But making everything big helps. I realized that the carputer was more about simplicity in the end. The easiest solution to get it's job done..
    1997 Honda CR-V
    Feb 2006
    Just got my 1998 Honda CR-V.
    After complete removal of my carpc setup form a honda prelude, i'm planning to put it back in my cr-v.
    I have a Toshiba 4600 Notebook with a lilliput 7" touchscreen.
    As far as i can c i fits into the spot where a standard radio is put after removing the tray that's below it.
    I'll post some pictures when i can find the time to start building.
    Low Bitrate chomo's Avatar
    Jan 2006
    Mexico
    permanent location
    my sis's got a 2003 CR-V and I've been dreaming of getting a carpc into it, it's just made for it! you should consider trading yours... fit the screen where the stock head unit is and get the bones into the compartment right over the air conditioning controls, take advantage of the air conditioning vents to cool it down... can you think of a better stock car to install a pc?
  1. Honda fit**?
    By Ricky327 in forum Off Topic
    Last Post: 01-26-2004, 09:36 AM
  2. Honda bodyshop bites hard core
    By gizmomkr in forum Off Topic
    Last Post: 09-10-2003, 09:15 AM
  3. Honda Civic Question
    By xanimal in forum Off Topic
    Last Post: 06-09-2003, 09:35 AM
  4. Swapping stock Honda Decks
    By cruzc_99 in forum Off Topic
    Last Post: 05-23-2003, 01:01 PM
  5. 1997 Mercury Sable. Need wiring info.
    By lovariant in forum General MP3Car Discussion
    Last Post: 06-19-2001, 12:59 AM
