Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 46
Thread: My Project -
  1. #31
    Dec 2003
    South West, FL
    Quote Originally Posted by squigglyrulez
    Actually if you look by the left wheel well, behind the stock panel in the trunk, you have enough room to put a computer for a mustang. I have mine there and you cant see any computer parts, looks stock! Its great!
    Squiggly , do you happen to have any shots of this location in use?
  2. #32
    Feb 2004
    Awesome Install man! I have a 95 Convertible GT that I am curently gathering parts to do an install with. I love the trunk install, but I have a couple JL 10's in my trunk and I wouldnt want Hard drives anywhere near that I bought another glove box on ebay to try and install the comp in there and repace it with my other glove box, didnt work out.. not enought room
    So my next idea is this. I am thinking about getting rid of my back seat with one of these...
    Replace back seat
    I have a 4 point roll cage in my car and people sitting back there even without the cage was close to impossible So I think I want to install this replacement, then build it up to add the PC with neon and plexi windows like your trunk install.
    I would also move my Sony electronic crossover from under the seat to a windowed location also and myabe my amps if there is room!
  3. #33
    Jan 2003
    Overseas
    Scorpnstail,
    I'm changing my computer to an upgraded one at the moment, but in a week or so I will put it back in my car and and take some pictures for you.
    I can go into more details about it when I make the mounts for the new setup. Its not hard to do and you dont have to build a box for the computer.
    No problem.
  4. #34
    Dec 2003
    South West, FL
    Scorpnstail,
    No problem.
    Thanks , I would appreciate it .. I have been looking at the spot you mentioned and i see how there is some spare room there. I ma looking forward to seeing what you did there.
    Scorp
  5. #35
    Are you talking about a full sized computer/motherboard or a mini in the quarter panel?
    The rear seat delete offers ALOT of room. If you go into your car and stick a flathead screw driver under the rear seat, then slide it until your screw driver finds a little mounting block. Push the flathead into the front of that block and pull up on the seat. There is a very large area under the seat. The seat foam fills all of this. SO if your goin with the seat delete kit then you will end up with tons of space.
    As for the JL-10s, I wouldn't worry too much about them if theyre in a 3/4 inch MDF box. My one 8 inch Solobaric Kicker hit 140.6 DB! Which is more than many pairs of 10s, and as much as many pairs of 12s can do. Granted its a good ways away from the speaker but there is alot of noise comming from my trunk.
  6. #36
    Feb 2004
    Quote Originally Posted by gnat
    I allready have the comp. I bought a VIA M1000.
    I have taken the seat out before thats where my Sony electronic crossover is right now. I think it would be cool to use that rear seat delete kit, and build on it.. with some windows and neon lights to show off the comp, and myabe my amps if I put them there also.
    I havnt tested my JLs to see what they get db wise.. I like Kickers also, I had one before I got the JL's..
  7. #37
    Jan 2003
    Overseas
    Quote Originally Posted by Scorpnstail
    Scorp check this out
    http://www.mp3car.com/vbulletin/show...398#post207398
    Squigg
  8. #38
    Tainted Love Cris's Avatar
    Romania
    Gnat, what wires did you use to power all those things? The screen, is it powered from the PSU?
  9. #39
    I have 8 guage going to mypower inverter with a ITPS/relay inline. The accessory line from my radio wiring kit acts as the switch to the ITPS/relay and the power to the lilliput. I will be puting a master kill switch inline this weekend probably.
  10. #40
    Jan 2003
    Overseas
    GNAT,
    How did you mount your touchscreen? Any pics of the bracket?
    Squigg
  1. The Vectra CarPC / CarPuter Project v2
    By ccsnet in forum Show off your project
    Last Post: 08-29-2005, 06:46 PM
  2. Carputer as a comp sci final year project?
    By MikeHunt79 in forum General MP3Car Discussion
    Last Post: 06-23-2004, 10:19 AM
  3. Hello!! CarPC project pics inside.
    By bobbykokinos in forum Newbie
    Last Post: 03-29-2004, 12:44 PM
  4. RLion Project Webpage
    By Reactor in forum General MP3Car Discussion
    Last Post: 02-18-2004, 06:43 AM
  5. my carputer project
    By -TheDarkEye- in forum Power Supplies
    Last Post: 10-13-2003, 11:28 PM
