Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: My 03' Maxima carputer install
    Talking My 03' Maxima carputer install
    I've just done installing my carputer on my 03' Maxima. Took some pics please refer to the link below. Dumbest installation ever I guess, but enough to serve my purpose Comments are welcome!
    Pics here
    Specs for my previous carputer:
    Car: 03 Maxima SE
    Carputer Hardware: AMD Athlon XP1800+, Full size MB, 512MB RAM, 20G HDD, FX5900, SB Live
    Screen: Lilliput 7" Touch
    Install pics: http://members.shaw.ca/hermanao/carputer.html
    Maximum Bitrate jusatry's Avatar
    Nov 2003
    looks nice!
    2 questions:
    1. how did you mount your lilli? any issues with pushing the TS and the monitor moving?
    2. Are you worried about mounting everything to the sub-box? all that stuff is sensitive to both vibration and EMF forces from a magnet.....
    Just a thought.
    I slided the rear end of Lilli's metal base into a gap, and for the front end I used super strong double sided tape to stick it on the console. The base's pretty sturdy just the monitor itself vibrates a little when I use the touch screen.
    As for mounting on the sub, I found that's the quickest+most space saving way to install inside my trunk so that's the first idea I came up with =) I read some posts on magnetic field, most say that it doesnt hurt the HDD, if it does later then I'll switch to a 2.5" notebook HDD instead and put it somewhere else.
    As for vibration, I don't see a lot of posts regarding how to eliminate/weaken it..I think it won't hurt much right? Maybe a smaller HDD is more prone to vibration? Anybody has a solution?
    Car: 03 Maxima SE
    Maximum Bitrate carpcnoobie's Avatar
    Mar 2004
    Interesting pics and great setup.
    I looked at your 'suspension' system with great interest actually. I noticed that you have springs on the bottom to hold the DVD/HDD up but there's no springs at the head of the screws to keep it from slamming upwards. (I hope I explain that well enough). It seems to me that you'll hit a bump, the spring will do their job and keep the DVD/HDD from hitting the box, but the springs will also push them up to the top of the travel, hitting the head of the screw. Wouldn't that be just as bad? Just a thought. I'm really not trying to down your system. I know there's been a lot of talk about using suspension systems or not. I'm sure you'll find out if this works well or not thru trial and error, but I still have to tip my hat for such simple but functional 'suspension'.
    One other thing I saw that I had a question about was your GPS mouse. That looks alot like the ebay mouse that every one has seen and many people are using. It also looks like, from the pic, that there is a red LED that is lit when this is in use. Did you do something to cover up this LED or do you have a red light on top of your car when you go down the road?
    Sorry for so many questions. Please don't think I'm trying to pick on your system. Your system works... that's a lot more then I've done.
    Progress Meter:
    [|||||!||||'] 95% complete
    It's in... it's finally installed!!!! But never finished!
    "It works! It works! I've finally invented something that works!" -- Doctor Emmit Brown
    Thx for the comments !
    You're right for sure, I thought of that but the springs were out of stock in home hardware for now, that's why I'm going to put a washer at the top of the screws then springs underneath it, so two springs supporting the hardware, then it may work better....(of coz w/ longer screws)
    I didn't cover that LED on the GPS, do you mean that the cops may stop me for that? I even thought about mod-ing it to a blue LED ...
    Car: 03 Maxima SE
    Mar 2004
    Ahh.. OK, that explains it.
    It's very possible they could stop you for it. They tend to frown on such things and depending on what state you live in, the laws could easily be 'bent' to let them bug you about it. Good thing it doesn't blink or someone might confuse you for a 747.
    Good job. Is that the ebay GPS?? How's it working for you?
    Progress Meter:
    FLAC MP3DUB's Avatar
    Jan 2002
    Chicagoland, IL
    Heh, creative points for how you mounted the motherboard, but just a word of advice, how stiff are those springs you're using? If they give easily, especially with two, you could easily set the drive into oscilation and kill it in very short order.
    -Nick
    _____________________________
    Monthly MP3Car Chicago Meets
    www.mp3vw.com Last updated: 07/07/2008
    Jun 2002
    Malaysia
    Man, put something to cover up your circuits..
    I cant think what happens if water gets spilled in there without you knowing
    Looks good though, man I envy modern cars =P
    Quote Originally Posted by carpcnoobie
    No that's not the ebay one, but I agree it really looks like one . I got it from a local store in vancouver (canada). It's packaged in a plastic enclosure and it has a model number "TN-200". It works flawlessly, I don't know when to start the timer for timing a "cold start", but everytime it is able to locate my position in less than 10 seconds after I've loaded up my GPS software.
    Car: 03 Maxima SE
    Quote Originally Posted by masch
    Know what, I actually like seeing the circuits spreading everywhere...heh
    Hopefully I won't get any water in as Im going to be extra cautious on that.
    Or maybe just wrap the whole thing using food wrap
    Car: 03 Maxima SE
  1. Replies: 2
    Last Post: 04-26-2004, 07:29 AM
  2. Carputer in '03 Vette - plz suggest
    By slushieken in forum Newbie
    Last Post: 04-19-2004, 12:15 PM
  3. install in a 99 maxima
    By dim-8 in forum General Hardware Discussion
    Last Post: 03-27-2004, 10:50 AM
  4. Replies: 1
    Last Post: 02-03-2004, 02:02 AM
  5. 85 Maxima carputer
    By wylie-c in forum Show off your project
    Last Post: 12-09-2003, 12:23 AM
