Page 5 of 11 FirstFirst 1234567891011 LastLast
Results 41 to 50 of 108
Thread: Enforcer's BMW E36 Carputer 1
  1. #41
    Apr 2010
    Hey Enforcer,
    I'm not sure if you've answered this in your previous posts and everything.. Can an iPod be intergrated into the carputer? so, once the ipod is plugged in music option for ipod music automatically comes up?
    Thinking about putting one in my car.. not sure how it's done or anything, want to know the perks..
    thanks!
  2. #42
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    iPods are not my thing really.
    I know RideRunner can read iPods I believe also CentraFuse can, but not having I don't know how well they integrate.
  3. #43
    Apr 2010
    North Suburbs, Chicago
    Also depends on the version of ipods, the newer ones use encryption. You can always use an AUX-out and control songs from the ipod.
  4. #44
    Apr 2010
    that's true forfend.. although how would i get an AUX-out in the car? put in glovebox or something?
    thanks enforcer, i was going to be using RideRunner anyway. I've purchased the books suggested on this site and i'm starting my build soon.
  5. #45
    Low Bitrate war085's Avatar
    Mar 2010
    Quote Originally Posted by Enforcer View Post
    You have to remove most of the back of the climate control.
    The climate control has two circuit boards, one vertical which has the buttons and display and the other has the fan attached and horizontal, you have to move the horizontal one down under the switch panel.
    Not for the faint hearted.
    Hey Enforcer, I'm facing this climate problem now .. I'm worried to open the A/C panel and leave the circuit to heat and dust .. any problems faced after these years ?
    So, I should get rid of the back of the climate ? Any pictures will be a great help ..
  6. #46
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    The only issues the CC's have had in there is when I have taken them out again and managed to split one of the connecting ribbon cables, but that was my fault.
    Both boards are covered with a protective layer, so dust is not an issue, the heat is no more than it would get when in it's normal place.
  7. #47
    Mar 2010
    Ok! I think I'm gonna have to do it. I just can't imagine how u did it .. you removed the 2nd board inside the cover completely out and total get rid of the cover ?
    What protection layers do you mean .. the ones built in on the board or you added a protective layer ?
    Thanks alot.
  8. #48
  9. #49
    Constant Bitrate vull's Avatar
    Oct 2007
    does it matter where the power is connected to? or it just needs to give the pc some juice when the ignition is turned on? what fuses should be used for m2-atx? wire thickness matters?
  10. #50
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Well you need two differnet power sources, a permanent and one that only gets power when the ignition is on.
    As for fuses, it depends on what your system will be drawing, I have a m4-atx so mine will be different to yours.
  1. (Div)XBox Carputer (warning: many pics)
    By Richie in forum Show off your project
    Last Post: 09-01-2005, 05:24 PM
  2. Good time to buy carputer components?
    By Linus in forum General MP3Car Discussion
    Last Post: 11-25-2004, 08:57 PM
  3. Replies: 9
    Last Post: 10-23-2004, 02:25 AM
  4. Replies: 4
    Last Post: 02-16-2004, 09:08 AM
  5. Thinking of selling my old carputer for an ipod
    By churnopol in forum General Hardware Discussion
    Last Post: 10-15-2003, 10:10 AM
