Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: 04 Honda Civic Type R
  1. #11
    Newbie spaced_chris's Avatar
    Nov 2003
    Newcastle, UK, England
    Quote Originally Posted by kandyman676
    Yes it is a touchscreen. But having some problems with sunglare unfortunately. At night it is completely fine.
    Nice. Might have to look into a one of these
    I'm finding it quite hard to see my screen during daylight. I can see it but could do without the glare. I saw someone on the board using some kind of antiprotective film to reduce it?
  2. #12
    Variable Bitrate darkhalo's Avatar
    Puerto Rico
    http://digitalww.com/VGA_Lilliput-to-Indash_HowTo.html
    your already off to a good start. you can convert your lilliput into an indash unit, if you have the soldering skills needed. If not send it to digitalww.com and they'll do it for 60 bucks. The in-dash housing is 90 bucks. enjoy.
    Carputer: 2.8Ghz P4, 512 RAM, 120gb HDD, WIFI, TV tuner, CDRW/DVDROM, Slot load DVD in front.
    Screen: Lilliput 7" touchscreen (Custom made Carbon Fiber Screen Enclosure)
    S2000 Carputer
  3. #13
    Nov 2003
    Quote Originally Posted by darkhalo
    Cheers for the link, im going to have a good look into this as I think it would be much better for vision to have it in dash! I would have done this originally but I did not quite fancy making a mess out of the dash when I had only just bought the car.
  4. #14
    Maximum Bitrate Yuriy's Avatar
    Jun 2004
    Seattle
    That is one weird stick shift!
    00 Saturn SL2, boosted @ 8 psi - CarDomain
    Newest install - my quickest ever
    My 2nd carputer - b4 I broke the touchscreen
    My very first carputer - voted the most ghetto
  5. #15
    Maximum Bitrate dodgetimes2's Avatar
    MI
    No way! I am using that same PC. HP e-pc 42! Did you end up using an Inverter or did you get the 12V and 19V that it needs to run?
    1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
  6. #16
    Nov 2003
    Quote Originally Posted by dodgetimes2
    Nice one. Its a really nice compact pc for the car. I managed to get it off Ebay fairly cheaply.
    I ended up using an inverter but it doesn't work when the car battery has been used while driving for a while
    How did you use the 12v and 19v that it needs to run?
    I'm now thinking of just using a laptop instead running 12v
  7. #17
    Variable Bitrate proTONEd's Avatar
    Jun 2004
    Belgium
    That's a nokia 6310 isn't it? Ever thought about experimenting with PhoneControl?
    REALLY NICE INSTALL!
    Why is it drug addicts and computer afficionados are both called users?
    Currently : Audi A6 - no install
    Second install : VW Passat '97 CarPC
    First install : '87 Audi 80 CarPC
  8. #18
    Maximum Bitrate XxAndyxX's Avatar
    Dec 2003
    Edmond, Oklahoma
    Those ground loop isolators saved my system... But for some weird reason after a little bit of changing the wires around the isolator made it sound even worse then when I took it off it sounded perfect, I mean I can't here any noise AT ALL, just some alt whine. Crazy, huh?
  9. #19
    Newbie RooDBwoY's Avatar
    Oct 2006
    there's nothing wrong with the gearshift in a uk-spec CTR. i love it. so easy to use and great positive shift.
    suppose most on here don't know how to use a gearbox though :P
    looks nice mate.
    i've currently sold my gti-6 which had a fantastic install in it, but kept the computer, so got a proper good spec VIA EPIA to install when i can figure out what to do with my setup.
    the double DIN slot is handy for a silly fold-out screen along with a head unit. except that when it's out it blocks the heater vents. really handy....not.
    i want to keep my head unit, but the screen would be perfect in its place and i don't want a lame head unit install that doesn't look OEM so i'm stumped for now..
  10. #20
    Mar 2007
    Quote Originally Posted by darkhalo View Post
    anyone got an updated link to liliput to in dash conversion?
  1. '98 Honda Civic
    By appletech in forum Show off your project
    Last Post: 10-14-2004, 12:30 AM
  2. 2000 Honda Civic DX Hatchback
    By 1BlackHatch in forum Show off your project
    Last Post: 02-16-2004, 11:07 PM
  3. Honda Civic Question
    By xanimal in forum Off Topic
    Last Post: 06-09-2003, 09:35 AM
  4. OEM HU Input for 98 Honda Civic.
    By chewtoy in forum General Hardware Discussion
    Last Post: 11-01-2001, 05:46 PM
  5. install on a 95 honda civic
    By schrodos in forum General MP3Car Discussion
    Last Post: 11-21-2000, 05:43 AM
