haa, i was actually surprised you used the two cat5e cables. never really thought about using them to do that:-P
are you just running straight windows xp with large icons?
Well, never though i would be posting in this catagory so soon but time flys when your having fun![]()
click here to see pics
comp specs
1.2ghz
60gig HDD
512 ram
DVD drive with IDE->Usb Converter
7" LCD
"If it works this good why F with it?" -KMFDM "Intro"
Strive for ethical wardriving: http://faq.wardrive.net/
My CarCPUs: v1 - 2000 | v2 - 2004
Mp3Car Meets: http://detrimental.org/eyecandy/MP3CarMeets
Nice install! And the plastic bin for a case is great!
Great work!
2000 Monte Carlo SS - CarPC FINALLY INSTALLED!!!
CarPC: VIA EPIA-M10000, Xenarc 700TSV, 20G 2.5" HD, Opus 90W, Targus USB DVD/CD-ROM
Audio: Audigy 2 USB, Alpine 4 Channel Amp, 2 x Alpine 300W 6x9, 2 x Alpine 200W 6.5 (sub coming soon)
Wow... nice faceplate extension.
slick. Monitors mounted too low for my taste, but thats almost always true.
Tupperware is a bad thing to mount a computer in. that tub can build up a tremendous amount of static charge and easily fry your machine. I'd think about building a better case for it, something you could mount to the side in such a way that it wouldn't easily be seen perhaps?
A digital mind lost in an analog world.
Learn to ask smart questions!
http://www.catb.org/~esr/faqs/smart-questions.html
My car PC: The Lost Cause!
Interesting set up. Gave me a few ideas for my own setup.
Are you worried or have you taken measures with the static in a plastic container?
Also what are you using for inverter and on/off control? Your car pc sounds similar to my plan. Except I'm debating the touchscreen route.
EDIT: While I was lookin' at pics, Fluffy was writing what I was thinking.
Progress Meter:
[|||||!||||'] 95% complete
It's in... it's finally installed!!!! But never finished!
"It works! It works! I've finally invented something that works!" -- Doctor Emmit Brown
i am doing something similar. don't you think that you could ground the case and problem solved? good looking setup
"I'm going back to Cali(Iraq), Cali(Iraq), Cali(Iraq), I'm going back to Cali(Iraq), Cali(Iraq), Cali(Iraq), I know so!!!!" Now I'm here!!
By "ToneRiddle"
I really like the touch pad idea in the ashtrayI have a Xenarc on the way so I won't need a touch pad but thats very cool never the less. Also I really like your tuperware computer case
I think I'm going to do something similar. Its nice to just pop the top off your case plus make it a little shock absorbant. Thanks.
How hard was it to extend the faceplate? What kind of stereo was it?
Don't Fear The Gurkey
Click here to check out My Setup
thanks for all the compliments, yes i am just using win XP with large Icons.
Im not too worried about the case....the mother board is grounded. Its in as much risk as a regular computer case.
Extending the face plate wasnt hard but you should have some soldering knowhow before you do it, the face plate is kensigton
