Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: 91 honda accord install
  1. #11
    Mac Car Moderator kandyman676's Avatar
    Maryland
    Talking
    Quote Originally Posted by ryguy
    Ahhhh the asus pundit good choice! You may want to mount it vertically to save wear on your hard disk. Once i take some pictures of my setup I'll post them up. I have a Pundit box mounted to my sub box. It is spaced a few inches away and also has foam around the mounting brackets for shock resistance.
    Good job so far
    actually, you *NEED* to mount it vertically. once good hard bump on the harddisk from a speed bump or pothole can take out a partion, some data, or the whole drive. I learned my lesson the hard way and always mount the harddrive on its side.
    as always, make sure you have backups of your data, esp with that large of a drive.
    "If it works this good why F with it?" -KMFDM "Intro"
    Strive for ethical wardriving: http://faq.wardrive.net/
    My CarCPUs: v1 - 2000 | v2 - 2004
    Mp3Car Meets: http://detrimental.org/eyecandy/MP3CarMeets
  2. #12
    FLAC robiewp's Avatar
    Dec 2003
    Massachusetts, US
    Quote Originally Posted by kandyman676
    When your read head motors go from being thrown arround (by putting them in the plane that the car gets jerked arround much), you won't just loose some data, you'll with certainty loose the whole drive.
    This is an age old debate.
    car computer rev 5: 8" lilliput and usual suspects
  3. #13
    Maryland
    yes, very much aware of the age old debate:-)
    My point is that you may *not* loose the whole drive. I had the "wonderful" experience of having a 20GB harddrive loose all of its data in one deep pothole bump when it was laying flat and very coushined back in 2001. The drive survived though, but I had to reformat the drive since the paration table and data on it was f-ed.
    i learned to mount it on its side back then:
    laptop harddrives are a completely different story; they are made to take some medium abuse.
  4. #14
    Feb 2004
    NYC
    I'm not completely understand on how to mount the HD? I'm currently mounted it == as that's the only way it will fit in my glovebox...
    But with the glovebox closed, it should be more of a // position. You're telling me I should mount it || ?
  5. #15
    Maryland
    Talking
    Quote Originally Posted by nl4jy
    correct, it should be mounted || .... you may still loose some data in a bump (i didn't though over the roughest PA roads), but not greatly decreases the chances of killing the drive if it was laying == when the head hits the platter hard.
    if you can, try to avoid the // position. cause then you have the worst of both mounts. if it hits a bump, it would be just as likely or worse to have the harddrive head hit the platter hard.
    hope that helps!
  6. #16
    Dec 2003
    Massachusetts, US
    at this point i just think mount it any way it fits. there are lots of dynamics to the movement in a car.
  7. #17
    Sep 2003
    Baltimore, MD
    i think with my car, i would be more worried about what has happened to my car then the 60 dollar harddrive when i go over a large bump
    2003 Jetta GLI
    1.8 ghz intel pentium 4
    256 mb ram
    dvdrom
    xenarc 700tsv
    Status - 90% - need to finish bondoing
  1. need tips for 2004 accord sedan install
    By keghead in forum General MP3Car Discussion
    Last Post: 07-07-2006, 05:48 PM
  2. ME 2.0 Official Bug Reports
    By phat_bastard in forum ME Archive
    Last Post: 01-31-2004, 07:27 PM
  3. Error #91
    By SiGmA_X in forum ME Archive
    Last Post: 01-08-2004, 10:40 PM
  4. 1994 Honda Accord CD Changer In to Aux In?
    By dynamike in forum General Hardware Discussion
    Last Post: 01-16-2002, 04:17 AM
  5. Installing a face unit in a honda CRX 91
    By mprover in forum General Hardware Discussion
    Last Post: 01-08-2001, 10:05 AM
