Page 7 of 8 FirstFirst 12345678 LastLast
Results 61 to 70 of 71
Thread: My HP Pavilion N5190 / F2025A Laptop Carputer Project
  1. #61
    Maximum Bitrate LinuxRacr's Avatar
    Jul 2003
    I just talked to Xenarc, and my screen is on the way back now. It was shipped out on the 6th, and is supposed to arrive TODAY!!
    My Car: 2001 Mazda MP3
    My OLD Carputer project: Here
    Completion Progress Bar: [**********100%]
    Current build! Here
    Completion Progress Bar: [*********99%]
  2. #62
    Jul 2003
    Put my screen back in the other night..man I am glad to have working GPS again. Now I have to work on getting music going again sicne my Headunit went out... Thinking of running an AMP only, and doing the Sirius to USB mod for the win...
    Current build! Here
  3. #63
    Jul 2003
    Ok, so the next thing I plan to do is run a 5-channel amp, and do the Sirius to carpc mod. Don't want to put another headunit back in my ride.
    Current build! Here
  4. #64
    Constant Bitrate 01black_ac's Avatar
    Jul 2005
    NJ
    I don't have the 700-IDT but right now it's my top choice and I might be ordering it in the next day or two.
    On page 4 of this thread you posted two pictures with an explanation of cutting/dremeling off a "lip" which pinches the ribbon cable when the screen is tilted. I looked at those two pictures but I can't figure out which part is the "lip" which needs to be cut away. If you'd be willing, could you do a quick mock-up in MS Paint.. just circle the area with a red circle so it's a little clearer? Please?
    Also, did you RMA the whole unit, and did they replace the ribbon cable?
    Did you dremel that lip off the unit when you got it back?
    Are there any warranty issues with cutting away a piece of the frame, even though it's to repair a design flaw?
    Does the 700-IDT let you control how far back the unit tilts? My dashboard is on a slight angle, not completely vertical, and I would want the unit to tilt probably no more than 75deg from the horizontal, not a full 90deg.
    Finally, are you pleased overall with the 700-IDT? Were you able to get 800x480 working on it?
    '01
    Hang on while I defragment my car...
    the Acura ITX project
    the Acura ITX skin for RoadRunner
    project progress: 99%
  5. #65
    Jul 2003
    5-Channel AMP with Sirius is now installed!!
    Current build! Here
  6. #66
    Jul 2003
    Some picures I snapped last night:
    http://www.msprotege.com/forum/showp...4&postcount=15
    Current build! Here
  7. #67
    Jul 2003
    After the ribbon cable went out again, I am again without a screen. Its time to get a screen and fiberglass.
    Current build! Here
  8. #68
    Jul 2003
    Quote Originally Posted by 01black_ac View Post
    '01
    They fixed mine even though I dremmeled off the edge lip. Here are pictures BEFORE the dremel:
    Current build! Here
  9. #69
    Jul 2003
    Quote Originally Posted by LinuxRacr View Post
    I ended up getting a replacement cable directly from Xenarc (since the cable from mp3car.com that I ordered was too short for my 700-IDT). I changed the cable out, and it works fine again. Just make sure if you ever have to do this, that you pay attention to the way the old cable was folded.
    Current build! Here
  10. #70
    Oct 2003
    Chicago, IL
    Good to hear.
    Still workin on mine. Alot left to do. Damn I'm too lazy.
    Mazdaspeed Car Computer
    gotta redo it all
  1. PC harddrive connected to laptop for home project
    By mrhic2 in forum General Hardware Discussion
    Last Post: 03-30-2006, 12:38 AM
  2. Need help with install of carputer using a laptop...
    By slimcubby in forum General Hardware Discussion
    Last Post: 04-27-2004, 01:55 PM
  3. Replies: 2
    Last Post: 04-26-2004, 07:29 AM
  4. Newbie asks ? Laptop based carputer vs desktop pc based carputer
    By SAScooby in forum General Hardware Discussion
    Last Post: 03-01-2004, 02:59 PM
  5. laptop carputer - noobie needs help :)
    By bigdongers in forum Newbie
    Last Post: 11-22-2003, 09:19 PM
