Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 55
Thread: 2004 Chrysler Crossfire CarPC Finished!
  1. #31
    May 2004
    Quote Originally Posted by kickercivic1
    damn man the first pic look like photoshop, it is done perfect.how did you make it look that clean? nice job
    I planned out the lay out and had to hire out the fiber work... I suck at that glass/bondo work. Rick my friend took the stock plate and gauged the monitor to fit in the middle. Blended in the switches up top where vents use to be. so.... this is what Stock layout once looked like... (not my car)
    now:
  2. #32
    Constant Bitrate fallnangel's Avatar
    Richmond va
    that looks really clean.awesome.
    ..and dont back out just because u think its too crazi , i hate pussies
    -outdidya
    epia m1000,256mb ddr,7"lilli,120gb hdd, Ati remote wonder,400watt inverter,350psu all under xp pro-installed
  3. #33
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    That looks awesome. One of the best I have seen, looks very professional and stock. Did you paint the screen casing as well?
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
  4. #34
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    Quote Originally Posted by mdrt4me
    Got up to 90 degrees this past week and had no problems with the a/c cooling down the car to 73 with in about 5-10 minutes.
    Awesome install... I've been looking at one of those Crossfires for a while now. Just haven't got the balls to make a move yet....
    If your Xenarc is mounted over HVAC vents, watch out for condensation. I had a Matrix Orbital LCD mounted over my AC vents and always had water dripping from it! It never hurt anything, but I would imagine that LCD's would be more sensitive to moisture. Just check it from time to time and post your findings here. I'm sure everyone would be interested in your observations.
    http://www.jeepmp3.com/
    CarPC Stolen. Starting over.
    Ne1 recognize the avatar?
  5. #35
    May 2004
    Smile monitor is not in ducting area.
    Quote Originally Posted by PatO
    My vents have been completely blocked off by a plastic template siliconed in place, never had any problems yet with the panel insert wedged in place to block the ducting from venting.
    monitor is not in the ducting area anyway. I think mounting a monitor near a vent could be asking for trouble. condensation, etc. i am with you. The switch plate is mounted over the blocked ducting. the switches were once in the DIN area below the OEM radio.... look ate the stock pic above for reference.
    Out ChrisG
    Thanks for all the props guys! You all helped inspire me to have the balls to do the install.
  6. #36
    May 2004
    Quote Originally Posted by Quattro-A4
    no stock xenarc color. matches pretty damn well! lucky if you ask me.
  7. #37
    _
    Mar 2004
    Little Elm, Texas
    sweet!
    I see that it appears that someone used the longer screw on the shorter part...heheh
    that sucks...i did that too but it didn't matter since I was sanding and filling a bunch of stuff...
    this install looks damn good!
    still would like to know if you have any pics of the entire process....hope so!
    Jan Bennett
  8. #38
    May 2004
    Quote Originally Posted by Red GTi VR6
    sweet!
    Damn Screws!
    I was hosting all my pics on supermagehost.com and they upgraded to a new browser upload partner and all my pics disappeared. Fuchers. They won't even return my emails. I will search one of my old boxes here in the house to see if they are still on that drive.
  9. #39
    Constant Bitrate ChaCha's Avatar
    Nov 2004
    Los Angeles
    What an incredibly awesome install! Nicely done and I love your car.
    What do you think of your Catalina SC? I'm contemplating one...
  10. #40
    May 2004
    Quote Originally Posted by ChaCha
    Works great form me. Using it for sound piped to an alpine vpower amp. Sounds great and not a hiss from it. Running my linein from xmpcr and have no noise from it. It has decent software and good drivers if you ask.
  1. Loud noice when turning on CarPC
    By Andreas106rally in forum Car Audio
    Last Post: 11-03-2004, 11:27 AM
