I have model 2002 to buth only 2½ month oldOriginally Posted by Motoko
I have found a disgram of a power suplly
go from 8 Volt to 20 volt and the output is 12 volt it have only 2.5 amp
I change the construction so it can give 5-7 amp
the power suplly have a less heat only 4 Watt
The ITPS at 16 volt at 5 amp burn 20 watt in heat
next week I got a new Midt consol to the car, the i move the radio one slot down and make more space over it to a 7" tft screen so I get my on design midt consol paint in the colour off the car.
I will have the input from the PC to the radio via the Aux and I use a cable from Blaupunkt is a Adapter lead ISO 8-pin (plug) to 3,5 mm jack plug (7 607 897 093)Originally Posted by windalo
The radio I have has only one aux input, and it’s okay why have a cd charger installed if you have a PC, you can use the cd charger box to build in a pc ( Mini-itx )
Well, first of all my car is like Moloko´s car, model from 99 to 03, not the new one as you, so on, we do not have aux input.Originally Posted by 4u2n
And I still don´t have a pc in my car, but this week I am starting ordering the components, but it´s more difficult to find them in Europe than in Usa; where to get a good power supply?
hi there, yeh i got the Chill edition Ibiza. i had a CD changer too but its gone now to make room for the Pc (its going to be bolted where the CD changer was). To get AUX input i bought an adapter that goes where the Cd change cable goes as input into the Stereo (se pic). the adaptor is called Connects2 adaptor http://www.stceurope.com/connects2.htm
To install an Amplifier check this http://www.icecavern.com/howtos/ampinstall/main.htm
CarPC status: iPod, 3,456,217 songs so **** you
Well in case you not have a AUX input there is another solution, you can take a FM-transmitter, then you got the sound from PC to RADIO via Radio station exam. 105.50 Mhz it not the best way but okOriginally Posted by windalo
If you want a Mini-itx computer you can look at this link Http://www.viavpsd.com/wheretobuy/index.jsp to find a place to buy it
Some of the power supply you buy you have ship from USA, and it expensive, some place it cost nearly the same to ship it to Denmark as the power supply cost.
In that care I desisted to build bye my self
You can follow my project if you want to have some idea or look in the forum
[QUOTE=Motoko]hi there, yeh i got the Chill edition Ibiza. i had a CD changer too but its gone now to make room for the Pc (its going to be bolted where the CD changer was). To get AUX input i bought an adapter that goes where the Cd change cable goes as input into the Stereo (se pic). the adaptor is called Connects2 adaptor http://www.stceurope.com/connects2.htm
QUOTE]
I’ll put my PC under the main seat, I have calculate the size of my PC to be ca. 20*25*7 cm![]()
The first test
http://www.4u2n.dk/mp3car/image/test_1.jpg
I get the most off the part now
The box for 7" VGA touchscreen monitor is build in the center consol
now I will make it reddy for paint
You can see the rest on my homepage
